Focus at the track, lacking power - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-13-2011, 04:33 PM   #11
chriskobi
chriskobi's Avatar
Fan#: 84901
What I Drive: 2000, bright blue, zx3
FF Reputation: 1 chriskobi Good Standing Member
PS here is a video someone took of me coming around turn 9 I was probably just shifting into 4th after the turn.
http://youtu.be/SY6VemIIb90
Also I really need a new muffler. lol
NW Posse #30
chriskobi is offline
Old 07-13-2011, 06:30 PM   #12
GodLovesUgly
.Flat Out.
GodLovesUgly's Avatar
Fan#: 56705
What I Drive: ^^^ That!
Points 28,599, Level 99
Points: 28,599, Level: 99 Points: 28,599, Level: 99 Points: 28,599, Level: 99
Level Up 16% Completed
FF Reputation: 10 GodLovesUgly Great Standing Member
Buy-Sell-Trade Rating: (7)
You could always try an app called 'Harry's Lap Timer Pro' it works for the iphone and believe Andriods.
it uses the GPS feature of your phone. it actually works pretty good. an alternate to the 500+ data loggers out there.
i've used it a few times and it's amazing the info it can provide.
The Rich Get Richer Until The Poor Get Educated.
Do Vegetarians eat Animal Crackers?
Moderator of Ford Focus Racing Discussions & Rocky Mountain Fanatics
GodLovesUgly is online now
Old 07-13-2011, 07:13 PM   #13
chriskobi
chriskobi's Avatar
Fan#: 84901
Cool, I will check that out. I tried using the Nike + gps on my last run but it was a parade run and mock start. Wish I would have remembered it before that.
Thanks for all the info, good stuff.
NW Posse #30
Old 07-14-2011, 01:57 PM   #14
shlbygt
Fan#: 23315
What I Drive: 04 SVT PWSC EAP
Points 688, Level 13
Points: 688, Level: 13 Points: 688, Level: 13 Points: 688, Level: 13
Level Up 76% Completed
FF Reputation: 5 shlbygt Good Standing Member
From the track map and satellite photo of the track you would need to get as much speed as possible exiting turn 8. A couple of mph there would give a higher top speed towards turn 2 if you could carry the speed through the jogs in the track. Similarly you will need to get out of turn 3B cleanly to make speed towards 5A.
From the videos you were using all of the track at the exit of 8 which is good. If you notice a number of the other cars were not. They were leaving a lot on the table by not finishing off the turn properly.
I tell my students to get on the power as soon and as hard as they can to the point where you wonít need to get out of it.
Most people apply too much throttle too early and too hard, then back out and back on again. It is a real momentum killer, especially in a low horsepower car.
I ask my students if they have taken calculus (see, book learnín ainít all bad after all). Think about the area under a curve. A nice throttle application would be a smooth arc upwards that maximizes both the time the throttle is applied and the amount of throttle. Someone who gets on the throttle a tick later or applies it too soon and has to back off would have a jagged line with spikes and valleys. Less area under the curve.
I run a SVT Focus with Cobalt pads, they are phenomenal. I do much of my ďacceleratingĒ while under braking because the car stops so well.
Most folks starting out do not use their brakes as efficiently as they could. Many back off the throttle, coast down a ways then apply a little brake, then a little more before turn in. Exactly as you would while driving to work approaching a signal light. On track the rules are different.
Keep on the throttle to the braking zone and then get on the brakes hard until turn in. If the car has ABS, find out where the threshold is and get as close to that point as you can before the turn. On a non ABS car it will take a bit more practice.
As for more power, it is nice but wonít necessarily make you faster. I have a friend that I run with at Mosport. He has a SVT with Hoosiers and a Torsen. I have a PWSC SVT with NT01ís and a Torsen. So I have more power but his tires are a little stickier.
When we go out to play I can run him down and pull away at will with my power advantage all day long.
However, he has larger testicles than I.
In turns 1 through 4 he carries way more speed than I am comfortable with. He brakes later and less and gets back on the power a little earlier. He also keeps the car up in the rev band while I tend to short shift.
If we were in identical cars, he would simply pull away from me and it would appear to anyone watching that he had tons more power because of the distance he gains exiting the turns. In a 20-25 minute session he would probably be 3 or 4 turns ahead by the end of the session.
shlbygt is offline
Old 07-14-2011, 04:15 PM   #15
blueovaldave
Fan#: 84022
What I Drive: 2001 Liquid Grey ZX3 S2
FF Reputation: 1 blueovaldave Good Standing Member
Originally Posted by chriskobi View Post
Bluovaldave, As far as cornering you are totally right, it handles really well and when I do it right I can gain lots of distance from the Porsche, Mustangs and Sti's. If I could beat them to the first turn after the long straight I seemed to be ok, If I didn't they would easily pass me. I wish I had someone there to time me. we were all there for classes so in no means was it really competitive.
It is really hard to make it work in the corners if the guys won't "breath" the throttle a little bit to let you go on the straights.
If you are better in the corners and are on a guys ass coming to the straights the proper way to run is the guy let's you go and then the next lap you will stretch out on them.
Most guys ego won't let them do this though and unless you have good corner workers that will help you with passing flags, ect or instructors that pay attention it is hard to do.
2009 EMRA Time Trail Tuner Under Champion
2010 EMRA Time Trail Tuner Over Champion
2001 Ford Focus ZX3 S2 with PWSC 265 whp
blueovaldave is offline
Old 07-15-2011, 02:51 PM   #16
chriskobi
chriskobi's Avatar
Fan#: 84901
What is a PWSC? I tried googling it but got no definitive answer. My best guess is a supercharger of some sort?
Yeah a lot of those guys wouldn't hold back and I don't blame them, I actually like the turns more than the straights I like the technical aspects of them. I've actually heard that Pacific raceways is probably one of the most technical courses around hear, with all the elevation changes and turns. I really hope to get to go out there and play more and learn as much as possible. I have started the process in getting my novice license now I just need to get a car prepped for racing or rent one. The original goal was to have the car built for Group 2 rally and just rally but I need to do something in between rally so I figure circuit racing would be a good choice since the operate year round. It may be a pain in the ass but I figure I could use the car as a dual purpose car. I figure id have to change out the suspension and wheels and I could get by. The cage is my biggest hurtle at the moment. I'm not sure if its the wisest plan. I have been looking at the Pro3's they seem fun and very cost effective to race on a budget.
NW Posse #30
Old 07-15-2011, 05:53 PM   #17
GodLovesUgly
.Flat Out.
Fan#: 56705
Correct, it's a PowerWorksSuperCharger
i would just pick up a beater hatch for rally, then build it for rally only. less of a headache. plus Rally beats up the car pretty bad, i'm not sure if i'd want to rally a car then take it on the track where speeds can reach the triple digits..
Old 07-18-2011, 02:16 PM   #18
chriskobi
chriskobi's Avatar
Fan#: 84901
You have a good point there. I have been looking at the costs of building a rally car and comparing that to a used older rally car. I have seen used ones (group 2) from 4000. on up. cost of a cage is starting around 3500. then I would need seats, belts, electronics, suspension. I'm sure there are more but that's just a few. So yeah It would make way more sense for me to buy a used one probably save half the dollars and headache.
NW Posse #30
Old 07-19-2011, 04:11 PM   #19
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,570, Level 100
Points: 52,570, Level: 100 Points: 52,570, Level: 100 Points: 52,570, Level: 100
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
A good way to add 20-30HP is a SVT header , 2.5 exh , drop in filter , TB and a tune would net you a good 20+ HP to the wheels and you will be surprised what it will do on the track , a lot of this you can find used here on FF
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 07-19-2011, 04:50 PM   #20
chriskobi
chriskobi's Avatar
Fan#: 84901
Tom
been keeping an eye out for the SVT header right now I have a OBX header in it (came with the car, not sure if its any good or not) http://www.obxracingsports.com/products.php?pk=905
I have a 2.5 exhaust in it (came with it) I'm going to get a new muffler because this one sounds horrible at high RPMs not natural sounding at all.
I do plan on getting new TB and tune but also want to get new camshafts and valves, but not sure what order to do it in. I imagine the tune will be last, at least it makes sense. I also want new wheels but that comes in the "looks" category.
NW Posse #30
