How To Make Your Own Wiring Harness For Fog Lights - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-21-2010, 08:40 PM   #1
norcalfocus01
Fan#: 55603
What I Drive: White N Gold 2001 Sedan
FF Reputation: 132 norcalfocus01 Excellent Standing Member norcalfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Do you want to put OEM fogs in your car, but have no stock wiring harness? This is the How To you have been looking for. This how to assumes you have some basic electrical knowledge and can run wires on your own. This will work for all years and models.
KeepItKauai (Cy) has helped me out with the diagram and some of the parts you will need.
I copied this set up out of my car. I had a old set of aftermarket fogs that I used the wiring from along with the OEM style fogs.
Parts Needed:
  • 12-15 feet of 14 gauge wire
  • Two position toggle switch (whatever style you like) or a OEM switch with the fog option
  • 12 volt automotive relay
  • Inline Fuse with a 20a Fuse
  • OEM Foglight Housings, Bulbs, Mounts, and Pigtails
  • Misc. Jointplugs, Wiring End clamps for grounding
Wiring Diagram
It uses a switched 12V source for pin 86 on the relay so if the car is off, the fogs won't stay on and drain your battery. It doesn't matter what voltage is being used for pin 86, just as long as it's switched. The wire will only energize the coil, creating a magnetic field and throwing the switch inside the relay. Just hit the fog switch and bamo, foglights.
Here is a picture of how I wired the OEM pigtails. I just took these out of a junkyard Focus then used the jointplugs to wire them to my new wires.
Next is where I mounted my relay, inline fuse and the ground I used. It so happened to be a OEM ground near by so I used it. Both fog lights and the relay ground to this spot. Also this is super close to the battery to make it easier to run from the relay to the battery.
Now you can mount your toggle switch anywhere you'd like inside your car. Mine is mounted on the dash next to the steering colum. You can also use a OEM fog light switch and run your wire to the correct pin on the back of the OEM harness. The later of the two is a cleaner look, but you will pay a little more for the switch.
So after running the wires and tucking everything out of the way you should have a nice new set of OEM fog lights in your car. I really hope this helps some people out. If you have any questions or coments please share.
norcalfocus01 is offline
Old 04-21-2010, 09:31 PM   #2
captcurt_18
captcurt_18's Avatar
Fan#: 49565
What I Drive: 2005 Light Tundra ZX4
FF Reputation: 26 captcurt_18 Great Standing Member
sick chris! im going to use this!
2005 Light Tundra ZX4 2002 BMW 325xi
Sedan Revolution Member #120
University of Montana
Photoshop Guru! PM me if you need something chopped up
Give me rep if im helpful!
captcurt_18 is offline
Old 04-21-2010, 10:52 PM   #3
focus_kid_89
focus_kid_89's Avatar
Fan#: 45745
What I Drive: 2003 Pitch Black ZX5
FF Reputation: 11 focus_kid_89 Great Standing Member
Very nicely done. This should help a lot of people.
Zetec Crew #264 H.B. Lover #27
Originally Posted by djblackout View Post
not trying to be a dick, but i'm tired of putting up with everyones opinions. its my car, ill style it how I like. If you dont like that, just click next thread.
focus_kid_89 is offline
Old 04-22-2010, 12:04 AM   #4
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
FF Reputation: 34 tukaniSVT Great Standing Member
Nice write up Chris.
Good job.
-Ray-
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 04-22-2010, 12:06 AM   #5
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,745, Level 78
Points: 14,745, Level: 78 Points: 14,745, Level: 78 Points: 14,745, Level: 78
Level Up 74% Completed
Forum Activity 10%
FF Reputation: 90 goinloco1 Excellent Standing Member
couple of suggestions.
Take a light to the auto parts store that has the help section (advance. oreily's, etc) if you would prefer new plugs. picked some up that way, but dont have the number anymore. should be able to match them with the light handy.
All wire joints exposed to the elements should be soldered, lightly coated with silicone, and then heat shrinked while the silicon is wet (will prevent shorting and also decay from water, salt, etc). solder and seal, you'll never have to worry about them. :)
goinloco1 is online now
Old 04-22-2010, 12:12 AM   #6
norcalfocus01
Fan#: 55603
Yes the joints should be sealed, thats why I use the heat shrink over the jointplugs.
Old 09-12-2010, 09:08 PM   #7
Twytch
Twytch's Avatar
Fan#: 78294
What I Drive: Betreyal, 2000 Impreza, '88 Sierra
FF Reputation: 1 Twytch Good Standing Member
what about making a car that doesnt have foglight slots have them? did you just cut out the plastic from the lower grill? or was there more work that had to be done to install them?
ISR #102
1st.....2nd.....3rd.....4th......5th......GGGRRRRIINDDD!!! oops... It's only a 5 speed...
Twytch is offline
Old 09-12-2010, 09:53 PM   #8
disciplerocks
GT40 all the things!
disciplerocks's Avatar
Fan#: 59330
What I Drive: 04 ZX3, 12 Hatch
Points 13,460, Level 75
Points: 13,460, Level: 75 Points: 13,460, Level: 75 Points: 13,460, Level: 75
Level Up 53% Completed
FF Reputation: 13 disciplerocks Great Standing Member
Buy-Sell-Trade Rating: (17)
^You would need the grill made for fogs.
I added fogs and just ran them to the ignition. Would have wired to the switch if I knew which wire it was. Don't really need this now since they have been removed, but good write up. Should help a lot of people.
04 ZX3 Mostly Stock ["Best Non-SVT" FITF '12][3/13 ROTM][7/14 ROTM][2014 ROTY]
12 SE Hatch Sport & Winter Package, ST Front End
94 F150 XLT 5.0 HO, OBDII Swap
89 Bronco II XLT Crawler
disciplerocks is offline
Old 09-13-2010, 06:55 PM   #9
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
Dude, thank you for this write up! I have the fogs installed and the OEM switch but it's not wired up yet. Gotta do that soon.
+1 rep!
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 11-25-2010, 09:47 PM   #10
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
Okay, 20 years later and today was the first free day in awhile to wire up these badboys.
A quick addition to the how-to:
If you want to wire up a factory fog light switch, you will want to tap your fog light power into pin 83b. This will be the wire coming from pin 86 on the fog light relay. I tested each lead with a volt meter while turning the fog switch on and off. 83b was the only one that gave power when the fog light switch was pulled.
and....finally! I used cheap ebay fog-light houses. The old ones I got from a junk yard were yellowing beyond repair. These are nice and crystal clear, I also covered them in 3M clear bra material.
Camera makes it look like 14k HID's, but they're just the cheapest bulbs I could find.
