#451 | ||||
They did the test drive for me and had it relearn itself, however, I think they normally let you do it and just remind you that it will shift kinda weird while it relearns itself.
2012 Sterling Gray/Titanium/Sport Handling Pkg/NAV/Winter Pkg/Rapid Spec/Remote Start/K&N Order Date: May 23, 2011 Born Date: June 20, 2011 Delivery Date: June 29, 2011 |
#452 | ||||
Hopefully this gets applied!
2012 Focus Titanium Hatchback | White Platinum | 400A + Navigation Ordered: June 18 | VIN#: July 14 Window Sticker: July 27 Build Date: Aug 2 | ETAs: Aug 13-27, 26, 28, 31 Arrival: Aug 25 (picked up Aug 29) |
#454 | ||||
#455 | ||||
The previous calibration was smooth but the clutch engagement always seemed a bit "soft" to me. Under certain circumstances, the RPMs would drop too slowly during some shifts (i.e. excessive clutch slippage). I just did the update yesterday so I will give it more time before reaching any conclusions. |
#456 | ||||
Well got mine done today. I thought to myself, what if they didnt do it cause they said it was ok, or worse they said they did do it, but really they didnt......Well that was before I drove the car. I could tell right away that they did it! What a difference! Shifting is alot smoother and rpms are a bit higher.
I also noted the Test menu before and after the update and a couple codes did change. They are: under APP it was BM5T-14CO26-AK, now its BM5T-14CO26-AP also under NVM EEPROM it was 17.m8 now its 19.101. I'm not sure if the above changes relate to the transmission update or a gauge calibration update they did. He said the calibration update should fix the fuel guage error i got when it was cold outside.
2012 SE Sedan Spec 201A, Sport appearance package and 17" wheels |
#457 | ||||
My build date is Dec 2nd so I'll be asking the dealer to check into this when I take it in this evening!
2012 Focus Ti Hatch | Ingot Silver | 401A, Nav, Winter Pkg, Moon Roof, Parking Tech. Pkg Build Date: 12/2/2011 | New APIM: 4/4/2012 MFT: Factory v2.11, 3/14/12 USB/Web > v3.0.2, 9/24/12 USB/Web > v3.2.2, 1/24/13 USB/Web > v3.5.1 |
#458 | ||||
If you're pretty happy with the way yours is running, I don't know if I would recommend the update. As mentioned, I thought pre-update test cars I drove performed better. As an aside, mine came off the trailer with 100 miles and a note from Ford that it was used for test purposes. Must've been one of the first off the line with the new software and was tested for that reason. Surprised it passed. |
#459 | ||||
Out of interest, is this exhaust note the shift pattern of a full throttle pre-TSB in D?
My Focus was built post-TSB, so I can't tell for sure, but that shift into 3rd sounds a good deal earlier than mine does (in D). I'm not sure I'd be happier with a shift that low in the power curve. |
#460 | ||||
Got mine done tonight. Will report back.
2012 Focus Titanium HB, Yellow Blaze, 400A, Winter, & 17" Black Machined Rims |
