ECU Tuning Chat Discuss performance tuning options for your Ford Focus.
#21 | ||||
The SVT has 5 tables. 4 of which are based on rpm and load and the 5th one is rpm only. The 4 that are based on rpm and load do not do anything. The 5th one WILL adjust the knock sensor's sensitivity. By not doing anything I mean you can adjust all of them (the 4 mentioned above) to either end of the spectrum and you will not see any difference in spark at any time nor will you see any change in knock sensor activity. |
#22 | ||||
Token Engin-nerd
I'm just wondering why you dont make those tables available to the consumer version of advantage?
#23 | ||||
FF Affiliate
There are a lot of tables that are in the PRP that are not needed for basic safe NA/FI tuning why double the list with other things
Most people dont need to be messing with half of what they already have access to why make things more confusing to 99.9% of the people using the PRP Yes there are a FEW very few that access to some stuff might help but with out testing equipment , dyno most you couldnt use anyway Tom
#24 | ||||
Token Engin-nerd
#25 | ||||
omn-nom-nomnomnomnom
nice
SCT PRP FTMFW! |
#26 | ||||
Screenshot of LL with all this stuff hooked up as described:
![]() That's what you could expect to see if you're running an SVTF on MBT spark @ high loads. I was pretty surprised it didn't knock until 6k. And no, I obviously didn't repeat this run. This was one of VERY few times I have observed my motor knocking. FWIW, I am actually running MBT just about everywhere, but -1 above 0.8 and -2.5 at full load (from about 4k and up).
SCT PRP FTMFW! Last edited by mellephants; 03-25-2010 at 08:40 PM. |
#27 | ||||
i bought the same cable, from stock cable.com
i foudn the 3 wires, how do i know which is analog one oveously the bare one is ground, but the other two are red and yellow. plugged the cable into the xcal and gave it power and found that 2 of the wires gave out 2.5 volts so im guessing they are the analog wires
BEWSTING ALL DAY SELLING: FACTORY 03 SUBWOOFER AMP $15 FACTORY 03 HEADLIGHTS W/ ZENON BULBS 30$ FACTORY 03 SPEAKERS $10 FOR 2 |
#29 | ||||
like i know which pins are what because of the diagram
but how do i know wich wires that are putting out positive voltage are analog 1 or 2 do i combine the 2 wires or only use one or the other im talking about the 9 pin mini din
#30 | ||||
Use a multimeter to find out which wire is connected to each pin.
SCT PRP FTMFW! |
Similar Threads
| Help! 2000 Focus - no fuel - need wiring diagram | thebigreddog! | General Technical Chat | 6 | 05-06-2009 06:33 PM |
| ST170 Tailight Wiring Diagram | havoc7476 | MK1 Focus | 6 | 11-07-2005 11:50 PM |
| April 2005 U.S. Auto Sales Scorecard | Kneel | Ford Focus & General Car Chat | 3 | 05-04-2005 03:56 PM |
| Anyone have a wiring diagram for guage cluster. | BLKEUROSVTZX5 | Car Audio, SYNC, MyFord Touch & Electronics | 2 | 08-11-2004 10:04 AM |
