#11 | ||||
Once the engine has run for a minute or so, rev it to around 2,000 RPMs for a few seconds. This will build oil pressure to near its maximum level and may identify leaks that wouldn't occur at idle. I don't preload the filter because it's messy and it introduces a batch of unfiltered oil into the engine. If you want to avoid some of the start-up clatter crank the engine for a few seconds with the accelerator floored. Gas is shut off when you do this but the oil pump should fill the filter. Changing your own oil shouldn't jeopardize your warranty but make sure you keep receipts for oil and filter and record date and mileage. To be extra careful, take a picture of the oil, filter and receipt and email them to yourself. This is harder to lose and also gives evidence you used oil that meets Ford's specs (WSS...945 - see owner's manual). |
#12 | ||||
Anybody know the purpose of the felt thing???? Is that some kind of splash guard? If so, call me skeptical of the long-term durability of the material
#13 | ||||
I've added this to the OP. I've never preloaded an oil filter, but considered it after hearing the racket my engine made for 3 seconds after the oil change.
Current 2012 SEL 5 door w/Premium Package - April 2011 | 1957 Chevrolet 3200 - 2005 Past Rides 2000 F150 Sport 2000-2011 | 1988 Ranger XLT 4wd 1988 - 2000 | 1966 Mustang 1983 - 2008 | 1963 Ford Econoline Van 1979 - 1983 |
#14 | ||||
I think it's a sheet of plastic with a textured felt covering. Only time will tell on it's lifespan.
#15 | ||||
#16 | ||||
How does cranking the engine with accelerator floored work with the push start?
I think the car only goes into accessory mode without the brake pressed...? |
#17 | ||||
glad to know it's actually better.
>B^)> |
#18 | ||||
Advanced Auto parts has 5 quart Motorcraft 5W20 for 14.99 on their website.
#19 | ||||
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!ALWAYS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!ALWAYS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!ALWAYS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!PRECHARGE YOUR NEW OIL FILTER WITH FRESH OIL!!!!!!!!!! Do this to ANY new oil filter you install, even if it's a horizontal mount (and of course put a little oil on the gasket). One other item is to make sure the old gasket came off with the old filter. I had that happen to me once many moons ago. But please, charge the filter with new oil before you put it on. Much better and safer than cranking the engine before hand. Joe
Ford Focus 2012 Hatchback 400A Titanium w/ Moonroof Red Candy Metallic |
#20 | ||||
In the 40+ years I have been changing my own oil I have never pre-filled an oil filter. This included all through high school and college working in a garage where no one pre-filled oil filters
My vehicles all have gone 250-300k miles before I have gotten rid of them and I have never had an internal engine failure. Certainly not a bad idea but I don't feel the benefit out weights the nuisance factor. |
