MSD coil problem found - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-14-2011, 12:40 PM   #1
Paul P
Paul P's Avatar
Fan#: 75111
What I Drive: 2001 ZX3, 71 Chevelle 408
Points 627, Level 12
Points: 627, Level: 12 Points: 627, Level: 12 Points: 627, Level: 12
Level Up 54% Completed
FF Reputation: 2 Paul P Good Standing Member
MSD coil problem found and solved
I bought an MSD coil for my ZX3. I know it is not needed as per many posts. I did find out why after some period of time they really perform poorly. The aluminum standoffs that are included with the coil are a problem. If you think about it going from the steel coil core that needs to be grounded to the aluminum standoffs to the steel bracket to the aluminum head it is not a good setup.
Steel-aluminum-steel-aluminum is not a good ground path with galvanic action taking place here it is all bad. What I did was put some stainless standoffs in place of the aluminum ones that the coil comes with. Problem solved. Another good thing to use is the copper antiseize compound from Permatex. It provides good conductivity and protects against galvanic degradation of the parts. I decided that instead of bitching to MSD that their coil didn't work I'd try to see why it went from great to poor. Sure enough someone there wasn't thinking about the consequences of mixing aluminum and steel. Just thought I would point this out. I do have a note on my RMA about this. Maybe they will change the standoffs who knows.
Paul
Paul P is offline
Old 12-27-2011, 07:25 PM   #2
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,099, Level 67
Points: 10,099, Level: 67 Points: 10,099, Level: 67 Points: 10,099, Level: 67
Level Up 13% Completed
Forum Activity 42%
Buy-Sell-Trade Rating: (41)
thanks for the tip
pasta is online now
Old 12-27-2011, 08:55 PM   #3
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
So what your saying is, they aren't. Worth it?
Sent from my kindlefire.
Djzx3
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 12-27-2011, 09:19 PM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,625, Level 100
Points: 138,625, Level: 100 Points: 138,625, Level: 100 Points: 138,625, Level: 100
Forum Activity 50%
Buy-Sell-Trade Rating: (11)
Good know, I was thinking the same thing on the SD coil. Though it doesn't need to be grounded to work from my experiences. My coil bracket broke and was just hanging there and it ran fine. Though it did start funny which lead me to look under the hood only to find it hanging there. Picked it up while it was running and no change in the way it was running. Though it may run like crap if I drove with it like that for sure. All the more reason why I want to upgrade to COP, that and it looks awesome.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 12-27-2011, 09:22 PM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
Wouldn't it be grounded through the bolt and not the stand offs and grounding itself to the coil bracket and then to the head?
Oh I don't run any stand off's on my SD coil, just set it in the bracket and snugged the bolts down.
Moderator for
Technical Chat
Old 12-30-2011, 10:03 AM   #6
Paul P
Paul P's Avatar
Fan#: 75111
This is really a tip for those who have the MSD or even other aftermarket coils in their cars. It will perform better with less aluminum to steel mixed in the ground path. Electricity always follows the path of least resistance. The bolts are not the necessarily the best path to ground. In my case the aluminum standoffs that came with the coil have rust bonded to the end of them from the dis similar metals eating each other.
Providing a good ground for anything in the cars of today is a must. You said the coil was operating without being grounded and if you think about it the power/control plug was providing the ground and is probably not what you want.
They are worth it if installed correctly. It is a slight improvement likely due to the better spark plug leads used with this coil. You can however purchase the 8.5mm superconductor wires for the stock coil MSD 32949 to yield the same results.
Paul P is offline
Old 12-30-2011, 11:22 AM   #7
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
What makes you think the body of the coil pack needs to be grounded?
BC_ZX3 is offline
Old 12-30-2011, 05:41 PM   #8
teamDFL
teamDFL's Avatar
Fan#: 92060
Agreed. AFAIK, a coil shouldn't be grounded through its body.
Rally Revolution #21
teamDFL is offline
Old 12-30-2011, 09:37 PM   #9
Paul P
Paul P's Avatar
Fan#: 75111
Don't ground yours then. You can do what you want. There are some coil types that need that core grounded. This is one of them. One of similar design is a GM HEI where that core ground is important. If it is corroded the spark will be very weak. It makes a difference. Just thought I would share this tested true experience on the site.
Paul P is offline
Old 12-31-2011, 12:20 AM   #10
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
Buy-Sell-Trade Rating: (13)
The biggest problem with the MSD , turn it over. Made in China. They used to make great products. Used them for years on many muscle cars . Not any more. The stock coils work great.
iroc34 is offline
