Sound System Install - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-18-2011, 07:46 AM   #41
Tony407
Tony407's Avatar
Fan#: 85289
What I Drive: 2012 Sterling Gray Hatch Titanium
Points 11,374, Level 70
Points: 11,374, Level: 70 Points: 11,374, Level: 70 Points: 11,374, Level: 70
Level Up 31% Completed
FF Reputation: 4 Tony407 Good Standing Member
Center channel
While I was at it I decided to check out the center channel. To be honest, I wasn't sure how much (if any) sound this sucker was putting out. I've tried to get my head close enough to hear it, but I really couldn't hear much.
To get the center channel out, I used my pry tool and carefully went around the grill in a circular pattern and carefully pried it out (notice I used the word "carefully" twice). It's wasn't hard, but it takes a little patience because I didn't want to break anything. It's in there pretty good.
Once I had it out I faced it towards me and was surprised how much volume was coming from it compared to the door speakers. I then disconnected it and was really surprised how much I noticed its absence. Which, I have to say, was a good thing. I always thought the Sony system in the Focus was mediocre at best, with one of my complaints being a harshness at higher volumes, with a moderate amount of distortion in the upper end. Once I disconnected the center channel most if not all of that was gone. GONE!! No more center channel speaker for me!!
So are you wondering how much presence around the dash/windshield area I would miss without the center channel? Yeah, me too. But I'm happy to say with the added clarity of the JL speakers vs. the Sonys, the center channel is not missed at all. Not a bit. Evidently the center channel is not a "true" center channel, meaning it's not receiving any sort of dedicated music material that's unique to it. I'm assuming all it is is just a summed mono signal. So it's been permanently unplugged.
I really didn't notice too much difference in sound quality when I had only done the driver's side speakers. However, with both sides now done I have to say the difference is quite noticeable. It's much more musical, detailed and articulate, and easier on the ears too. (The easier on the ears part is probably mostly due to the center channel being shut off now.)
Here's some pictures of the center channel speaker and the cavernous hole left in the dash when the grill is removed. The yellow arrow is pointing to the speaker connector. I took the photo through the windshield so the bottom of the photo is facing the front of the car:
Tony407 is offline
Old 08-02-2011, 10:46 AM   #42
Rod Knock
Fan#: 88184
What I Drive: 2009 WRX
FF Reputation: 1 Rod Knock Good Standing Member
Any plans on upgrading the center channel or are you just going to continue running without it?
Thank you for all the info and time you've put into documenting everything!
2012 Ford Focus Titanium 400a Package 5 door
Sterling grey metallic, 17" Polished Alloy Wheels
Tentative build date: 8/22
Tentative deliver date: 9/5
Rod Knock is offline
Old 08-02-2011, 11:12 AM   #43
immaengineer
Fan#: 87350
What I Drive: 2012, White, Ford Focus
FF Reputation: 1 immaengineer Good Standing Member
What is the size of that center channel speaker?
immaengineer is offline
Old 08-03-2011, 04:38 AM   #44
Tony407
Tony407's Avatar
Fan#: 85289
I'm not sure. I'll wait after I finish the rest of the install and see how it sounds.
I'm not sure what size the center channel is. I'll try to measure it when I have time.
Tony
Tony407 is offline
Old 08-03-2011, 03:02 PM   #45
kaelumsonofson
Fan#: 88337
What I Drive: 2012 Sterling Gray Focus Ti Hatch
Points 48, Level 1
Points: 48, Level: 1 Points: 48, Level: 1 Points: 48, Level: 1
Level Up 96% Completed
FF Reputation: 1 kaelumsonofson Good Standing Member
Tony, this info (esp. all the pics) is absolutely fabulous...will be a huge help if I decide to mess with my system (once I get my car).
kaelumsonofson is offline
Old 08-03-2011, 04:38 PM   #46
Tony407
Tony407's Avatar
Fan#: 85289
Glad everyone is liking them!! Hopefully they'll be useful to others.
Tony
Tony407 is offline
Old 08-07-2011, 12:53 PM   #47
tvp90
Fan#: 87517
What I Drive: 2012 Grey Focus SEL Sedan
FF Reputation: 1 tvp90 Good Standing Member
Hi Tony,
I am deciding whether or not to get the MFT/Sony system package for my SEL. Which one do you think would have better sound, I get a 6-speaker system and then change the speakers aftermarket (but that's as far as I will go, wont add amp or anything else) vs just the stock Sony system? Thank you very much
tvp90 is offline
Old 08-07-2011, 01:15 PM   #48
Tony407
Tony407's Avatar
Fan#: 85289
Originally Posted by tvp90 View Post
Hi Tony,
Wish I could help. There's a ton of technology in the MFT (when it works) that is worth the upgrade alone, if you have use for it. I can't compare the stock stereo vs. the Sony. If you could get MFT w/o the Sony that might be an option, but I don't think you can do that. This is something that a TON of people on this forum have grappled with. Sorry I can't be more help.
Tony
Tony407 is offline
Old 08-07-2011, 01:19 PM   #49
tvp90
Fan#: 87517
Thanks for replying, Tony.
However, my question is if I get 4 new aftermarket speakers to replace the stock ones, do you think it would be better than sony system?
tvp90 is offline
Old 08-07-2011, 05:29 PM   #50
Tony407
Tony407's Avatar
Fan#: 85289
I found the biggest difference when I disconnected the center channel, which was producing some distorted, shrill high notes. I didn't realize this was the case until I did this, and the results surprised me. Of course, this is fairly subjective.
I did notice a difference in SQ when I replaced the front speakers with the JL Audios, but it was not as pronounced as I thought it would be. I suspect the Sony's system biggest fault lies in amplification and (possibly) equalization. I don't think the Sony speakers are that bad actually, with the center channel being an exception.
I will also make an educated guess and say that changing the sub, or at least providing more power and less (or more) equalization to it will make a huge difference as well.
I realize you're asking a simple question and I'm not really giving you a simple answer. Truth is, what my ears hear (or don't hear) might be different than yours. There are a few others who have swapped the Sony speakers out, I'd love to hear their input as well.
In a nutshell? Maybe. Was it worth the big bucks I spent replacing the Sonys with JL Audios? Not quite yet. Getting rid of the crappy center channel (or maybe it wasn't the speaker per se, but the amplification and/or equalization) was a much bigger improvement - and it was free! What I think will make a huge difference is when I eventually add my own amp(s) to replace the Sony one, in which case I think my JL investment will start to pay off.
Tony
Tony
Tony407 is offline
