Replace master cylinder clutch - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-26-2010, 09:07 PM   #1
Notorious0ne
Notorious0ne's Avatar
Fan#: 70375
What I Drive: 05 Saleen Focus, 04 Saleen Focus
Points 7,505, Level 57
Points: 7,505, Level: 57 Points: 7,505, Level: 57 Points: 7,505, Level: 57
Level Up 78% Completed
FF Reputation: 15 Notorious0ne Great Standing Member
Well i just replaced my master cylinder clutch and would have loved for more indepth information and some pictures. So here are pictues and step by step information to go along with it.
1. First of this will be alot easier if you take out your front drive seat. Unplug battery as well.
2. start by removing the panal under your steering wheel.
3. Remove Hood release cable and your diagnostic cable.
4. You are going to need to remove your starter safty switch (black)
5. Continue by removing these 3 things
1- Speed control deactivation switch (Green) Turn left and lift small clip.
2- Stop lamp switch (Grey) turn right and lift clip
3- Clutch Position Switch (Red) turn left and lift clip.
They do not need to come off in any order what ever is easiest for you. When removed you will need to put these cables in a safe spot. I put them up by my steering wheel.
6. You will now need to remove both bolts that hold your master cylinder clutch in place. they are 10mm. (note do not pull master cylinder clutch out of compartment until you have drained most of your fluid out so you dont get a pond in your car.
7. after you take those bolts out you will now take off your clutch pedal and spring. (in picture the master cylinder is still on there)
8. You will now remove the pedal assembly so when you put your master clutch cylinder back on you do not snap the white rod like i did :/. There are 4 bolts.
9. In the engine compartment you are going to need to take out your battery and move your fuse box a little atleast i did on my 2004 focus.
10. Drain your clutch/brake fluid. you can use a turkey baster in this occasion.
11. When your fuse box is out of the way you will be able to see where the green rods come through into your engine bay as seen below.
12.There are small butterfly clips on the green parts you can use a small ice pick in order for you to get them out easily. be careful not to loose them there are new ones with your new part but its nice to know you have an extra one if you happen to loose one. (cover the lines with paper towel you do not want to get dirt in them!)
13. Now remove previous clutch master cylinder and install the new one in the previous order. connect all the lines and refill brake/ clutch fluid. Use dot 3 brake fluid. picked it up for about 5 bucks at my local autozone.
14. Heres the rough part it took me a good 45 minutes to find the bleed plug for my clutch you are going to need to bleed your clutch, and maybe your breaks. I did not need to bleed my brakes i left just enough in the reservoir to not need to do that.
You will need to pump your clutch multiple times. YOU WILL NEED TO PEOPLE to bleed your clutch and or brakes.
Goodluck!
2004/2005 Ford Focus Saleen
The cops are here to keep us safe.............I'm here to keep them busy!
Hatch Nation #43
Notorious0ne is offline
Old 10-27-2010, 12:03 AM   #2
oknvragain
Fan#: 48054
What I Drive: 06,RED,ZX3
Points 737, Level 14
Points: 737, Level: 14 Points: 737, Level: 14 Points: 737, Level: 14
Level Up 37% Completed
FF Reputation: 1 oknvragain Good Standing Member
I was able to gravity bleed mine. Took a little while and probably more fluid, but it worked.
2.0 Duratec
Custom GT28R Turbo build
3 Inch Exhaust...... NOW 2.5 Inch
42lb bosch injectors
Tune by Tom
oknvragain is offline
Old 10-27-2010, 06:24 AM   #3
Points 27,776, Level 98
Points: 27,776, Level: 98 Points: 27,776, Level: 98 Points: 27,776, Level: 98
Level Up 43% Completed
Personally, I hate people. That's why I have a vacuum bleeder kit. It's the fastest way to bleed brakes, and the most efficient. This is a pic of the Acutron version. A company named Miti-Vac has both plastic and metal versions. The Acutron looks a little heavier duty for about the same price as the cast metal MV. I use a cheap $20 plastic body Miti-Vac for brake jobs. It's done it's job for many years now.
Old 10-27-2010, 09:56 AM   #4
Notorious0ne
Fan#: 70375
Never knew they made that haha thanks for the tip it def would have helped me instead of pumping my clutch so much!
Hatch Nation #43
Old 10-27-2010, 01:52 PM   #5
IzzyTheSVT
IzzyTheSVT's Avatar
Fan#: 79598
What I Drive: 2003 Competition Orange SVT - EAP
FF Reputation: 1 IzzyTheSVT Good Standing Member
GREAT pictures NotoriousOne - i just did mine last saturday and i'm wishing that these were up last week to help me out! for anyone who will be doing future CMC replacements, i also found that it was convenient to remove the drivers side front wheel to access the lower green rod.
IzzyTheSVT is offline
Old 10-27-2010, 02:43 PM   #6
Notorious0ne
Fan#: 70375
thanks and when i was replacing mine i going wow i really wish i had some step by step with pictures so i made this hopefully it helps out some people!
Hatch Nation #43
Old 10-27-2010, 03:31 PM   #7
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Yeah, I have a metal mighty vac.. Its saved my butt many times..Good investment..I had never seen the acutron one before.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 10-27-2010, 04:32 PM   #8
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Yep...Mighty Vac FTW!!!!
Here's how I bled mine when I replaced the clutch master cylinder:
WD40 is offline
Old 10-27-2010, 08:12 PM   #9
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
another tip
remove the inner fender liner on that side of the car. you can get better access to it.
scrammer is offline
Old 11-02-2010, 11:16 PM   #10
Notorious0ne
Fan#: 70375
any idea how i get this put into the archive?
Hatch Nation #43
Tags
