HOW TO: Intermittent Wiper Problem Fix. AKA TSB Fix. - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-18-2011, 05:45 PM   #51
sloth163
Fan#: 38092
What I Drive: 03 CD Silver ZX3
FF Reputation: 1 sloth163 Good Standing Member
sorry for bumping an old thread...i changed out the relay but my front wipers still don't park like they should. what else could be the problem?
sloth163 is offline
Old 03-17-2011, 04:45 PM   #52
19COBRA93
19COBRA93's Avatar
Fan#: 84093
What I Drive: 2003 DSG ZX3
FF Reputation: 2 19COBRA93 Good Standing Member
Originally Posted by mmcclusk2 View Post
BTW, the part number I got from my Ford Dealership is the following:
F57B-14B192-AA
I assume it's a replacement for the F5TZ-14N089-B mentioned above.
My cost was $13.
Originally Posted by GB904150 View Post
Hi,
MMCCLUSK2 gives p/n
F57B-14B192-AA
David
F5TZ-14N089-B and F57B-14B192-AA are the exact same relay. The F57B number is just the engineering number Ford uses on the actual part. The F5TZ number is the actual part number we Ford parts guys use.
So to clarify; F57B-14B192-AA will be on the actual part. The bag it comes in, or the invoice you're billed on through the Ford dealer will be F5TZ-14N089-B. They're the same exact thing, both numbers cross right over to the other. If that makes sense.
Hope that helps. And my ZX3 is having the same problem.
2003 DSG ZX3, Mostly stock.
2005 Mustang GT, Forged, Procharger F1C.
1985 ASC McLaren Capri, 347 stroker.
19COBRA93 is offline
Old 10-26-2011, 05:44 PM   #53
Bobbr
Bobbr's Avatar
Fan#: 71712
What I Drive: 2003 Yellow Ford Focus SVT w/EAP
FF Reputation: 1 Bobbr Good Standing Member
Awesome "how to." Saved me a LOT of time by having me avoid the task of tracing where the problem was in the first place. One thing I will add is that I did NOT have to remove any of the lower dash! I just pulled off the fuse box cover, used extensions on my socket wrench to remove the two fuse block bolts, and released the tabs to drop the fuse block down. I don't think I spent more than ten minutes, start to finish.
THANKS!
Bobb Coatesville, PA USA
2003 Ford Focus SVT EAP: Chrome Yellow ~ Silver Argent 'Euro' Wheels ~ HIDs ~ Michelin Pilot Sport A/S
Also: 1980 Fiat X1/9, 1986 Bertone X1/9, 1979 Fiat X1/9, 2012 Fiat ABARTH, 2000 Ford Ranger XLT
Bobbr is offline
Old 11-14-2011, 09:35 PM   #54
5alarm
Fan#: 91632
What I Drive: 2003 Beige SE Wagon
FF Reputation: 1 5alarm Good Standing Member
Just to clarify, are the relays identical for front and rear? Are the R18 and R19 the very same part number listed above?
Thanks and pardon me if I missed it earlier.
** Edit ** Yes they are indeed identical. Try simply swapping the Front and Rear relay (assuming you don't have the single combined unit) before you go get a relay. Very easy and quick to test!
5alarm is offline
Old 11-15-2011, 12:31 PM   #55
5alarm
Fan#: 91632
Originally Posted by andyandlexi View Post
I just swapped over the rear and front wiper relays and this cured the wiper parking fault on the front without transferring any fault to the rear. (maybe a loose relay in the first place?) It's worth a try before buying a new one!
Andy, thanks for the AWESOME info. Didn't even have to go get a relay. The installed spare (rear relay) was already there!
Was very easy to access on my 03 Wagon through the access hole and 7mm with extension.
Would've only taken 5-10 mins, but of course Mr. Murphy appeared. When I was replacing one of the 7mm bolts, I bobbled it and it disappeared into a never never land pocket on the back side of the lower dash plate next to the OBD plug.
Thought about leaving it there, but I HATE RATTLES and figured I might be able to extract it with a magnet. 5 mins later and the magnet worked charms.
THANK YOU everyone for all the info posts and updates. This site rules!
5alarm is offline
Old 11-15-2011, 02:03 PM   #56
Gerry05
Fan#: 64429
What I Drive: 2005 Focus Wagon
FF Reputation: 1 Gerry05 Good Standing Member
focus wipers
i have a2005 ford focus wagon iam having trouble with my wipers .their,s only one speed working and that is high. please i need help[
Gerry05 is offline
Old 11-15-2011, 02:06 PM   #57
Peregrine
I.S.A.I.K.I.
Peregrine's Avatar
Fan#: 6009
What I Drive: '03 CD Silver SVT, '11 Mazda CX-9
FF Reputation: 112 Peregrine Excellent Standing Member Peregrine Excellent Standing Member
Buy-Sell-Trade Rating: (23)
Not trying to sound like a jerk, but you might want to go back and reread the first post and try swapping out your relay first.
Peregrine is offline
Old 11-15-2011, 02:17 PM   #58
Gerry05
Fan#: 64429
but if relay is gone why is low not working but high speed is .
Gerry05 is offline
Old 11-15-2011, 02:25 PM   #59
Peregrine
I.S.A.I.K.I.
Peregrine's Avatar
Fan#: 6009
Dunno, but I would start with the cheapest part to replace first (which would be the relay).
Old 11-15-2011, 08:10 PM   #60
Gerry05
Fan#: 64429
thanks for your help makes sense will try this i will let you know how i make out with it
Gerry05 is offline
Similar Threads
New sympton with an old problem that no one can fix.. kndlz28 General Technical Chat 8 05-15-2007 09:11 AM
Windshield Wiper problem KMiller General Technical Chat 10 01-28-2005 12:31 AM
rear window wiper problem Focus2000 Ford Focus & General Car Chat 6 11-27-2004 03:30 AM
Problem: Indiglo gauges not lighting up. Anyone know how to fix this? thrill5one6 MK1 Interior Mods & Upgrades 9 09-17-2004 07:04 AM
Rear Windshield Wiper Problem (HELP!) Seb656 Ford Focus & General Car Chat 15 03-25-2004 12:01 PM
