Valentine One - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-11-2012, 07:51 AM   #21
Dgc333
Fan#: 85422
What I Drive: 2012, candy blue, SEL
Points 750, Level 14
Points: 750, Level: 14 Points: 750, Level: 14 Points: 750, Level: 14
FF Reputation: 1 Dgc333 Good Standing Member
I wired in my detector by popping out the overhead console and picking up a switched 12v wire there. Much simpler than running a wire down the a-pillar.
Dgc333 is offline
Old 02-11-2012, 10:22 AM   #22
Jdog913
Guest
Fan#: 84424
What I Drive: .
FF Reputation: 3 Jdog913 Good Standing Member
Originally Posted by Ratskrad View Post
@Jdog913 - I assume you ran the wires down the weather stripping on the door side of the a pillar, not the windshield side. If that's true, did you just lever the a-pillar trim out, and thread the wires behind the air-bag harness? Are there any tie-down points anywhere so as to not interfere with air-bags?.
Thanks.
You don't actually put it down the a-pillar. I don't know exactly how I would explain but I will try to get a picture to show you exactly what I did. It is really simple.
Jdog913 is offline
Old 02-11-2012, 08:10 PM   #23
Ratskrad
Fan#: 93063
What I Drive: 2012 Sterling Gray Focus SE
Points 118, Level 2
Points: 118, Level: 2 Points: 118, Level: 2 Points: 118, Level: 2
Level Up 36% Completed
FF Reputation: 1 Ratskrad Good Standing Member
Interesting - If you could get photos that would be great.
@Dgc333 - Did you pick up switched 12V from the auto dimming mirror, or from the map lights? I don't have the auto dim mirror, and presume it's harness is not there.
Ratskrad is online now
Old 02-12-2012, 08:55 AM   #24
Dgc333
Fan#: 85422
It's been awhile since I did it but I believe the wire I used was the power feed to the sun roof. But, anything that powers on and off with the ignition will work.
Dgc333 is offline
Old 02-12-2012, 02:20 PM   #25
newblue12
Fan#: 94825
What I Drive: 2012 Titanium Focus
FF Reputation: 1 newblue12 Good Standing Member
Looks clean, how much for the unit?
newblue12 is offline
Old 02-13-2012, 06:14 PM   #26
Jdog913
Guest
Fan#: 84424
What I Drive: .
I finally took some pictures.
Under headliner
Tucked under A-Pillar
Then down the weatherstripping
Jdog913 is offline
Old 02-14-2012, 03:12 AM   #27
Ratskrad
Fan#: 93063
Points 118, Level 2
Thanks for the photos - I was thinking of doing this, but my concern was that it would mean running a wire over the curtain air-bag. I followed your idea about the head-liner and weatherstrip (works great), but decided to thread my wires behind the airbag (the canvas strip bit). Don't know if it is any better or worse, but I came to buy the Focus after the air bags in my previous car saved me - so I'm a little paranoid when it comes to 'em.
@Dgc333 - thanks - great tip, although I don't have a sunroof :) Thanks tho.
Old 10-05-2012, 10:44 PM   #28
devvy
Fan#: 88652
What I Drive: 2012 Ford Focus SEL
FF Reputation: 1 devvy Good Standing Member
Ratskrad -- can you describe in a little more detail how easily the a-pillar covering came off, and then went back on again? I have a BlackVue camera that I'm about to hardwire to the passenger side fuse box, and I'm seriously bad when it comes to the hands-on stuff :) I am planning on running the wire across the headliner, and then underneath the airbag that's inside the a-pillar as recommended by you, but I am definitely nervous about getting that a-piller cover off and back on again.
devvy is offline
Old 10-05-2012, 11:15 PM   #29
Ratskrad
Fan#: 93063
Points 118, Level 2
Re: Valentine One
Hi Devvy, it just needs to be grabbed firmly at the top and pulled gently, rocking side to side. It will start to separate from the pillar and you will see/feel the clips. Don't pull the cover off - just pull the top away from the pillar about 1", enough to get a hook through to pull your wire. You can then route your wire under the air bag and down the pillar. The side trim on the inside of the door/pillar interface easily pulls back and you can retrieve your cable. Once you got the cable, you can route to the fuse box.
I hope its clear - if not I will send some photos. Good luck.
Old 10-06-2012, 06:52 PM   #30
devvy
Fan#: 88652
I was fooling around a bit today before the device gets here to see how this will go, and I'm a little more confident. I think I'm good, thanks for the advice :)
devvy is offline
