Using Snow Chains - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-24-2011, 11:24 AM   #11
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
What I Drive: 86 GN, 11.1@128, 20 psi
Points 4,560, Level 43
Points: 4,560, Level: 43 Points: 4,560, Level: 43 Points: 4,560, Level: 43
Level Up 5% Completed
FF Reputation: 8 NJSVTGUY Good Standing Member
Buy-Sell-Trade Rating: (10)
Originally Posted by mlebl View Post
My question is: will I run into major wear and tear on tires, wheels, or fenders?
The front struts would get some additional wear, but all things considered a good trade off.
NJSVTGUY is offline
Old 11-24-2011, 11:26 AM   #12
JCH841
JCH841's Avatar
Fan#: 79303
What I Drive: 2013 Blue ST3
Points 906, Level 16
Points: 906, Level: 16 Points: 906, Level: 16 Points: 906, Level: 16
Level Up 6% Completed
FF Reputation: 3 JCH841 Good Standing Member
(1) You'll notice the speed limit in CA with chains is 25-30 mph. Driving faster will make it more likely the chains fly out and strike the car. (2) even on the tractor, screaming along at 6.82 mph, we found we could usually take up at least one more link after a few minutes of operation; if it's safe you may want to pull over and check adjust the tightness after a couple of miles.
Growing old is unavoidable. Growing up is optional.
JCH841 is offline
Old 11-27-2011, 01:48 AM   #13
djo90
because race car
djo90's Avatar
Fan#: 60957
What I Drive: 2007 ms3
FF Reputation: 6 djo90 Good Standing Member
Use cable chains as well.
2007 Mazdaspeed 3 black mica metallic
1988 Jeep Comanche (MJ) blue/gray. 4.0 5 spd
Rice, It's what's for dinner.
djo90 is offline
Old 11-27-2011, 02:36 PM   #14
mlebl
Fan#: 92085
What I Drive: 2009 Silver Ford Focus
FF Reputation: 1 mlebl Good Standing Member
Thanks for all the comments. Unfortunately snow tires, or studded tires wont work because the drive between spokane, portland, and San diego has mainly Highway miles. I went with some heavy duty snow chains that have 12mm links. I will definately use the idea of tightening the chains after driving for a litttle while. Also, I have purchased an extra set of tensioners just in case.
mlebl is offline
Old 10-17-2012, 05:02 PM   #15
jetfuelgm
Fan#: 101553
What I Drive: 2012, Tuxedo Black, Focus Titanium
FF Reputation: 1 jetfuelgm Good Standing Member
2012 Focus Titanium Tire chains
I called our local Les Schwab and they advised to check the owners manual, which I did, it does not provide a recommended size for the 215/50 R17's.
Anyone found a suitable size chain for the 17's?
jetfuelgm is offline
Old 10-17-2012, 05:55 PM   #16
lyonsroar
Guest
Fan#: 63166
What I Drive: 2009 Volkswagen GTI
FF Reputation: 31 lyonsroar Great Standing Member
quality thread bump...
lyonsroar is offline
Old 04-21-2013, 05:54 PM   #17
jetfuelgm
Fan#: 101553
I received the same reply from Les Schwab. Kind of wonder what was going through the salesman's head when I told him of the travel needs for my job in OR, WA, ID, MT, WY???
Old 04-22-2013, 09:36 PM   #18
Elder
Points 13,459, Level 75
Points: 13,459, Level: 75 Points: 13,459, Level: 75 Points: 13,459, Level: 75
Level Up 53% Completed
I'd say the salesman was counting the commission on the Titanium Edition Focus, not worrying about how you'd get around in the Winter!
I'm not current on all the optional sizes for the '13's, but I THINK 16" is the smallest Std. size avail..
A set of those, with appropriate size Winter tires, should get you through MOST of the Winter driving you face. And you should be able to get chains to fit those to carry so you're "legal" where required. Going on through the pass when USE of chains is required would be at your discretion. (More than one Truck sits it out for a bit until the "chain law" lights go out as the road is cleared...)
Laws on the use of chains vary by state, year, and type of vehicle from what I've seen, & can change by the minute depending on current conditions in some cases.
In the few times I've been over the passes in the Winter myself, I've managed to avoid "throwing iron" - though I had to buy enough chains to be "legal" just in case!
Hope some 'Locals" from the states involved comment, at least you have some time to plan for next year at this point.
Cheers!
sailor is online now
Old 04-22-2013, 10:58 PM   #19
jsr72
jsr72's Avatar
Fan#: 97393
What I Drive: MK III
Points 153, Level 3
Points: 153, Level: 3 Points: 153, Level: 3 Points: 153, Level: 3
15" is allowed. From the MKIII owners manual (non ST)...
Use SAE Class S chains with 195/65R15 or 215/55R16 tires only; do not use tire chains with any other size tires.
jsr72 is offline
Old 02-06-2014, 06:02 PM   #20
mvgary094
Fan#: 118766
What I Drive: 2000 silver zx3
FF Reputation: 1 mvgary094 Good Standing Member
If you don't understand how this works on the west coast, please stop telling us about snow tires. In California we barely ever need chains or snow tires but if we do, they are enforced by the highway patrol. Nobody in California who doesn't live in Tahoe has snow tires. I've been trying to find out for a while if anyone has used chains and all I hear about is snow tires. If somebody does know about whether you can run chains(cables) on an mk1 with 195+ tire width. Their input would be greatly appreciated.
mvgary094 is offline
