Replacing air box with K&N air filter. HELP - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-10-2009, 03:55 PM   #11
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
> Could the 'lifetime' engine air filter be the problem at 40,000 miles?
Check the sensor which will tell you if the filter is restricting. If it's in the green, no problem.
penguin is offline
Old 08-10-2009, 07:33 PM   #12
MaroonZX3
Fan#: 49579
What I Drive: 2003 Red ZX3
FF Reputation: 12 MaroonZX3 Great Standing Member
Originally Posted by mikebontoft View Post
I just left the lower box on. That way I still have the useless air snorkel on it as well as not having to bother with a breather valve filter
That is a good idea, and the air snorkel may not be as useless as you think. It does bring in some cool air. Especially if you swap in an SVT snorkel.
MaroonZX3 is offline
Old 12-08-2010, 09:33 AM   #13
A Psycho Martyr
Fan#: 81018
What I Drive: 2003 Frosty White Pontiac Vibe
FF Reputation: 1 A Psycho Martyr Good Standing Member
I registered here because after MUCH google-ing I couldn't find a specific answer this SAME question pertaining to my Pontiac Vibe.
I just insalled a SRI on my car and when the crankshaft vent tube is plugged into my new intake, the engine stalls within 2 seconds of starting it. When left unplugged...I have a rough idle and a sporadic hissing noise, but it stays running fine and I got a pretty successful test drive. Then I tried plugging it and the idle is perfect and the car still runs great.
Is it ok to leave this plugged? or should I just put a little filter on it like what Mr. Bergner has done with his? Or is this expected with a Short Ram Intake while the MAF sensor adjusts to the new airflow?
Please pardon my ignorance, as this is my 1st venture into any kind of performance mod.
A Psycho Martyr is offline
Old 12-08-2010, 11:03 AM   #14
Elder
Points 13,378, Level 75
Points: 13,378, Level: 75 Points: 13,378, Level: 75 Points: 13,378, Level: 75
Level Up 32% Completed
Posted via FF MobileCan`t see what kind of car, what SRI, or which hose you are plugging in where from here. General info - never plug a crankcase ventilation tube! Worst case, if it`s sealed REAL good is that engine seals blow out & you neeed a rebuild just to replace them...... Installed in the same order as stock, with hoses in the same relationship to filter, MAF, and throttle body as they were originally is best - other options defeat part of the emissions system, and except for some extreme race & turbo applications do NOT increase performance... Pulling the battery negative for a bit to reset the computer so it can learn the new setup quicker is recommended for any change that effects the breathing of the engine, even if a relatively minor change... Hope this helps, get back with more info/questions & the members here will try to help out....
sailor is offline
Old 12-08-2010, 02:39 PM   #15
A Psycho Martyr
Fan#: 81018
ok. I'll get back to you with pics later today. Thanks
Old 01-09-2011, 01:52 PM   #16
FuhFuh Focus
Stuff about Florida
FuhFuh Focus's Avatar
Fan#: 67230
What I Drive: 2002 Mazda Protegé ES
FF Reputation: 7 FuhFuh Focus Good Standing Member
Where did you guys buy the breather filter that goes on the valve cover?
FuhFuh Focus is offline
Old 02-07-2013, 10:16 PM   #17
kensaysrawr
Fan#: 107068
What I Drive: 2003 Pitch Black Focus ZX3 Hatch
Points 172, Level 3
Points: 172, Level: 3 Points: 172, Level: 3 Points: 172, Level: 3
Level Up 44% Completed
FF Reputation: 1 kensaysrawr Good Standing Member
Anywhere. autozone or advance auto parts have them for about $8 in various colors
kensaysrawr is offline
Similar Threads
03 ZX3 air Filter box with snorkel and K&N filter with amber turn signals Poney Archive 12 03-10-2009 12:08 AM
Amsoil Dual Remote By-Pass Filter Installation S2 General Technical Chat 0 10-01-2008 06:05 PM
K&N air filter cleaning StealthGray Ford Focus & General Car Chat 5 02-13-2008 12:31 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
K&N Air Filter drooler General Technical Chat 19 03-31-2005 06:24 PM
