Old 10-29-2011, 02:14 PM   #1
LVSBB6
Fan#: 91020
What I Drive: 2011 Ford Focus
FF Reputation: 1 LVSBB6 Good Standing Member
What's the easiest way to remove tail lights on the hatchback?
Manual says remove the plastic pieces, and then remove the lights, but didn't clearly say how and which piece to remove
Has anyone changed bulbs or remove the tail lights before? care to share your experience? thanks!
LVSBB6 is offline
Old 10-31-2011, 12:55 PM   #2
LVSBB6
Fan#: 91020
Up for answers :) I'm sure someone else has swapped tail lights before.
LVSBB6 is offline
Old 10-31-2011, 12:56 PM   #3
feta_mgp
feta_mgp's Avatar
Fan#: 88210
FF Reputation: 6 feta_mgp Good Standing Member
What are you trying to swap them to? I didn't even know there were taillights other than OEM offered yet...
2012 SGM SEL Sedan 303a w/o Nav
Job 1 built 6/2011
feta_mgp is offline
Old 10-31-2011, 12:58 PM   #4
Dr. Woo
Dr. Woo's Avatar
Fan#: 90817
He might be tinting them.
Dr. Woo is offline
Old 10-31-2011, 01:05 PM   #5
LVSBB6
Fan#: 91020
On actually I'm just trying to change the bulbs to brighter ones...instruction manual says to remove the light housing first...but I have difficulty understanding which plastic panels that need to be removed.
Anyone has experienced?
LVSBB6 is offline
Old 10-31-2011, 01:13 PM   #6
feta_mgp
feta_mgp's Avatar
Fan#: 88210
You shouldn't have to remove the housings to get at the lights. Look in your trunk/hatch and there should be removable panels near the taillights. All it should take is reaching a hand back there to get to the bulbs... I may be wrong as I haven't done it, but that's normally how it works.
Job 1 built 6/2011
feta_mgp is offline
Old 10-31-2011, 01:44 PM   #7
dasilvarsa
dasilvarsa's Avatar
Fan#: 89551
What I Drive: 2012 2.0 Gdi Trend
FF Reputation: 2 dasilvarsa Good Standing Member
Open the small covers in the trunk behind the tail lights. (hatch)
Inside there are 2 Grey plastic wingnuts.
You have to look carefully with a torch to find them.
Get someone to hold the tail light so it cannot fall on the floor.
Remove the wingnuts.
Warning (Installing higher wattage globes may melt your plasting housing)
2012 Focus 2.0 GDI Trend (RHD Euro Focus with US Engine)
dasilvarsa is offline
Old 10-09-2012, 07:57 PM   #8
jake90
Fan#: 104685
What I Drive: 2012 Black SEL (5dr Hatchback)
FF Reputation: 1 jake90 Good Standing Member
Hi all, im new to the forum, this is my first post... Im actually looking to remove the whole taillight. Its cracked and needs replacing. (my wife thought the new focus was able to reverse through walls).
I couldnt find any other threads with the answer but this one i thought was relevant enough... any help would be much appreciated.
jake90 is offline
Old 10-09-2012, 08:12 PM   #9
VH5150
VH5150's Avatar
Fan#: 97424
What I Drive: '12 Ti Hatch, '04 Ranger Supercab
FF Reputation: 2 VH5150 Good Standing Member
Do Not--I repeat--Do Not drop the plastic retaining nuts inside the interior trim panel!
Once you get the nuts removed, the locating pi will still be holding the taillight in place. Give it a good, firm tug, and the light will separate from the body. Then disconnect the wiring harness. Did I mention not to drop the wing nuts?
2012 Focus Titanium Hatch--6/12/12 Build Date--Tux Black--Charcoal Cloth--DCT--Winter Pkg--Moonroof--K&N Drop-in--Early Ti Engine Cover--Magnaflow 15072cat back--Redline Tuning QuickLifts.
2004 Ranger SuperCab--Project:FX4 Level 3
VH5150 is offline
Old 10-09-2012, 08:17 PM   #10
Timthom62
Timthom62's Avatar
Fan#: 97579
FF Reputation: 3 Timthom62 Good Standing Member
On page 131 of the owners manual it shows the removal procedure for the 5-door tail light. The basic process is described in post #7 in this thread.
Best of luck!
2012 Red Candy 5-Door SEL 303A (built 2/27/12)
2012 Sonic Blue 5-Door SE Sport 203A (built 9/13/11)
Last edited by Timthom62; 10-09-2012 at 10:33 PM. Reason: Deleted broken link to Owners Manual
Timthom62 is offline
