#1 | ||||
Ran the 1/8 again tonight!
This time for real, not launching at 2000RPM and babying the clutch like last week. Best run was actually a race between me and a 97 Thunderbird mark VIII with some mods and on 100 octane, I am on 91. He asked to run me because I was running about the same times he was, should have bet him (see below). Also ran a modded Fox body 5.0 on my 9.79 run where I trapped 80MPH. The last run, I put Richard's 17 inch SVT wheels. He was running 215/45 BFG street tires that should have run better than mine, but it was actually my slowest run. Got a 2.7 60' 9.978@79.60MPH Go figure.
Car is #5160 http://img684.imageshack.us/img684/9535/69657093.jpg Run against the Thunderbird http://img5.imageshack.us/img5/2236/67167830.jpg Run against the 5.0 http://img256.imageshack.us/img256/5504/91265049.jpg Run against Richard's SVT Focus http://img130.imageshack.us/img130/4893/81365170.jpg Shot of his SVT wheels on my car http://img714.imageshack.us/img714/5569/10324700.jpg
2009 Scion Xb with Strup exhaust and way too much else to write here |
Remove Advertisements |
#2 | ||||
Boost Junkie!
Those 60ft times are still killing you. I hate to say it but you're going to need slicks.
With the power you're making, you have a much faster car than that.
2007 Focus ZX3 - FSW Stg 2, cams and cossie mani, stock motor, 7.74 @ 93mph (1/8th mile) w/ 1.84 60ft spinning Built motor on the engine stand! Shout out to FSWerks and Focus Rising 2012! |
#3 | ||||
Well I reached my goals for tonight. Wanted to get a 9.7, wanted a 2.4 60' and wanted to trap 80MPH. I am doing a cup kit and 2.5 inch drop and the dogbone motor mount on Tues. That should eliminate most of the wheel hop. Then I am going to get some 205/50/15 star specs and see what I can do with those. We'll see.
#4 | ||||
Boost Junkie!
The star specs will help a good bit but they are far from perfect for drag racing. They are very hard walled and meant for hard cornering around a road course, not straight ahead launching. My best run with them I want to say was 8.76 @ 83mph with a 2.2 60ft. The slicks was 8.29 @ 86mph with a 1.91 60ft.
If you are having an issue with wheel hop, then I would suggest investing in polyurethane control arm bushings (works magic) and a lower stress bar. These two things eliminated my wheel hop problems completely. I did the dogbone a long time ago and it did help a bit. The cup kit will help also by putting the car's weight more directly over the wheels. I'm still on stock shocks/struts, that's my problem. My front end picks up worse than a fox body.
#5 | ||||
Yea. I might get a set of steelies and run some drag radials up front if I want to get into this hardcore but I dunno. We will see how happy I am after my new setup.
#6 | ||||
just to give you a brief idea my car did a 2.13 60' / 9.651 at 72.7 mph without the bottle... your car like stated above is alot faster then the times its pulling... need slicks or learn to get it out of the hole better. your car is a 8 second car...
1.706 / 7.720@91.13 / 12.381@96.84 letting off. ![]() Stock Motor, why hate on the 2.0? More power and new numbers to come soon... |
#7 | ||||
also a mark 8 is not a thunderbird. its a lincoln with a 32 valve modular 4.6 in it. I believe this was the motor they started putting in the cobras. it made 290hp at the crank but weighed 5k lbs. I used to have one and actually wanted to swap that into my focus before i got the svt swap but the tranny was shot and dad wanted the car gone.
#8 | ||||
Boost Junkie!
2007 Focus ZX3 - FSW Stg 2, cams and cossie mani, stock motor, 7.74 @ 93mph (1/8th mile) w/ 1.84 60ft spinning Built motor on the engine stand! Shout out to FSWerks and Focus Rising 2012! Last edited by SMITHBOY76908; 12-17-2010 at 02:20 PM. |
#9 | ||||
Yea, I am on cheap ass 195/60 street tires so a 2.4 60' is pretty darn good haha. I should have no trouble hitting 2 with some real tires. Next run will be the 1/4 mile on Jan 8th! Will have the new tires, motor mounts and cup kit/drop, so I should be good to go. Oh and the car was a Lincoln Mark VIII, said 32V on the back and the guy said it was basically a detuned Cobra engine. No idea why he called it a Thunderbird though.
#10 | ||||
Moderator OF DOOM
Yeah, id like to make it to that 1/4, i just know the SVT will make up for the crappy starts with the top end.
