anyone using premium gas ? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-05-2011, 07:38 AM   #21
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Points 2,291, Level 28
Points: 2,291, Level: 28 Points: 2,291, Level: 28 Points: 2,291, Level: 28
Level Up 94% Completed
Originally Posted by Dgc333 View Post
If you read the whole paragraph its talking about the fact that in some regions regular is 85 octane and that using premium will give better performance than 85. It does not say you will get better performance than 87 octane.
Here's what it says on page 351 RE fuel ethanol/E85
During the summer season, fuel ethanol may contain a maximum of 85%
denatured ethanol (Ed85) and 15% unleaded gasoline. The fuel ethanol
has a higher octane rating than unleaded regular or premium gasoline
and this allows the design of engines with greater efficiency and power.
This basically says higher octane = greater efficiency and power.
BetaDnB is online now
Old 12-05-2011, 08:05 AM   #22
dasilvarsa
dasilvarsa's Avatar
Fan#: 89551
What I Drive: 2012 2.0 Gdi Trend
FF Reputation: 2 dasilvarsa Good Standing Member
My Findings.
Premium 95 RON Worse Fuel Consumption, Less Low End Torque, Better Power at High Revs
Regular 93 RON Better Fuel Consumprion, More Low End Torque, Worse Power at high Revs
High Octane Gas has a higher % of Retardants to combat Pre-Ignition.
2012 Focus 2.0 GDI Trend (RHD Euro Focus with US Engine)
dasilvarsa is offline
Old 12-05-2011, 08:20 AM   #23
Special K 17
Fan#: 90649
Points 217, Level 4
Points: 217, Level: 4 Points: 217, Level: 4 Points: 217, Level: 4
Level Up 34% Completed
FF Reputation: 1 Special K 17 Good Standing Member
I use 93 and have found a bit of an improvement from 87. Its a little more pricey, but when you only have a 12 gallon tank, its not a huge extra expenditure.
I'm coming from a 98 BMW 740i that I fed premium and had a 20 something gallon tank, so its still much cheaper then what I used to pay. Plus I'm only a semi decent stick driver, and am getting closer to 400 miles to the gallon then 300 now.
Special K 17 is offline
Old 12-05-2011, 09:43 AM   #24
HopJokey
Fan#: 88852
What I Drive: Silver 2012 Ford Focus Ti HB
Points 284, Level 5
Points: 284, Level: 5 Points: 284, Level: 5 Points: 284, Level: 5
Level Up 68% Completed
FF Reputation: 1 HopJokey Good Standing Member
What does the tank size have to do with the actual cost? Does it matter if your full fill up is 12 gal or 25 gal? The price per gallon is still the same.
HopJokey is offline
Old 12-05-2011, 09:45 AM   #25
Special K 17
Fan#: 90649
Points 217, Level 4
Because I'm no longer paying 75$ a tank, it doesn't bother me to keep using premium.
Old 12-05-2011, 09:50 AM   #26
Macsleuth
Fan#: 90432
What I Drive: 2012 Stirling Grey Focus Titanium
FF Reputation: 1 Macsleuth Good Standing Member
Yeah, but it's only coming out of your pocket 1/2 at a time. LOL Makes me feel good when I'm feeling up my Focus, About $50 every 3 or 4 days. My Saturn was $60 to $65 and my Murano was $85 to $100 every 3 to 4 days.
Macsleuth is offline
Old 12-05-2011, 09:53 AM   #27
JSR84
JSR84's Avatar
Fan#: 87788
What I Drive: 2008 MazdaSpeed 3
FF Reputation: 1 JSR84 Good Standing Member
Originally Posted by BowerR64 View Post
Its true in a way, stock the car is "tuned" to run that gas. I believe they retard the timming to allow the cheap fuel to run ok in it.
You start to tweak it with a tune and you bump the timming way up and then the cheap gas starts to cause knock and then the car backs off the timming like in the pictures i posted.
When you get a tune it says premium fuel only and this is why because there IS a difference. It burns better, cleaner or something and im sold on the better gas now.
Why does the cheap fuel cause knock and what is it they put in it that does it? i dont know but i like my car so im not going to put junk in it if there is better stuff right next to it.
A few weeks ago i went to a cheap mom and pop gas station and i filled up with their premium because i was about out and knew i couldnt make it to my regular station. I swear i thought something was wrong with my car. It lost some of its zip i wasnt sure what was wrong it didnt run rough or anything it just didnt have the same zip it did.
After that tank was done i filled up with my normal 92 premium from the BP near the airport i usualy go to and i instantly felt the difference.
If i ever get in a pinch again with fuel im using just what i need to get back to the regular station and thats it.
Their premium must be low grade or something it just wasnt right.
I even had Tom tell me once after i posted a datalog and he asked me what fuel i was using because it was junk and it wasnt the same stuff i posted in an earlier log he adjust the tune to. This was early before i found a good fuel my car was happy with. The junk fuel was from quick trip at that time.
The graph you posted is pretty useless. Its just to cluttered and you really can pull any information our of it, the scaling is all wrong. When posting data logs its usually best just to post up a spread sheet. Its a lot clean.
2008 Victory Red MazdaSpeed 3 - Not stock and self tuned.
2012 Sterling Gray Focus Ti - K&N.
Smashing Internet ignorance one person at a time.
JSR84 is offline
Old 12-05-2011, 10:11 AM   #28
JPopNC
JPopNC's Avatar
Fan#: 88327
What I Drive: 2012 Ingot Silver Titanium H-back
Points 1,271, Level 19
Points: 1,271, Level: 19 Points: 1,271, Level: 19 Points: 1,271, Level: 19
Level Up 72% Completed
FF Reputation: 1 JPopNC Good Standing Member
I've seen those favorably running 91 octane and those who have stuck with 87. I'm the middle-of-the-road guy who's running 89 and have seen welcomed improvement. Is this the best of boths worlds? Better performance and still reasonable cost?
2012 Silver Ingot Titanium Hatchback
Premium Package, Sport Handling Package 18" wheels
MFT w/Navigation, Parking Assist, Rain-sensing wipers, leather seats
JPopNC is offline
Old 12-05-2011, 04:42 PM   #29
zak404
Fan#: 89335
What I Drive: 2012 Race Red Se Sedan Sport
Points 267, Level 5
Points: 267, Level: 5 Points: 267, Level: 5 Points: 267, Level: 5
FF Reputation: 1 zak404 Good Standing Member
Running premium fuel allows the engine computer to advance the timing thus resulting in more power on the lower end torque curve, the burn time for higher octane fuel is also longer resulting in more power.
It would be interesting to see some dyno tests done with regular fuel and premium fuel.
Any of you that used to race will remember what quicker advance curves did for cars.
zak404 is offline
Old 12-05-2011, 11:33 PM   #30
sydtron
Fan#: 91386
What I Drive: 2012 Ford Focus
FF Reputation: 1 sydtron Good Standing Member
99% of the time the gas is cut with ethanol to raise the octane, or the other 1% of the time additives that have vastly lower energy content than gas. Go look at the threads about people complaining about their MPGs dropping in the winter -- that's when ethanol content in gas is increased. Even if higher octane helped, you would have to see a 10% improvement in fuel economy for it to save you any money. That's a tremendous increase in efficiency, something Ford would have considered. Hell, most manufacturers switched to 5W20 to squeak a little bit more out of the engines. Ford put in radiator shutters to get an extra 3% efficiency -- why wouldn't they want a car that pulls down 30mpg in the city cycle and 42mpg on the highway? Even if people ended up using 87 and getting 28/38 instead, it would still make for great numbers in advertisements. Look at it another way; see the people running E85 and see what kind of mileage they get out of it. E85 is right around 96 octane (RON+MON/2) -- if higher octane = better mileage then logically E85 would be what everyone is filling their cars with instead of E85 being a cheap way to skirt CAFE ratings or for people that convert their cars for the massive power gains that are available. No one ever converts for fuel economy and actually gets it.
Will it make more power? Possibly, in situations that you have the engine running under a heavy load for extended periods of time because the engine will have knock issues. The compression ratio is extremely high in these engines and even in day-to-day stuff you'll have the occasional ping/knock. If you take it to an HDPE event, premium fuel is a good idea. Same goes if you're towing or load the car down in the summer months.
Any increase in economy is going to be from being conscious about getting better MPGs and being easier on the pedal. There's also the chance of carbon deposits building up quicker, but that highly depends on what additives are being used. Some cause it, some have a negligible effect. It's too soon to tell how these engines do with carbon buildup but virtually every other direct injection motor on the market has issues so it's something to consider.
sydtron is offline
