Will i throw a CEL code if i take my passanger seat out? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus SVT > SVT Interior Mods & Upgrades
SVT Interior Mods & Upgrades The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the 2002-204 SVT Focus.
Old 04-26-2011, 07:44 PM   #1
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,075, Level 72
Points: 12,075, Level: 72 Points: 12,075, Level: 72 Points: 12,075, Level: 72
Level Up 7% Completed
I want to recover the seats so i thought ide start with the passanger seat that way i could still drive it around while i take time to redo it.
How do i bypass all the switches and stuff? or will it be ok just leaving it unhooked?
2 leads from the buckle, a 2 wire and a 3 wire. The 2 wire goes over to the large plug going to the ECU i think. The second set goes into the brown plug which runs into the pressure switch under the cushion.
This is the 2 wires which look like they go into the latch
WHy the other set runs into the latch i dont quite understand. It looks as if its connected to the belt which the latch is strapped to.
BowerR64 is offline
Old 04-27-2011, 11:06 PM   #2
BowerR64
BowerR64's Avatar
Fan#: 78699
Well it threw an airbag light i guess because it wasnt hooked up. Looks like its just an air type of pressure switch or somthing.
I bought a torx set from sears, its a 3 bit set for a 3/8 drive came with 40-45 and 50.
Its good because you can really crank on the ratchet. Some of them are in pretty good and i had to use a 1/2" drive extension.
Once you bust em loose you can use a flat head to spin em out the rest of the way. You could use a flat head to get em out to if you were good.
While i had em out i tried to clean the carpet good. Its kinda hard to get down inbetween the seats with them in.
BowerR64 is offline
Old 04-27-2011, 11:09 PM   #3
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,649, Level 94
Points: 23,649, Level: 94 Points: 23,649, Level: 94 Points: 23,649, Level: 94
Level Up 30% Completed
Forum Activity 16%
ah sorry I didn't see this...... yeah it will just throw an airbag light (at the moment you don't have airbags either..) If you're not putting another seat in there, remove pressure sensor and seat belt sensor from their modules. The little square connectors ARE separable, though it may take some work. and make sure you know which ones they go to.
edit: I looked at your post again to make sure.... yeah no it's going back in. lol. just don't, um get in an accident?
mikebontoft is online now
Old 04-27-2011, 11:16 PM   #4
Broncoboy80
#MattinglyBuilt
Broncoboy80's Avatar
Fan#: 59885
What I Drive: Stanced 02 SVT
FF Reputation: 13 Broncoboy80 Great Standing Member
Buy-Sell-Trade Rating: (8)
My airbag light wont go off. Does anyone know how to turn it off? I put the st seats in the car and since then the light stayed on
CREATOR OF THE CLEANEST FOCI's
Instagram - #MattinglyBuilt
Originally Posted by HaveBlue83 View Post
^yo, that bitch is LOW and clean!
Broncoboy80 is offline
Old 04-27-2011, 11:29 PM   #5
BowerR64
BowerR64's Avatar
Fan#: 78699
Do my seats have a side airbag? I didnt think they did but im not sure. There is nothing on the side like the SVT seats that say they do.
These parts just look like some kind of vacum switch to detect if anyone is in the seat. If i set my wheelchair frame into the passanger seat it turns the airbag off. Or even my tool bag turns it off. Not sure how much weight it needs to turn it on.
You might search the numbers on that module to see if you can find anything.
BowerR64 is offline
Old 04-28-2011, 12:08 AM   #6
UnbridledCarnage
Rhinoliner!!!
UnbridledCarnage's Avatar
Fan#: 66551
What I Drive: 03 Rhinoliner'd ZX3 AdvanceTrac
Points 16,266, Level 81
Points: 16,266, Level: 81 Points: 16,266, Level: 81 Points: 16,266, Level: 81
Level Up 84% Completed
FF Reputation: 9 UnbridledCarnage Good Standing Member
take apart ur gauges and unplug/cover up the airbag light. problem solved
If your local to the 502, 270, 812, 606, 859 area, check out FocusXtreme, the Ohio Valley chapter of FF. Monthly meets and kickass people! Join and POST UP!!!
UnbridledCarnage is offline
