How to diagnose cruise control problems. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-15-2011, 04:09 PM   #1
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
Points 2,624, Level 31
Points: 2,624, Level: 31 Points: 2,624, Level: 31 Points: 2,624, Level: 31
Level Up 16% Completed
I just had some issues with my CC and have sorted that out, but I found there is a really slick self diagnostic procedure for the cruise control. You don't need a diagnostic scanner to do this either, just the car. From what you describe I think the cruise control servo (motor with a spool of cable that controls the throttle body for CC) is bad, but this test will tell you for sure where the problem lies. This self diagnostic test will work on all Foci from 00-05, in addition to many other Ford models in those years.
The test is basically this: you're going to be turning the ignition key on and off repeatedly and then hitting the cruise control buttons quickly in a specific sequence, and then the cruise control light will blink repeatedly, and the number of blinks tells you where the fault is. It's easy to do once you get it sorted in your head and you won't mess anything up if you don't get it right the first time.
If it's a manual, don't depress the clutch. If it's an automatic leave it in park. First, turn the ignition to the accessory/run position but don't start it. Press and hold the CC off switch and then repeatedly turn the ignition from run to off and back to run again, you should do this 3 or 4 times. End this sequence with the ignition in the run position and then let go of the off switch, and you should see your CC light blink once, which means it's ready to run the self diagnostic. If it flashes 5 times at this point then it's a faulty speed control module, which is that servo I mentioned above. Quickly after the light blinks (like a second after), you then need to hit the other cruise control buttons in this order, and you will need to hit them fairly quickly for the test to proceed:
1. On
2. Resume
3. Coast
4. Set/accel
The CC light should blink once after each button you hit. Kind of take your time hitting the buttons and it's easier to keep track of the flashes, which is important at the end because you need to count the number of flashes that come after you hit "set". There won't be an immediate flash after you hit "set", there will be a slight delay, and then will come another short series of flashes. This next part is all verbatim (except for the parenthesis) from the Ford guide I'm translating here.
0 Flashes (no flash after last button is pushed): suspect circuitry or speed control steering wheel switches.
1 Flash: Static test passed (cruise control should work)
2 Flashes: BPP (brake pedal position) switch is damaged, circuit is damaged, or the brake or clutch pedal was applied during test.
3 Flashes: Brake deactivation switch is open or circuit is damaged.
4 Flashes: Indicates the speed signal circuit is open or damaged (wheel speed sensors, ETC)
5 Flashes: Suspect circuitry or module.
So I guess try to run the test. It's pretty quick and easy once your thumbs get the button sequence down. Then you should at least have a better idea where the problem is coming from. Post back here with results, I'm curious where the problem is for you. Mine was the brake deactivation switch which I'm putting in soon.
6SPD_soul is online now
Old 03-25-2013, 05:32 PM   #2
driver36@mts.net
Fan#: 111475
What I Drive: 2009 red ford focus
FF Reputation: 1 driver36@mts.net Good Standing Member
Thanks i will give that a try.
driver36@mts.net is offline
Old 07-29-2013, 01:14 PM   #3
desertrider
Fan#: 117290
What I Drive: 2005 white ZXW
Points 5, Level 1
Points: 5, Level: 1 Points: 5, Level: 1 Points: 5, Level: 1
Level Up 9% Completed
FF Reputation: 1 desertrider Good Standing Member
Thanks very much for the diagnostic test. I'll run it and report back the results.
LATER THE SAME DAY - OK, I tried various ways to get the Cruise Control to operate and it will not do so. No indication on the dashboard nor any part of operation (set, reset, coast, etc.)
Last edited by desertrider; 07-30-2013 at 12:15 AM. Reason: Tried to perform the diagnostic test - won't turn on..
desertrider is offline
Old 07-31-2013, 01:22 PM   #4
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 520, Level 10
Points: 520, Level: 10 Points: 520, Level: 10 Points: 520, Level: 10
Level Up 40% Completed
Forum Activity 10%
FF Reputation: 1 Leora83 Good Standing Member
Beautiful! Thanks for a detailed informative description.
Brake pedal position switch, btw.
Many thanks!
Leora83 is offline
Old 08-20-2013, 02:48 PM   #5
meldav72
Fan#: 118017
What I Drive: 2012 Red Focus
FF Reputation: 1 meldav72 Good Standing Member
Do you think this would work on a 2012? I bought the car used in June, and I have used the CC but tried to use it this past weekend and nothing...
meldav72 is offline
Old 09-11-2013, 08:20 PM   #6
clownymb
clownymb's Avatar
Fan#: 116722
What I Drive: 2003 Silver SVT
FF Reputation: 1 clownymb Good Standing Member
Mine seems to be the BPP. Now I just have to go and figure out what that is. Haha. Thanks for posting this guide. Really helpful. Also, I found that at least on my car, I just held down the off switch and turned the car on once. Didn't have to do the on/off multiple times thing.
clownymb is offline
Old 09-11-2013, 09:16 PM   #7
meldav72
Fan#: 118017
Auxiliary preventing cc from working
I discovered on mine that for whatever weird reason, having my mp3 player plugged in in the Auxiliary input located in the glove compartment caused my cruise control not to work. I unplug the mp3 player and it works fine.
meldav72 is offline
Old 09-12-2013, 09:26 AM   #8
FordService
FordService's Avatar
Points 3,482, Level 36
Points: 3,482, Level: 36 Points: 3,482, Level: 36 Points: 3,482, Level: 36
Level Up 88% Completed
Forum Activity 27%
Hi meldav72,
I recommend making an appointment at your dealership so they can take a look. Once you get a diagnosis, shoot me a PM if you need any additional assistance; be sure to include your name, phone number, VIN, mileage, and preferred servicing dealership in your message.
Crystal
FordService is offline
Old 10-17-2013, 05:31 PM   #9
driver36@mts.net
Fan#: 111475
thanks for that but ford just diagnosed the throttle body as the problem any one else have a throttle body problem
Old 01-19-2014, 01:26 AM   #10
RSVT170
FocusRush
RSVT170's Avatar
Fan#: 28451
What I Drive: '13 ST2 & '05 ZXW
Points 15,294, Level 79
Points: 15,294, Level: 79 Points: 15,294, Level: 79 Points: 15,294, Level: 79
Level Up 89% Completed
FF Reputation: 42 RSVT170 Great Standing Member
Buy-Sell-Trade Rating: (13)
Just saw this thread! Mine and my roomate's Hatches both have non-functioning CCs. I'm going to do this right now on both!
HATCH NATION #139 | 2013 ST2 "P5" | 2004 SVT EAP "P9" | FocusRush.com
RSVT170 is offline
