Common Ford Focus Transmission Problem, How to fix - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-02-2011, 11:16 AM   #71
fordcrazi
Fan#: 86801
What I Drive: 2003 white Focus
FF Reputation: 1 fordcrazi Good Standing Member
hard shifting
My transmission seems to only act up when i get heavy with gas pedal, shifts very harsh, seems to not shift when should stays in gear longer than i think it should than slams into gear, If i get off the interstate at 70 slow down to 15-20 and smash the gas to jump into traffic it slams into lower gear so hard it throws me back into the seat then shifts hard on up shift and over drive than it is fine. was getting on interstate and it began to shift put paused for few seconds and slamed into the next gear.. this sound like it could be like everyone else and need to replace the solenoid or 2? car sat for a few years
fordcrazi is offline
Old 10-04-2011, 10:49 PM   #72
coop875
Fan#: 84033
What I Drive: 2000 zx3
FF Reputation: 1 coop875 Good Standing Member
since this thread was brought back to life..
what solenoid is 2-3
also when it is supposed to shift it will sometimes not go into gear and feel like its just being revved in neutral, solenoid? this only occurs on shifting 2-3
was rolling up to a stop light and it locked up aswell, put into park and it ran noram ( with slipping still)
ideas?
coop875 is offline
Old 10-24-2011, 08:56 PM   #73
Ricky g 863
Fan#: 91159
What I Drive: 2008 focus se
FF Reputation: 1 Ricky g 863 Good Standing Member
Hey I have a 08 focus se with 37k miles and I seem to be having kind of the same problem as you. What my car is doin is that when you first turn it on,on cold start or when its been running it runs good,but when I stop at a stop light or stop sign or just stop it jerks between gears. So when I take off after stopping it jerks from 1 to 2 and then on 2 it dnt shift to third and so when that happens the motors sounds like it being forced and the rpm is at 3000 or more depending on speed. But when I stop and turn the car off then turn it back on it runs good and then it does the same thing all over again. I took it to a machanic and he said that it was the coils but I changed them and it still doing the same. Please Someone let me know what it it could be so I can get it fixed
Ricky g 863 is offline
Old 10-31-2011, 02:05 AM   #74
aipsaro
Fan#: 34013
FF Reputation: 1 aipsaro Good Standing Member
ideas?
is your check engine light on? Also, solenoid E shuts off when shifting to 3rd gear
aipsaro is offline
Old 10-31-2011, 02:09 AM   #75
aipsaro
Fan#: 34013
aipsaro is offline
Old 10-31-2011, 02:24 AM   #76
aipsaro
Fan#: 34013
solenoid diagram here and here for part numbers
aipsaro is offline
Old 10-31-2011, 05:57 PM   #77
FordService
FordService's Avatar
Points 3,388, Level 36
Level Up 26% Completed
Forum Activity 25%
Hey Ricky g 863,
You may want to bring it to the dealer for inspection, since your Focus may still be under warranty. Let me know if I can help.
~Natasha
FordService is online now
Old 11-08-2011, 07:52 PM   #78
Ricky g 863
Fan#: 91159
Yes my lights is one
Old 11-09-2011, 01:01 PM   #79
Zach man
Fan#: 91175
What I Drive: 2002 silver zx5
FF Reputation: 1 Zach man Good Standing Member
these diagrams are awsome man...
i read every post wondering if these were around here somewhere... thank you
Zach man is offline
Old 05-27-2012, 12:14 AM   #80
drewts86
Fan#: 72974
What I Drive: 2004 Burgundy ZX3
Points 468, Level 9
Points: 468, Level: 9 Points: 468, Level: 9 Points: 468, Level: 9
Level Up 36% Completed
FF Reputation: 1 drewts86 Good Standing Member
Go to Autozone or a local mechanic that will run your OBD-II code for free or cheap. Due to some lame California law Autozone's here cannot loan out OBD diagnostic tools. The Ford dealer hear wanted to charge me $150 just to run the diagnostic scan, so I told him to go fark himself and took it to a local mechanic that ran it for free. Bottom line is that tool should tell you what the problem is (in the case of my '04 I had the same solenoid fail as the OP).
On another note, I just had the same thing happen to OP and it's super easy to fix. With the correct part and all the correct tools on hand, it shouldn't take more than an hour.
OBD-II scan: FREE
Solenoid from Ford dealer: $60
Auto-tranny RTV gasket: $6
6 qts ATF Merc V:$40
Running car: Priceless
drewts86 is offline
Similar Threads
Zero to 60 & 1/4 Miles Times (List of all cars) OrangeSVTguy Drag Racing 36 07-09-2013 10:48 PM
Ford debuts Focus Coupe-Cabriolet Kneel Ford Focus & General Car Chat 50 10-02-2011 08:04 PM
Big plans for tiny Focus remusrm Ford Focus & General Car Chat 50 08-19-2009 02:51 PM
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Even this fOCUS!!!! Jeezzzz!!!! TORQUERULES Ford Focus & General Car Chat 22 02-11-2007 11:47 PM
