Old 07-15-2011, 09:22 PM   #1
macromind
Fan#: 87854
What I Drive: 2012 sterling gray focus
FF Reputation: 1 macromind Good Standing Member
2012 Ford Focus Scheduled Maintenance
While perusing through the owner's manual, I was surprised to learn that in addition having an intelligent oil life monitor that effective extends the intervals between oil changes, the 2012 Ford Focus has no scheduled tune- ups. (at least non that is mentioned in the owner's manual).
Here's what my dealer rep said:
"The intelligent oil-life monitor, monitors your oil and the monitor will go as long as one year or 10,000 miles on the focus. This means that you don't have to change your oil untill 10,000 miles; if you do the oil monitor will let you know.
There is no maitinance schedule for the focus other than the oil changes at 10,000 miles and the spark plug changes at 100,000 miles. That is amazing. Just let me know if there is anything else i can do for you."
Is this correct? Is this pretty standard with new cars today? Nobody has ever mentioned this about the car and I have read through a lot print research before buying. If it it correct, then it would substantially lower the overall cost of ownership, especially over other/ older cars that require such maintenance. Just surprised it's never mentioned as a selling point.
macromind is offline
Old 07-15-2011, 09:36 PM   #2
fla2smoker
fla2smoker's Avatar
Fan#: 87092
What I Drive: 2012, Black, Focus Ti
FF Reputation: 1 fla2smoker Good Standing Member
This is pretty much the standard on vehicles over the past ten years. The only change in the past five years has been towards more synthetic fluids for the drivetrain. They reduce wear and allow the manufacturer to run a lighter weight oil which reduces drag and increases mpg.
fla2smoker is offline
Old 07-15-2011, 11:06 PM   #3
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
What I Drive: 2003 2.0L Grabber Green Zx3
FF Reputation: 45 DrkKnight614 Great Standing Member
Posted via FF Mobile Technically I guess. I would still check my oil once in a while and depending on your driving Id probably still change the oil before 10k, especially if you are in a lot of stop and go traffic or running to the store etc a lot. Keep an eye on other fluids too and obviously tires, and clean battery terminals. The air filter is a no change filter, the transmission is dry, so no fluid there. And your belt is actually a chain. So yes technically a lot of the tune up stuff youd normally do pretty much should last a really long time.
DrkKnight614 is offline
Old 07-16-2011, 01:03 AM   #4
LiquidGreyZX5
LiquidGreyZX5's Avatar
Fan#: 35544
What I Drive: 2012 Ingot Silver Metallic Titanium
FF Reputation: 1 LiquidGreyZX5 Good Standing Member
The automatic is "fill for life" and has a 150k interval as does the manual. You should replace the air filter every 30k. It's all on pg 388 of owner's manual.
LiquidGreyZX5 is offline
Old 07-16-2011, 05:04 AM   #5
cuke2u
cuke2u's Avatar
Fan#: 87358
What I Drive: It's in my sig..
FF Reputation: 2 cuke2u Good Standing Member
Hi, this is our service schedule for the 1.6 ecoboost, I hope this isn't against the forum rules if so mods please delete:
Driving Vehicle into Workshop
Instrument gauges, warning/control lights and
horn
Check operation
Clutch Check operation/adjust, if necessary
Washers, wipers Check operation/adjust, if necessary
Inside Vehicle
Exterior and respective control lights;
instrument cluster illumination
Check operation/condition
Handbrake Check operation/adjust, if necessary
Seat belts, buckles and stalks Check operation/condition
Warning vest Check availability - if applicable
First aid kit Check availability and expiry date - if applicable
Warning triangle Check availability - if applicable
Outside Vehicle
Road (MOT) test Check regarding next road (MOT) test due date - if applicable
Emission test Check regarding next emission test due - if applicable
Under Hood
Wiring, pipes, hoses, oil and fuel feed lines Check for routing, damage, chafing and leaks
Engine, vacuum pump, heater and radiator Check for damage and leaks
Coolant Check anti-freeze concentration: °C
Headlamp alignment Check - adjust alignment, if necessary
Brake fluid Check/top up fluid levels as necessary - in case of abnormal fluid loss, a separate order is
required to investigate and rectify
Under Vehicle
Engine undershield Remove/install engine undershield, if fitted (LTS 21 130 4)
Engine Drain oil and renew oil filter
Steering, suspension linkages, ball joints,
sideshaft joints, gaiters
Check for damage, wear, security and rubber deterioration
Engine, transmission Check for damage and leaks
Pipes, hoses, wiring, oil and fuel feed lines,
exhaust
Underbody Check condition of PVC coating
Tyres Check wear and condition, especially at tyre wall, note tread depth
RF mm, LF mm, LR mm, RR mm
Brake system With wheels on, check brake pads and discs for wear. Check rear brake drums - in case of
abnormal fluid loss, a separate order is required to investigate and rectify. (More often
under severe duty conditions).
Outside Vehicle
Engine Refill engine oil
Tyres Adjust pressure
Instant mobility system Check best before date on tyre sealant - if applicable
Spare wheel Adjust pressure, check wear - condition (note tread depth)
mm
Luggage compartment lamp Check operation - if applicable
Service reminder sticker Affix to driver side B pillar
Interim Service & Convenience Checks
Model Focus 2011
Variant 1.6L ECOBOOST SCTI (01/2011 - )
Interval 1 Years (12500 ml)
Repair/Order No
Reg. No.
Reg. Date
Radio Code
Mileage ml
Outstanding Field Service Actions. Please ensure they are completed.
1U391 - DISCHARGED BATTERY AFTER PARKING
Page 1 of 2
Extended Period Maintenance
Brake system Every 2 years - Renew - brake fluid (LTS 12 154 4)
Air conditioning Every 3 years - Check temperature at the evaporator outlet tube. Check air conditioning
lines for damage and leaks
(LTS 34 619 1) (TSB 67/2002)
Cooling system Every 10 years - Drain, flush and refill with Super Plus
(LTS 24 122 4)
Camshaft drive belt Every 125 000 miles/10 years - Renew (LTS 21 304 9)
Auxiliary drive belts Every 125 000 miles/10 years - Renew (LTS 21 567 5)
Extra Services and Additional Offers * (optional - upon customer request / charged seperately)
Interior filter replacement Odour filter / Odour filter plus - remove and install.
(LTS 34 350 1)
AC maintenance package Air Conditioning (A.C.) system check. Apply A.C. cleaner to air distribution system.
(LTS 54 552 4)
Odour filter plus Upgrade odour filter to odour filter plus (LTS 34 350 1)
Test Drive
Test drive Perform test drive after routine service
Page 2 of 2
Note there is a TSB regarding the fuel pump remaining on and draining the battery, if the problem occurs.
Chris
Mk3 Focus Titanium X, 1.6 Ecoboost 150ps + Bluefin Remap
Candy Red
Appearance Pack
18" 5 Spoke Alloy Wheels
Manual 6-speed gearbox,,,
cuke2u is offline
Old 07-16-2011, 07:07 AM   #6
DrkKnight614
GO Green
Fan#: 14522
Posted via FF Mobile So the air filter is no longer the 100k lifetime filter that the duratecs have had since 05? And fill what? Ive heard seal for life but the transmission is dry, so what fluid to fill?
Old 07-16-2011, 08:39 AM   #7
mysticbluebmw
mysticbluebmw's Avatar
Fan#: 85252
What I Drive: 2013 Accord EX-L V6 w/Navi
FF Reputation: 1 mysticbluebmw Good Standing Member
Posted via FF MobileAnd fill what? Ive heard seal for life but the transmission is dry, so what fluid to fill?
I think it just uses a low friction gear lubricant, but yes, doesn't require any regular maintenance.
**edit**
Owners manual states the use of 1.9 quarts of Motorcraft Dual Clutch transmission fluid. Also service interval is stated to be 150K miles for a fluid and filter change.
2012 Red Candy Focus Titanium Hatch ----RETIRED----
401A Premium /Handling Pkg /Winter Pkg /Park Assist
Navigation / Moonroof
Laguna Seca Pedals
mysticbluebmw is offline
Old 07-16-2011, 10:45 AM   #8
immaengineer
Fan#: 87350
What I Drive: 2012, White, Ford Focus
FF Reputation: 1 immaengineer Good Standing Member
Dry in the case of the transmision doesn't mean no fluid, just less than the typical application.
immaengineer is offline
Old 07-16-2011, 12:01 PM   #9
sterg
Fan#: 86158
What I Drive: 2012 Focuse SE Kona blue
FF Reputation: 1 sterg Good Standing Member
Dry clutch as opposed to a wet clutch. The tranny still has fluid.
I wonder about the timing belt? 75,000?
Steve
2012 Kona Blue SE 5 speed sedan
Sport and Winter package
Moonroof
sterg is offline
Old 07-16-2011, 12:23 PM   #10
fla2smoker
fla2smoker's Avatar
Fan#: 87092
It's a chain.
