How-To: 2008 - 2011 Halo Projectors Light Installation - Page 15 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Second Generation > MK2 Focus
Old 12-14-2010, 05:02 PM   #141
2011 SE
2011 SE's Avatar
Fan#: 80951
What I Drive: 2011 SE
FF Reputation: 8 2011 SE Good Standing Member
Interesting. With mine the only connection problem I thought I had was between the bulb and the adapter, not the adapter and the stock connector (sorry if those terms were unclear).
When I barely put the bulb in (before it "snaps" into its slot) it works. But when I put the bulb all the way in, it only sometimes works.
Regardless, this weekend I'll have to see if the tape helps out. At this point I'll try anything...the SOMETIMES directional is getting pretty annoying.
Thanks for the pics!
2011 SE Manual - black exterior/interior
Eagle Eyes halo projectors using 55w 5000K DDMtuning HIDs
LED Conversion (license plate, map/dome lights), and LED Taillights
Autobots decal over Ford emblems
Flat black TFB Designs hood stripes
2011 SE is offline
Old 01-06-2011, 06:31 PM   #142
andrewsfm
andrewsfm's Avatar
Fan#: 70099
What I Drive: 2008 Ebony ATX SES w/ Leather & Sun
FF Reputation: 5 andrewsfm Good Standing Member
I'm having a problem with the cutoff shield on my left projector not going back into place when I flick the highbeams. It gets stuck in the highbeam position. Could be the cold weather, but I need to flick them a few times till it fixes itself.
DEI 2-way Alarm & Start / DDM Ballasts + CAP 6000k 55w HIDs in Eagle Eyes Projectors / 6000k 55w HID Fogs / All INT+EXT LEDs+7W LED Reverse / K&N Air Filter / Kumho Ecsta 4X Tires / 35%/20% Tint / Black Grille / Maxxsonics MX-1 + 2500W Stereo
andrewsfm is offline
Old 01-07-2011, 10:07 PM   #143
2011 SE
2011 SE's Avatar
Fan#: 80951
Mine have maybe a 1/4 second delay between when I turn the high beams on/off, but mine haven't gotten stuck. I hope your problem resolves itself!
2011 SE is offline
Old 02-05-2011, 06:57 PM   #144
BIG_SEXY
Fan#: 33524
What I Drive: 2009 Silver Metalic Focus Coupe SE
FF Reputation: 1 BIG_SEXY Good Standing Member
I just installed these recently on a 09 coupe, and I have noticed that when I have high beams on that only drivers side is the only one in high beam. Does anyone know what would cause the passenger side not to go into high beam?
DOIN' WORK ON THESE BITCHS!
BIG_SEXY is offline
Old 03-21-2011, 11:08 PM   #145
2011 SE
2011 SE's Avatar
Fan#: 80951
My directional problem rages on! I spent a couple hours messing with the connections a few weeks ago, and couldn't for the life of me figure out where exactly the connection problem is. Once it warms up I'll be able to throw more time at it to see if I can finally get it fixed...but for now it's still a "sometimes" problem. Now it seems like when they're cold the directionals work, but as the headlights warm up the enclosure, they stop working. I have no clue!
In addition, I noticed that the spring clip on my left housing broke off. The headlight is still securely held in place, but when I hit bumps the left headlight bounces a little. Only an annoyance, but I may put some double-sided tape on the bottom of the lamp so that it doesn't shake itself to pieces over time.
Edit: And I tried the electrical tape method, and it didn't end up working for me. :(
2011 SE is offline
Old 03-21-2011, 11:13 PM   #146
2011 SE
2011 SE's Avatar
Fan#: 80951
I would just go over your connections on the passenger side carefully. I know it's largely plug and play, but as it appears to be the case with some of the other adapters, it may be an issue with connections.
2011 SE is offline
Old 03-23-2011, 09:59 PM   #147
2011 SE
2011 SE's Avatar
Fan#: 80951
So here's an interesting discovery I made:
My directional problem I've been having DISAPPEARS when I don't have the halos/headlights on. I've tested it two days in a row now, and the directional seems to work fine and dandy when no extra electricity is flowing that way.
Anyone have any ideas as to why that would matter? I never noticed it before because until two days ago, I always drove with either the parking lights/halos or headlights on.
2011 SE is offline
Old 04-17-2011, 10:47 PM   #148
KyleQ
KyleQ's Avatar
Fan#: 84296
What I Drive: 2008 Focus Coupe 5 Speed
FF Reputation: 3 KyleQ Good Standing Member
Does anyone know if a H13 bulb will fit in these projectors? If you could, you could get a hi/lo HID bulb for this and have hi-beams, if it's needed.
Where are folks getting the halo's for the fogs as well? I'm thinking projects with HID's and HID fogs - I live in the middle of nowhere and more light the better.
2008 SE Coupe MTX
2000 Contour SVT 3L
MSDS Headers/Weapon-R Y-pipe
Torsen T-2/Clutchnet Stage 3
Fidanza 8lb 131 of 2150
KyleQ is offline
Old 06-22-2011, 09:15 PM   #149
blackbumpinfocus93
Fan#: 80510
What I Drive: 2009 Black SES Sedan
FF Reputation: 2 blackbumpinfocus93 Good Standing Member
Does anybody know if you can replace the halos that come with the headlights with red halos?
Team Duratec #61
Sedan Revolution #134
2008+ SES #017
"Doing a drag race in an automatic is like running a 100M sprint in your wellies, full of tadpoles."- Jeremy Clarkson
blackbumpinfocus93 is offline
Old 07-01-2011, 06:16 AM   #150
2011 SE
2011 SE's Avatar
Fan#: 80951
For anyone interested (and in case this happens to you), the turn signal socket from a 2000-2007 Focus is what fits in these Eagle Eyes projectors.
The bulbs size is 3157, and I FINALLY fixed the problem I was having. Only took 7 months of tinkering and research!
2011 SE is offline
Similar Threads
Q type rear bumper + FREE halo projectors lamps toeycrack Archive 10 08-04-2007 04:12 AM
Halo Projectors for Sale - Awesome Condition SVTFRobexe Archive 10 11-17-2006 10:55 AM
Washed, waxed, and cataracts (Halo Projectors) removed! 56k, tread carefully T-V Ford Focus Builds & General Showroom 13 09-10-2006 11:24 PM
