#31 | ||||
#32 | ||||
Yes, an engine designed to run on just E85 can have very high compression allowing it to make more power but because E85 has less energy content than gasoline will always use more. But a flex fuel vehicle is designed to run on both gasoline and E85 so it can't be designed to take advantage of the 100+ octane rating of E85, still needs to run on 87 octane gasoline. So, "higher octane = greater efficiency and power." is wrong when it comes to the Focus. My comment was in response to the first paragraph under "Octane recommendations" on pg 354. Where the sentence; "Premium fuel will provide improved performance." You can't take that out of context from the rest of the paragraph. |
#33 | ||||
Drum n Bass Lover
I incorrectly read what I posted. I agree with you about page 354, but beware, there are some who seem to take that sentence way out of context and make it something it's not.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete www.soundcloud.com/betadnb www.facebook.com/betadnb |
#34 | ||||
Back when cars had distributors and springs/weights/vacuum controlled the advance curve the engineers didn't have the CAD tools to design and model engine designs that are available today. Quite often you couldn't establish the ideal advance curve because of poor combustion chamber design and inconsistent manufacturing so they established safe limits. This allowed the enthusiast to tune for their needs and make a significant improvement. Today designs are very well optimized before the first piece of metal is machined and there is much less room for improvement. A muscle car era bug block mopar needs upwards of 40 degrees of advance to make max power. The current generation Hemi, LS or Mod Motor makes max power with less than 30 degrees of advance and runs to much higher rpms. |
#37 | ||||
Thus, using a good (e.g., 'Top Tier') 87 octane fuel is better than using a crappy (e.g., oxidized, off-season, no-additives) 93 octane. You are incorrect in your statement about causing knock. The Focus' engine does not knock when using 87 octane because it adjusts the timing. Of course, it is not getting as much power as it could get with a higher octane fuel, but that is of small importance compared to the cleanliness and life of the engine. |
#38 | ||||
In the old days distributors had mechanical advance that was strickly rpm dependent, more rpms, more advance. They also had vacuum advance that added more timing in high manifold vacuum conditions such as light load cruising. |
#39 | ||||
I guess most people are not aware that all gas (in the area you live) is created equal. This is because for each area of the country their is only one refinery making the gas. This is especially true during the Summer, due to the EPA requiring at least 18 different formulations for at least 18 different parts of the country. Twice a year all refineries shut down for about 2 weeks so they can reformulate per EPA rules.
Here in Florida almost all of our gas comes from one refinery in the Gulf coast. Now the only difference between brands is that when the gas is moved from the refinery to storage tanks Shell, Mobil or whatever brand can then add additional additives if they want to. Otherwise all the gas (regular, Plus and Premium) has the same cleaning additives that the EPA requires. Also the Refinery only makes Regular and Premium. Plus is made by just blending Regular with Premium either at the retailers storage tanks or at the gas station. |
#40 | ||||
2012 Focus SEL 303A, moon roof, etc 2006 Isusu I350 4x4 (my wife's truck) 2000 Honda Shadow VT600 (my summer ride) 1975 Jeep CJ built 1974 Dodge W300 Power Wagon dump truck & 2002 Kubota B-21 tractor-loader-backhoe |
