Old 09-24-2011, 06:40 PM   #11
Vrod21
Vrod21's Avatar
Fan#: 86456
What I Drive: 2012 Tuxedo black metallic SE
FF Reputation: 2 Vrod21 Good Standing Member
Originally Posted by vegachicago View Post
How can I remove that flat plastic pin. Mine will not budge - do you need a new one to replace it? Thanks everyone.
Get a paper clip or very small screw driver. Stick it in the center hole. It should come out. Hope this helps.
Vrod21 is offline
Old 09-25-2011, 09:39 AM   #12
vegachicago
Fan#: 89988
What I Drive: 2012 Focus SEL Sterling Grey
FF Reputation: 2 vegachicago Good Standing Member
Thanks - that did it.
vegachicago is offline
Old 09-29-2011, 07:41 PM   #13
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
FF Reputation: 200 warneej Excellent Standing Memberwarneej Excellent Standing Memberwarneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I know for a fact that the MFT-equipped models do have this extra USB port as that is how the system is updated at the dealer. Haven't tried using it yet for media though!
Looking for 17x8 wheels to race on! PM me if you have something!
173.4whp
gump
crew #6
warneej is online now
Old 10-03-2011, 10:11 PM   #14
Dethpickle
Dethpickle's Avatar
Fan#: 86276
What I Drive: 2012 Focus Titanium HB
FF Reputation: 1 Dethpickle Good Standing Member
Forgive me... That doesn't help at all.
I've got a small screwdriver that fits in. I've done everything with it that I think I could do with a paper clip. I've pressed pretty hard in the center and tried to pull it out. I've tried screwing it several directions. Pressing it different directions... no dice.
What am I trying to release? Should I be pushing it one way or another?
Dethpickle is offline
Old 10-06-2011, 03:46 AM   #15
SimonSellsAustin
SimonSellsAustin's Avatar
Fan#: 90594
What I Drive: 2012 Sonic Blue SE hatch.
FF Reputation: 2 SimonSellsAustin Good Standing Member
Have you tried swapping USB1 and USB2 to make the new "USB2" install the primary? I'm going to try this mod this weekend and put mine in the door pocket. I'd like to know if anyone has tried this mod.
"May the wind always be at your back and the sun always upon your face and may the wings of destiny carry you aloft to dance with the stars."
~ Boston George
SimonSellsAustin is offline
Old 10-08-2011, 08:07 PM   #16
Jgetz524
Fan#: 90377
What I Drive: 2012 black SEL sedan
FF Reputation: 1 Jgetz524 Good Standing Member
None of that helped me either. I ended up pulling on the panel hard enough that that plug released. After having the plug out, I see nothing that could result from using that center hole.
Since the plug is recessed and has a cover over it, I used a sheet metal screw with the proper diameter in place of the plastic plug. If I ever want to take the panel off agian, no more drama.
Jgetz524 is offline
Old 10-09-2011, 07:26 PM   #17
Phantom Zero
Phantom Zero's Avatar
Fan#: 90652
What I Drive: 2012 Sterling Grey Ford Focus SE
FF Reputation: 1 Phantom Zero Good Standing Member
will this work on the SE model without SYNC? guessing not
Phantom Zero is offline
Old 10-31-2011, 08:21 PM   #18
juanfran
Fan#: 91347
What I Drive: 2012 Steerling Grey Focus SE
FF Reputation: 1 juanfran Good Standing Member
Same Question
juanfran is offline
Old 10-31-2011, 09:28 PM   #19
Vrod21
Vrod21's Avatar
Fan#: 86456
Hey, sorry for the delay. The 2nd USB port is in the sync computer. I would have to say it will not work for you.
Vrod21 is offline
Old 11-13-2011, 06:36 PM   #20
voipguy
Fan#: 85222
What I Drive: 2012 S.Grey SE Spt,4dr,Wint,MR,6sp
FF Reputation: 1 voipguy Good Standing Member
I did this mod tonight and here are my thoughts.
1. Use a flat blade screw driver to take the flap off the side panel.
2. Getting that round pin out wasnt easy, had to work it loose and carefully pull at the panel the way described, make sure you remove the front floor mat.
3. I ordered the monoprice adaptor as mentioned eailer but it would not fit so I had to shave it down, then I was able to get into the connector. Im thinking about using a Standard USB mini 5pin male to Male USB cable and getting one of these:
http://www.amazon.com/USB-Female-Ada...1230113&sr=8-2
This way it will fit better & we can try to connect a USB Memory stick into the adaptor as well as an Ipod, will let you know if it works better!
And thanks for the drywall screw idea, for reconnecting the panel.
voipguy is offline
