Go Back   Focus Fanatics > Model Specific Discussions > MK1 Focus > MK1 Interior Mods & Upgrades
Old 01-04-2011, 09:26 AM   #1
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
Post HOW-TO: electricle oil pressure gauge.
This is a HOW-TO: on how to set-up a electrical oil pressure gauge to a 2000 ford focus se wagon with the 2.0l DOHC Zetec. I am not responsible if you mess up your own car.
Well first things first. You will need a good oil gauge, I went with glowshift, It comes with the gauge, sender unit and wiring harness and hardware to mount.
You will also need some copper tubing, A inch long tube with both ends being 1/4 male, and a T fitting with all three ends being 1/4 female, and a adapter from 1/4 to 1/8 fitting.
You will also need these tools too. Wire stripper, connectors, wire, heat gun, heat shrink tubing, and electrical tap, and if you don't have a heat gun, Use your lighter.
Now take the inch long tube and put some thread sealant on both end and screw it into the T fitting, and attach the old oil pressure sensor on too,
and it should look like this. DO NOT put the 1/4th to 1/8th adapter on yet or it will not clear the oil filter.
And then when you got this^ set-up, screwed it into the block and position it where you want the sender unit to point, then add your adapter and sender unit.
Now for wiring, you gauge should have came with a manual saying what the wires that came with the gauge are, and where some of them go.
Now we can start. I drilled a little hole near the hood latch release to get the wire through the firewall.
It came out here under the relay box.
Now once you got that through, run your sender wire along the fire wall using zip-ties to keep it out of sight and away from heat. Run the wire all the way over the the TB where you will run it down the same path as the knock sensor. The knock sensor wire's run in-between the intake manifold tubing. And make sure to keep the wire away from the TB's spring movement.
Then your ready to do the ground for the sender unit itself. I used the circle loop to the back left of the motor. Down through the same way as the sender wire. and agian make sure to keep it away from the TB's spring movement, You can see where my fingers are I zip-tied it the the original wiring for the knock sensor before it goes through the intake manifold.
And it should connect up to the sender, and use the shrink tubing here to protect it from the elements.
After that go back into the cabin and wire the sender wire you just ran, with the wiring harness that came with the gauge.
After that there is another ground wire to run on the wiring harness that came with the gauge, I wired it to the fuse box metal.
And finally the last two wires, yellow for the horn fuse since it works when the car's key is not turned, and the red wire to the brake lights, since on my 2000 wagon they only work when the key is turned.
And then your done sit back and enjoy knowing your oil pressure. And the coolest thing about Glowshift? You control what color you want.
And again I am not responsible if you mess your own car up.
Hope this helps some people to know how a electrical oil gauge hooks up.
djzx3
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
ctfocusfans.proboards.com
Djzx3 is offline
Old 01-04-2011, 11:46 AM   #2
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
Good right up I deff like the autozone special coolant temp gauge
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 01-04-2011, 11:52 AM   #3
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
Yea well you might be the only one to like it, cause I don't, I will have to replace it later with another Glowshift.
EDIT: also thanks to the people who helped me to either understand this, or helped with any idea's for this project.
Gauge pod idea came from Mr. volcomstone1966
And these people helped with the hardest part, wiring, and tubing set up.
Jgrove998
BC_ZX3
drostedrummer89
And sorry if I forgot anyone.
Thanks djzx3
HN #17
D23 crew-#1
Djzx3 is offline
Old 01-04-2011, 05:08 PM   #4
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
And yes the sun-pro is temporary I will be getting a temp gauge from Glowshift soon.
HN #17
D23 crew-#1
Djzx3 is offline
Old 01-18-2011, 04:18 PM   #5
JaFocus01
JaFocus01's Avatar
Fan#: 48654
What I Drive: 01 Turbo Zx3 & 04 Orange EaP
FF Reputation: 1 JaFocus01 Good Standing Member
nice write up
JaFocus01 is offline
Old 01-18-2011, 06:20 PM   #6
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
Thank you, And for anyone wondering I got a water temp gauge sitting right next to me to replace that autozone one, and I will replace the bad pic's with good one's of the two Glowshift gauges.
This water temp gauge is soo much better too, Just wire's no metal tubing.
HN #17
D23 crew-#1
Djzx3 is offline
Old 01-23-2011, 03:19 PM   #7
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
Up-dated with the new glowshift gauge for the water temp.
HN #17
D23 crew-#1
Djzx3 is offline
Old 01-23-2011, 03:51 PM   #8
Indy'sexclusiveZx3
Fan#: 65419
So where did you hook the water temp gauge up to?
Old 01-23-2011, 03:59 PM   #9
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
My dad brought it to work and drilled it out with a Bridgeport drill press.
The only difference is that metal line isn't there any more I got the new sensor in there.
HN #17
D23 crew-#1
Djzx3 is offline
Old 01-23-2011, 05:07 PM   #10
JCH841
JCH841's Avatar
Fan#: 79303
What I Drive: 2008 Black SES (?) Coupe
FF Reputation: 3 JCH841 Good Standing Member
Nice writeup and pictures. Two little things, if you're trying to get the "tubing" from the hardware store, technically it is called a pipe nipple and I'd use a grommet where the wire goes through the firewall to prevent chaffing the insulation. Not that any of us drive in a manner to cause vibration or flexing.
JCH841 is offline
