ECU Tuning Chat Discuss performance tuning options for your Ford Focus.
#1 | ||||
If i pull the fuse will the engine light go out?
Today i put in my wideband sensor to the bottom bung (the third one)
![]() ![]() I wired the module (innovate LC-1) into the fuse box under the hood for power but when i drove it i notice its not reading quite right. I may need to replace the sensor or rewire it to a different power source. When i look in the manual i see a fuse for "HEGO sensors" it says (Heated exhaust gas oxygen) what if i pull that fuse? is that for all the sensors maybe? Im sure its not that easy but it never hurts to ask. ![]() ![]()
DX3?.. huh?.. well ZX3 = Zetec the 05-07 has a Duratec so DX3 |
Remove Advertisements |
#2 | ||||
Gets more V8
nope that just gives it more of a chance to stay ON. can you read the codes?
SR #127 | '02 Focus SE "Foci" (5.0 in progress) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-selling) | '94 Toyota 4Runner SR5 "Roach" (daily-stockish) Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics |
#3 | ||||
The engine codes? I just put it on today and it came on instantly after i unhooked the stock one and started it up. Im sure thats what the CEL is from.
#4 | ||||
Gets more V8
yeah I thought of that after I posted and left the thread. well.... hook up a cheater to it or something just so it's hooked up. may not even need to do that. I (sadly) had an 02 sensor wrapped around a harness for a few days so I could still drive the car and didn't get a light
#5 | ||||
has a screw loose
This should stop the CEL until you get a tune . I did it after I installed my header and not once did I get the CEL until I put my Wideband in and then I got a tune update and now no more CEL .
But this should do the trick for you , I know you don't have a header but it would be worth a try . http://www.focusfanatics.com/forum/showthread.php?t=161467
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21 February 2012 Sedan of The Month Last edited by FocusedSlayer; 03-20-2011 at 12:03 AM. Reason: added info |
#6 | ||||
The wideband comes with its own 02 sensor, i used the #3 bung and took out the stock 02 in the #3 location and just unplugged it. Thats why its throwing the CEL because its reading nothing at that location. I need to try and trick it with the LC-1 it has an analog out with a selectable voltage output to trick the ECU into thinking its there but i wanted to ask about that fuse first. I knew it wasnt that easy but thought ide ask. I need to find out what lead the stock 02 uses and tap into it. I believe its +12, -12 (for the heater) and signal + and signal ground to the ECU
