How To Make Your Own Wiring Harness For Fog Lights - Page 3 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > MK1 Focus
Old 02-09-2011, 03:11 PM   #21
FuhFuh Focus
Stuff about Florida
FuhFuh Focus's Avatar
Fan#: 67230
What I Drive: 2002 Mazda Protegé ES
FF Reputation: 7 FuhFuh Focus Good Standing Member
How many pins did your relay have, 4? Also what is it plugging in to?
Shown here:
Originally Posted by norcalfocus01 View Post
FuhFuh Focus is offline
Old 02-09-2011, 07:19 PM   #22
norcalfocus01
Fan#: 55603
What I Drive: White N Gold 2001 Sedan
FF Reputation: 132 norcalfocus01 Excellent Standing Membernorcalfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Yeah there's for pins and its plugged into the relay.
norcalfocus01 is offline
Old 02-09-2011, 08:04 PM   #23
FuhFuh Focus
Stuff about Florida
Fan#: 67230
Ok cool.
But sorry im still confused a little, is the inline fuse thing plugging into the relay?
Electrical stuff really confuses me =/
Old 02-12-2011, 05:21 PM   #24
FuhFuh Focus
Stuff about Florida
Fan#: 67230
Ok got it all figured out, it was really easy actually, almost plug and play.
I just have one more thing to do, which is put a wire to pin 83b on the oem headlight switch. What kind of connector did yall use to do this? I dont have one small enough.
Old 02-12-2011, 05:26 PM   #25
norcalfocus01
Fan#: 55603
Isn't there a wire already coming out of 83b? If so just strip about a 1/8" of the plastic off the wire, wrap the bare end of your wire around it, and electrical tape it up.
Old 02-12-2011, 08:03 PM   #26
FuhFuh Focus
Stuff about Florida
Fan#: 67230
Nope there wasnt a wire coming off of mine.
I can try and get a pic tomorrow.
Old 02-13-2011, 12:07 AM   #27
milkweed
Fan#: 40906
What I Drive: 2007 ford focus zx3 red
FF Reputation: 1 milkweed Good Standing Member
see this is where i am stuck at too, i have the OEM, Fog lights, the surrounds, the OEM switch, and the wiring harness. which the harness is not OEM. i have everything routed and it's grounded but i don't have it hooked up to the battery yet, cause i am trying to figure out where the female interface for the male pin 83b leads to, so i can connect it to the switched input on the relay. do i have to drill through the firewall or route it through a grommet that leads to the wiring for the light switch? if our cars are not prewired for fog lights, is there even a line that leads from the light switch on the female receptacle for pin 83b? if there is a line, does it route to a fuse box inside the car or in the engine bay?
milkweed is offline
Old 02-13-2011, 12:23 AM   #28
norcalfocus01
Fan#: 55603
Duh I just re-read your question and the part about 83b. I didn't connect to a OEM fog light switch, but I would say you should be able to get a female slip connector to fit on that pin.
You can either...
go through the fire wall, which there are holes already there to slide the one wire through.
or go behind the fender and through the plastic plug in the door jamb.
Old 02-13-2011, 01:40 PM   #29
FuhFuh Focus
Stuff about Florida
Fan#: 67230
Alright i found connectors that fit on the pin. Only problem is they dont fit through the harness.
So when i plug it into the back of the switch it cant connect all the way.
Old 02-14-2011, 01:21 AM   #30
norcalfocus01
Fan#: 55603
You got any extra harnesses laying around? You can pull apart the harness and get the plug and then wire it into your harness.
I sent a PM to Mr.B to help you out as I didn't do it this way so Im a little lost.
