2012 Focus Wheel/Tire Guide - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-28-2011, 09:38 PM   #11
thenorm
thenorm's Avatar
Fan#: 14947
Points 5,532, Level 47
Points: 5,532, Level: 47 Points: 5,532, Level: 47 Points: 5,532, Level: 47
Level Up 91% Completed
Forum Activity 10%
Are there any difference in brake rotor diameter between the trim levels?
I.e., will the 15" oem wheels fit on a titanium trim car?
May 2014 ROTM
for street: '02 Infrared SVT
thenorm is offline
Old 11-28-2011, 10:13 PM   #12
Eurofordfan
Fan#: 87186
What I Drive: 1985 Moto Guzzi T5 850 NT
FF Reputation: 1 Eurofordfan Good Standing Member
Originally Posted by Jdog913 View Post
OEM Wheel Sizes:
15X6
16X6.5
16X7
17X7
18X8
OEM Tire Sizes:
195/65R15
215/55R16
215/50R17
235/40R18
Bolt Pattern:
5-108mm
Same bolt pattern as 2012 Focus
Courteous of TCOA
Ford
Taurus/Sable 91-07
Thunderbird 89-04
Windstar 95-04
Jaguar
S-Type 99-03
X-Type 01-03
Lincoln
Continental 88-94, 95-03
LS6 00-03
Mark VII 93-00
Mercury
Cougar 89-98
Sable 86-05
Volvo
240 76-93
740 83-98
850 94-00
940 91-98
960 94-00
C70 98-00
60 Series 00-03
70 Series 98-03
90 Series 98-00
XC90 03
In my opinion the best wheel and tire calculator. Tire Calculator
Snow is just around the corner in the northern states, thought this might come in handy.
I think the 15 X 6 is wrong. I think it is 15 X 6-1/2.
Also, it might be that the 16 X 6-1/2 is actually a 16 X 6, strange as that may be. I certainly could be wrong, here. I say this 'cause the 215/55-16 tires that are on an SE, versus the 195/65-15 tires that are on an S -- stick out a whole lot more than a section size difference of 10mm per side!
Note that all of these wheels are about 63.9mm hub bore I think. They are all hub-centric.
The Volvo rims which are 5 X 108 Bolt Circle Diameter (BCD) are 65.1mm hub bore. You need those special hub spacer rings to make up this difference. Those would be pretty darned thin hub spacers! You must have the wheels properly fixed on the hubs!
Eurofordfan is offline
Old 11-28-2011, 10:46 PM   #13
Jdog913
Guest
Fan#: 84424
What I Drive: .
FF Reputation: 3 Jdog913 Good Standing Member
The original posted wheel sizes are all correct.
Jdog913 is offline
Old 11-28-2011, 11:03 PM   #14
Jdog913
Guest
Fan#: 84424
What I Drive: .
.6mm (.023") of play isn't going to make a difference. 28HopUp was successful with Volvo Wheels without spacers. But for the "professional" wheel and tire people will say you will need spacers.
Jdog913 is offline
Old 11-28-2011, 11:12 PM   #15
NorthernFocalPoint
Fan#: 89496
What I Drive: 2012 Candy Red Titanium Focus HB
FF Reputation: 3 NorthernFocalPoint Good Standing Member
Yup a 15" wheel will fit on all the trims of the '12 Focus (I've got 15" Windstar alloys on my Titanium for winter).
NorthernFocalPoint is offline
Old 11-29-2011, 09:07 AM   #16
28HopUp
28HopUp's Avatar
Fan#: 85449
What I Drive: 2012 SE 5-door
FF Reputation: 3 28HopUp Good Standing Member
I guess I should chime in!
I have had zero problems with the Volvo XC90 wheels 16x7". Here is the thread I made about them:
http://www.focusfanatics.com/forum/showthread.php?t=259031
The Volvo hub bore IS slightly larger, but the 5x108 lug pattern allows the wheels to be centered once the lug nuts are properly secured. I have had no issues with vibration. But here's the caveot - this car is a commuter vehicle only and isn't driven agressively at all. So I am not putting undo strain on the wheel lugs (IMO) through normal driving. If I was autocrossing the car, then I would use wheels with the correct bore size so the wheel hub bares the corrnering load force.
In terms of determining wheel options, offset is very important, along with bore size (you cannot use a non-factory wheel with a bore size smaller than that on a Focus). But another consideration is maintaining sufficient clearance around your brake calipers. Stock OEM brakes are not massive, but you need to ensure that the spokes of the new wheel will clear the calipers (in most cases you'll be fine I think, but it's still something to consider).
Bill Jr.
28HopUp is offline
Old 11-30-2011, 12:26 AM   #17
Eurofordfan
Fan#: 87186
Can you give me a sense for where / what your source is?
I am principally talking about the steel wheels. I found some info from a wheel supplier, that suggests that there is a 15 X 6 and a 15 X 6-1/2 out there -- as in stock / OEM wheels. Likewise re the 16" steel.
Old 11-30-2011, 12:35 AM   #18
Eurofordfan
Fan#: 87186
In talking with a professional wheel / tire shop -- and the principal who I consider to be a pretty decent source of accurate info -- he said go out of your way to stay with the stock ET value. He had had direct experience, decreasing the ET value (i.e. decreasing the back-set) on his shop vehicle. It went from tracking really well, to a circumstance of very poor steering.
Old 11-30-2011, 12:21 PM   #19
Dr. Woo
Dr. Woo's Avatar
Fan#: 90817
If that's the case, then short of having wheels custom-built, we aren't going to find anything in the aftermarket for our cars. The offset values on OEM wheels are at just about the highest numbers possible, but most aftermarket manufacturers seem to go no higher than 45 or so on 5x108 wheels.
Dr. Woo is offline
Old 11-30-2011, 03:11 PM   #20
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
Points 22,044, Level 92
Points: 22,044, Level: 92 Points: 22,044, Level: 92 Points: 22,044, Level: 92
Level Up 70% Completed
Forum Activity 10%
Hmm, I see I could 'borrow' my father's wheels from his Continental to change things up.
officialTHREETWENTY
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
