General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
Old 12-15-2010, 10:41 AM   #11
NotAnSES
NotAnSES's Avatar
Fan#: 77951
What I Drive: 2013 PB Focus ST
FF Reputation: 1 NotAnSES Good Standing Member
Hilarious! Thanks for posting this! I NEED to show this to my buddy whos about to buy one of those kits from ebay!
ST Crew #109
2006 ZX4 ST SAP Sold!
2007 Honda Civic Si----Sold.. :(
1995 BMW 316i Beater for Germany
2013 Focus ST!
NotAnSES is offline
Old 12-15-2010, 10:44 AM   #12
klodkrawler05
Sooooooooooo EURO
klodkrawler05's Avatar
Fan#: 47771
What I Drive: BMW's
FF Reputation: 25 klodkrawler05 Great Standing Member
Buy-Sell-Trade Rating: (30)
Much Better G!
I added a few of my own thoughts/comments.
Originally Posted by starfuryt550 View Post
Here's why:
1) Cheap oil line fittings. Yes, they are NOT Earl's, Russell, Aero, or XPR. They are extremely poorly manufactured. I have held these side-by-side with the real deal and it's scary. The machining is horrible and not straight and these WILL leak and WILL cause your turbo to fail.
2) Crappy couplers. I bought a single coupler from eBay to compare with Brand Name 5 layer silicone couplers. I think the layers are non existent as these look like a single rubber piece. Good luck trying to add boost and having one of these blow off or apart.
This is a hit or miss thing. I've used no brand couplers with 0 issues on moderate boost/power levels. I have blown apart every single no brand coupler on the car now that I upped the boost to 24psi. If you intend to run large power or just want maximum reliability stick to name brand Samco etc
3) Crappy, fake, unreliable turbo. The turbo is no-name. No specs are given, ever. Just a bunch of supposed specs without any flow rates, dyno's, etc. It is cheap and will fail, guaranteed. It will not spool NOR make good power NOR be reliable.
Correct, the big doozey here is spool time. on the vw forums people have shown that the exact same size/spec turbo from a name brand place (bullseye, precision, garret, turbonetics) will spool almost a full 1000 RPMS sooner.
4) Knockoff Wastegates and Blowoff Valves. Some say these are fine to be cheap on, esp the BOV. If you buy a cheap fake BOV or WG and spend thousands on a kit, why cheap out now and get inferior products? What is another $100 when you've spent $3-4,000? Get a real WG and BOV and save yourself from problems later on when these fail.
5) Crappy intercooler. Some will say the intercooler is great. How do you know this? Do you have a picture of the intercooler from the inside of the hose end connectors to show how the fins are arranged to actually show it will flow and cool? You don't, nor do they ever show these pics, nor post how efficient the intercoolers are.
I'll try to find the flow tests on some of these but its pretty common to hear that the ebay godspeed cores are fine for a 300whp or less build you can compensate for the slightly less efficient core compared to a name brand by getting a slightly large off brand.
6) Intercooler piping is universal and won't fit. None of the pipes will fit the focus. They are pre-made sizes. You will have to spend hundreds to make them fit and you'll more than likely need more piping.
6) Oil (feed) lines are crappy. I've had one of these fake ones. It's scary. Not flexible at all, very long and will not fit well or look good. The connector ends are cheap and just like the hose fittings, horrible cast and WILL LEAK. The line ends are also crimp so there is no way to shorten the line if need be. You will have to make your own line to have a proper one.
7) No oil return. How are you going to return the oil to the oil pan or block? You don't have an oil pan with a bung nor taps for the block to make one.
8) Gauges are completely crappy. No brand gauges. I wouldn't trust these to be accurate, look good or perform in any way shape or form.
[B] EXACTLY gauges are the life monitor system of your car. if you dont have reliable gauges you have no clue of the true status of your car.
9) Downpipe sucks. All of the parts are mild steel. They WILL crack. That nice silver shine will go away fast.
Not true, most of these are stainless and hold up pretty well. the jetta had a ebay downpipe all summer long and I had absolutely no issues with it.
10) Oil catch can is a joke. No baffle, nor will they tell you info on it. If it has a "baffle" it will consist of a sponge inside the car. Really now, a sponge?
11) No air filter. How are you going to protect the turbo from sucking crap in? You won't because you dont have a filter nor a connector to it in many cases, nor will this fit.
since its a "custom" kit with end user deciding the placement it doesnt make sense to include an air filter because how are they to know the size limitations of where you are placing it?
There is more but that's it for now!!
Thanks for putting all this info together!
'91 Mazda Miata | '87 BMW 325e S50 Swapped |'94 Honda CBR600 F2
klodkrawler05 is offline
Old 12-15-2010, 10:56 AM   #13
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: Miata, STi, GSXR1k
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (24)
i think the biggest issue with these (besides the horrible turbo and wg) is the fact that they advertice them as a bolt on kit. and they are far from that. the IC piping is not a direct fit and will have to be modified, cut, welded, etc. to fit. even though there isnt any thing wrong with the material it still wont just fit the car, it is a bunch of random crap. as well as not mentioning the many, many other things you need to turbo any car much less focus.
Turbo Turtle Garage
facebook.com/turboturtlefabrication
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 12-15-2010, 11:03 AM   #14
starfuryt550
I Speed Often.
starfuryt550's Avatar
Fan#: 18440
What I Drive: Audi S4, Turbo ZX3
FF Reputation: 22 starfuryt550 Great Standing Member
Buy-Sell-Trade Rating: (51)
Exactly.
They don't mention injectors or tuning either, as well as a larger MAF tube or mafia, a proper wideband A/F gauge, etc.
Like you said, just random shit thrown together to make it look like a kit.
Thanks Brad!!
FF Authorized Reseller
I do LED conversions: Focus / Cougar / Contour / Scion TC / Mustang / Fusion / Milan / Escape
http://www.focusfanatics.com/forum/showthread.php?t=299426
starfuryt550 is offline
Old 12-15-2010, 11:14 AM   #15
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Lots of wrench time, no respect
FF Reputation: 14 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (7)
Nice thread!!!!
SES #009
FR '11 FF Moderators pick
Oct '11 ROTM
FR '12 Carlisle Nifty Fifty Award/Best in Boost/Best 08-11/Finest Five Pick
PSUrivie is offline
Old 12-15-2010, 11:52 AM   #16
SMITHBOY76908
Boost Junkie!
SMITHBOY76908's Avatar
Fan#: 56301
What I Drive: 2007 Turbo ZX3
FF Reputation: 18 SMITHBOY76908 Great Standing Member
Amen!!! Great thread! It's not just ebay turbo kits but the majority of ebay "knockoff" parts. I've heard of knockoff oil pans that were cast from sand. I wouldn't be surprised if these knockoff turbos were the same. I say we test it out, someone get one, see if it's cast from sand and if it is, let's super heat it in hopes of making a glass turbo. lol
2007 Focus ZX3 - FSW Stg 2, cams and cossie mani, stock motor, 7.74 @ 93mph (1/8th mile) w/ 1.84 60ft spinning
Built motor on the engine stand!
Shout out to FSWerks and Focus Rising 2012!
SMITHBOY76908 is offline
Old 12-15-2010, 11:57 AM   #17
alex62390
BACON?
alex62390's Avatar
Fan#: 60434
Location: People's republic massivetwoshits, United States
What I Drive: 2004 svt focus EAP
FF Reputation: 22 alex62390 Great Standing Member
i got the kiln and the torches... a glass oil pan would be dangerous but cool. glass valve cover would be SICK.
i will never buy aftermarket parts off ebay. The only thing that ebay is good for is finding rare parts for a rare car, and that is still hit or miss. some of the stores are pretty legit but its hard to tell whats good.
2004 svt focus EAP #658
1986 Chevy M1008- new(to me) motor going in, 6.5l sleeping for winter then HX40...
Hatch Nation #08
alex62390 is offline
Old 12-15-2010, 11:58 AM   #18
jmiller_1974
Fan#: 57165
What I Drive: a car
FF Reputation: 27 jmiller_1974 Great Standing Member
Buy-Sell-Trade Rating: (14)
Rep+ for this thread, by the way.
jmiller_1974 is offline
Old 12-15-2010, 12:03 PM   #19
xecutionr
Haterz gonna Hate
xecutionr's Avatar
Fan#: 55434
What I Drive: 2003 Frost Silver zx3
FF Reputation: 18 xecutionr Great Standing Member
Buy-Sell-Trade Rating: (11)
well, either this kit im installing now blows up my damn motor, or i will make this thread bow to me and ask me how i did it LOL
cause i'm def using a turbo kit from OBX
Zetec Crew #343
1979 Ford F-150 Custom 200,000 and counting
2003 Ford Focus Zx3 - 130,000 and counting (DD)
xecutionr is offline
Old 12-15-2010, 12:07 PM   #20
alex62390
BACON?
alex62390's Avatar
Fan#: 60434
nobody said they won't work, just its not worth paying for a poor quality kit thats going to break soon.
Hatch Nation #08
