SuperTech 85.5 Low Compression Zetec Piston OVERSTOCK SALE!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Exclusive Vendor Discussions > Massive Speed
Massive Speed Discuss about forced induction upgrades and performance tuning for your Ford Focus.
Sponsored By: Massive Speed
Old 02-09-2011, 07:00 PM   #1
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Points 16,188, Level 81
Points: 16,188, Level: 81 Points: 16,188, Level: 81 Points: 16,188, Level: 81
Level Up 68% Completed
Buy-Sell-Trade Rating: (19)
Massive Speed's EXCLUSIVE custom line of Zetec forged pistons already possess an unreal blend of quality, performance and value.
But.
We are currently OVER stocked on the 85.5mm (~.027" over) sized 8.7:1 compression variety. For a limited time, take $28 off our already outstanding prices: a FULL SET of 4 forged pistons, rings, pins and locks for only $409!!! You'll ALSO get a limited edition calabo "Forged" Massive/SuperTech shirt!!! ONLY buyers of these pistons during this special promotion can get this shirt, so don't ask otherwise!!!
This is ONLY while supplies last. Premium 6.1 oz cotton black T with low down full custom Massive/Forged/SuperTech roll call in purple.
Use coupon code: Forged
exactly as it appears above.
Find em Here
Here's a little about them:
Genuine SuperTech / Massive Speed Bespoke Forged Pistons, Moly Ring Set, and wrist pins. Another MASSIVE EXCLUSIVE DESIGN!!! Install in place of the stock cast pistons, one of the weak areas in the Zetec engines. DONT expect to run anything over 250 flywheel horsepower with stock pistons. Pistons are manufactured from extruded high silicon, enhanced 4032 alloy (with additional Cu, Ni & Mg) that has low thermal expansion, excellent wear resistance and higher thermal conductivity. SuperTech pistons with this alloy have withstood up to 42psi of turbo boost, with alcohol, without any problems. Several heat treatments provide the piston with a high tensile strength and evenly distributed hardness. The pistons are submitted to several machining steps in specially designed machines and in conventional CNC machines with special diamond tools for dimensional precision, perpendicularity and flatness of the ring grooves. Contact reduction grooves are standard. Honed & reamed pin bores for precise fit. Wrist pins are constructed of cold extruded chrome moly steel for high strength to be used with wire clip locks. A 2 or 3 forging steps process yields a fine structural grain oriented in fibers in the same direction of the stresses. Finally a “phosphate dry lubricant” coating is applied to protect the rings against “micro welding” and enhance lubrication on the skirt/cylinder area. Piston Rings are manufactured in Japan with the latest technology for high performance applications. Quality Control is performed after every step of the manufacturing process in climate controlled environments to ensure reliability of dimensions. Installation is best left to a professional. You’ll need serious automotive knowledge and specialized tools to complete this job. Available in multiple compression ratios, choose below.
  • Forged of extruded high silicon enhanced 4032 alloy
  • The lightest weight Zetec pistons on the market today – a ful 1.5oz’s versus the competition for quick revs and power.
  • Tight piston to wall clearance design for better ring seal.
  • Fully CNC machined domes and valve reliefs for perfect fit.
  • Radial Anti Detonation Grooves reduce detonation by clipping pressure spikes.
  • Slipper style skirts for the higher compression set results in less drag for faster revs, full round for low comp to eliminate pistons slap in boosted applications
  • Full floating lightweight wrist pins and double spiro locks for durability.
  • Narrow piston rings for the ultimate in power.
K Dog is offline
Old 02-10-2011, 09:24 AM   #2
hypnoticracing
Fan#: 51709
What I Drive: 2003 Focus Sedan Zetec 5 Spd
FF Reputation: 13 hypnoticracing Great Standing Member
very very nice price!
03 SE Liquid Grey zetec 5 spd
07 F150 FX2 Sport, White
Parting out the slammed sedan...
hypnoticracing is offline
