what's this metal tube? - Ford Focus Forum, Ford Focus ST Forum
Old 01-08-2011, 02:56 PM   #1
loveQQ
Fan#: 26398
What I Drive: 2000 focus zetec
FF Reputation: 1 loveQQ Good Standing Member
Focus zetec engine, the metal tube horizontal and parallel to the longer side of engine valve cover, it's above the exhaust manifold.
From the image i linked, you can see it clearly it's the painted black metal tube.
there is a small leak, how can i fix it?
thanks!
loveQQ is offline
Old 01-08-2011, 03:03 PM   #2
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
That would be the power steering line, And does your steering feel weird? And where is the hole cause if it's in the metal that runs over the heat shield there? You will have to replace the line.
Welcome to FF, your engine bay is very clean for a 2000, just take the fire wall blanket off on the back there.
Dj
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 01-08-2011, 03:06 PM   #3
loveQQ
Fan#: 26398
thanks a lot for the quick answer, I guessed so, but is there an easy way that I can fix the leak or change the tube by myself?
loveQQ is offline
Old 01-08-2011, 03:11 PM   #4
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
Yea of course you can do the job yourself, and no there is no way to close the hole, the power steering line there is under pressure.
So changing it yourself, rating it from a 1-10 scale...? it's about a 4, I personally think the hardest part is unhooking it from the bottom of the power steering pump. That nut on the bottom can be hard to get at, it might be easier to take the power steering pump out to get to that nut.
Do you have a Haynes manual for the car to help when taking it apart?
HN #17
D23 crew-#1
Djzx3 is offline
Old 01-08-2011, 03:24 PM   #5
loveQQ
Fan#: 26398
no, i don't have the Haynes manual, but i have checked the power steering system diagram. I need to get the part first.
loveQQ is offline
Old 01-08-2011, 04:05 PM   #6
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 04 Red/Black ZX5, 00 infared ZTS
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (7)
the nut is the hardest part if the line doesn't break off in the fitting on the rack. i would soak everything a day before in penetrating fluid.
Mike_Mac is offline
Old 01-08-2011, 04:16 PM   #7
Obocecha
Obocecha's Avatar
Fan#: 28484
What I Drive: 2002 Yellow ZX3
FF Reputation: 15 Obocecha Great Standing Member
Buy-Sell-Trade Rating: (9)
If you take your passenger side headlight out it's really easy to get at the nut on the pump. The other one isn't hard to get to but make sure to soak it in oil and use a flare nut wrench. Don't be tempted to use a regular wrench on it and risk rounding it off.
'02 Yellow ZX3
'85 Supra 6M-GTE
Obocecha is offline
Old 01-08-2011, 04:38 PM   #8
loveQQ
Fan#: 26398
Thanks for all the answers and tips, I'll give it a try next week OR I have to take it to a shop.
BTW, that picture I LINKED is not from my car, I steal the picture from internet search. The engine bay of mine is much dirtier, plus this power steering line leakage makes it look like a mess.
loveQQ is offline
Old 01-08-2011, 11:06 PM   #9
0352marine
0352marine's Avatar
Fan#: 81199
What I Drive: 2000 blue zts
FF Reputation: 2 0352marine Good Standing Member
Dj
If it's in the metal tube you can fix it if you have a welder and some experiance. Or if you have a torch and a metal hanger you can braze it.
2000 zts, automatic, accel super coil, 8.2mm taylor wires, short ram air intake, custom full length header, Tom's tune, Drilled and slotted rotors, indiglo gauges, HID headlights.
0352marine is offline
Old 10-20-2012, 08:50 PM   #10
total_telecom
Fan#: 83049
What I Drive: 2004 se wagon 2.0L
FF Reputation: 1 total_telecom Good Standing Member
Mines Freaking leaking too! So one end of this starts at the pump and the routes around the engine compartment to the rack?
Looks like a major PITA!
total_telecom is offline
