2012 Focus Transmission Shaking - Page 20 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-07-2011, 02:28 PM   #191
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,022, Level 33
Level Up 82% Completed
Forum Activity 12%
I (and many others) have been posting transmission issues in the non-performance section of 2012 Focus (whoops!)
Here's an update on that pulled TSB:
P068A - Indicates the non volatile random access memory (NVRAM) write did not complete successfully after the ignition key was turned off, prior to PCM shutdown. This DTC sets when the PCM power relay is de-energized too early.
P2610 - Indicates an error in the internal PCM engine off timer processor. The test fails when the difference between the engine off time and the central processing unit (CPU) time exceeds a calibrated limit for a calibrated amount of time.
For these DTCs, the technical details probably aren't important because there is a TSB that covers these issues:
TSB 11-10-2
Publication Date: October 2, 2011
Some 2012 Focus vehicles built on or before 8/12/2011 may exhibit the following engine drivability and/or automatic transmission concerns; RPM flare on deceleration coming to a stop, rough idle on deceleration coming to a stop, intermittent engine idle fluctuations at a stop, intermittent vehicle speed control inoperative, intermittent harsh engagement/shift, engine no-start with engine coolant temperature (ECT) open circuit faults and intermittent no-crank/no-start condition after performing normal Powertrain Control/Emissions Diagnosis (PC/ED) pinpoint test (PPT) diagnostic procedures. The vehicle may also exhibit diagnostic trouble codes (DTC) U0422, P00D2, P068A, P0850, P2610, P2832, P286F or P2877. The vehicle may also exhibit intermittent false initialization to 21 C (70 F) on the instrument cluster's ambient temperature display upon engine start up.
The fix is a simple reprogramming of the PCM and TCM.
Not that it seems to matter, because my dealer told me "That's how these transmissions work."
That's how they work - but they've changed something on models after 8/12/2011 and won't tell us what or why? I guess I didn't know dual-clutch transmissions were supposed to make crunching noises when shifting gears... I'm just trying to save Ford (and myself) a headache and $$ when my transmission fails in 3 years due to bad programming and the warranty will have to pay for it.
Btw, I'm at 7,500 miles and will be checking this issue at a different dealer tomorrow.
PratoN is offline
Old 10-07-2011, 05:00 PM   #192
murfmoble
Fan#: 90355
What I Drive: 2012 silver focus titianum
FF Reputation: 1 murfmoble Good Standing Member
2012 6 speed transmission
got my car back after a week in the service bay, a guy from detroit came down to test drive and did this fix,reprogram pcm,trans,clutch,range sensor,shift drum adaptive learn and drive cycle. the car smoothed out alot and doesn't have that shudder anymore, still wish they would have been upfront about the feel of this new trans before selling it to us!
murfmoble is offline
Old 10-07-2011, 05:14 PM   #193
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 12%
Tell me about it! Do you think it'd be better or worse to go into the dealer with a copy of the TSB? I don't want to be rude, but I want it fixed.
EDIT: Nice thing about it is that if they don't know about it, it tells them exactly what they have to do.
PratoN is offline
Old 10-07-2011, 06:32 PM   #194
Montana
Montana's Avatar
Fan#: 89448
What I Drive: 2012 Candy Blue Focus SE
FF Reputation: 1 Montana Good Standing Member
If I am able to get my hands on a copy of the TSB I take it in with me and present it to the service writer and tell him this is the issue and this is the fix.
That way no wires get crossed and they have a copy of it.
Montana
Montana is offline
Old 10-07-2011, 07:18 PM   #195
murfmoble
Fan#: 90355
get in touch with a service rep from detroit through this site first and have them help handle the problem with your dealer, thats what I did and they helped alot and I spoke with the rep after they worked on it to be sure I was happy, give it a try! the tsb was 11-09-14
Old 10-08-2011, 11:33 PM   #196
Points 27,768, Level 98
Points: 27,768, Level: 98 Points: 27,768, Level: 98 Points: 27,768, Level: 98
Level Up 42% Completed
I'm really glad to see this working for someone again.
Old 10-10-2011, 05:19 PM   #197
FordService
FordService's Avatar
Points 3,388, Level 36
Level Up 26% Completed
Forum Activity 25%
Originally Posted by Montana View Post
I buy the car and take it into the dealer for the shuddering, Dealer confirms it is doing it and is told by Ford it is normal break in. Contact Customer Service both you and Melissa, and am told it is normal break in, Go past the normal break in mileage and car still shudders and am now told if it increases in severity let you know. Any issue with a car should be dealt with as a issue and not based on severity, If the tech drives the vehicle and verifies that it does as the customer states they may consider it non severe but they are not sitting in traffic with the issue either.
The TSB that was released and recalled was for vehicles built on or before 08/12/11, What changed after 08/12/11 that they were not affected by this TSB?
Individual situations are handled on a case-by-case basis, and I want you to keep me updated on any changes, as that is the best way to ease your concerns. I can't speculate on why TSBs are for certain date ranges, as that is from the engineers, but I can ensure any updated are noted in the system, and escalated to your CSM.
Originally Posted by MJEFF View Post
Will do....I don't think they are actually purchased as a fleet, but I believe our small company bought 3 identical cars, two of
Just responded to your PM.
PratoN - How did your dealer visit go? Please PM me your VIN, contact information, mileage, & servicing dealer name/state and I'll assist.
Thanks, murfmoble! Glad I could help.
I appreciate your long-term support!
~Natasha
FordService is offline
Old 10-11-2011, 04:49 PM   #198
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 12%
PM'd
PratoN is offline
Old 10-12-2011, 02:42 PM   #199
FordService
Forum Activity 25%
PM'd
It's been received. I'm working though my PMs and will respond soon. Thank you!
~Natasha
Old 10-12-2011, 02:48 PM   #200
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 12%
Awesome! Thanks for the help - I'll let the dealer know if they ask.
PratoN is offline
