New Water Pump Replacement HOW-TO w/ PICS - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-16-2010, 07:45 AM   #11
63redsled
Fan#: 23219
What I Drive: 2000 red zx3 1966 for tbird 1963 galaixe 500 ragtop 1972 f-100
FF Reputation: 1 63redsled Good Standing Member
thanks for the photos made it very easy and worked very well
63redsled is offline
Old 06-17-2010, 08:01 PM   #12
alrayworld
Fan#: 56076
What I Drive: ford focus 2001
FF Reputation: 1 alrayworld Good Standing Member
Very Informative. My question is the 3 bolts does it needs to be torque? or just make it sure it tight?
If there is what is the torque spec for this 3 bolts.
Thanks.
alrayworld is offline
Old 03-17-2011, 09:12 PM   #13
HolyHealy
Fan#: 84101
What I Drive: 2001 White ZX3
FF Reputation: 1 HolyHealy Good Standing Member
Hey guys, new to this forum and came across it via google. This how-to is fantastic, especially compared to the Haynes one I do have a few questions, however.
Why does the motor mount have to be removed? I've seen a few people across these boards and the net that claim to have not needed to drop the engine, is this true?
And secondly, What sort of skill level is needed to this? I've wrenched my own car on little things (belts, alternator, oil filter etc) but I've never dealt with motor mounts. I feel like it sounds more intimidating than it actually is. Anyone wanna shed some light on what sort of skill level is needed to perform this job?
Sorry for double post
HolyHealy is offline
Old 03-18-2011, 01:49 PM   #14
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
What I Drive: 2003 Pitch Black LX
Points 13,451, Level 75
Points: 13,451, Level: 75 Points: 13,451, Level: 75 Points: 13,451, Level: 75
Level Up 51% Completed
FF Reputation: 9 drunkyoda Good Standing Member
this is definately different then the SPI btw. The SPI's water pump is run off the timing belt.. this meaning you have to take off timing belt when you do it hence just changing it at the same time. good how-to!
2003 Focus Sedan - Sold but not forgotten
2014 Mustang V6 - Current
drunkyoda is offline
Old 03-18-2011, 02:58 PM   #15
oblivion2kx
Fan#: 61764
What I Drive: 2004 Twighlight Blue 2.3l ZX5
FF Reputation: 2 oblivion2kx Good Standing Member
dont forget to run the car afterwards with your heater on high and the coolant cap off to vent any air bubbles. not doing this will give you air buble in your system and a damaged head gasket.
A few years ago, I went to the gym for several months and lost 30 pounds. That must be worth about 1% more fuel economy in the city.
oblivion2kx is offline
Old 03-18-2011, 03:01 PM   #16
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
^^^^ i have never heard this before... it never ruined my headgasket but who knows.
Old 03-18-2011, 09:36 PM   #17
RAD2000
RAD2000's Avatar
Fan#: 82774
What I Drive: 2000 sedan 2003 zx3 2012 sorento 77
Points 661, Level 13
Points: 661, Level: 13 Points: 661, Level: 13 Points: 661, Level: 13
Level Up 22% Completed
FF Reputation: 1 RAD2000 Good Standing Member
great thread,this is why i joined this forum,my 2000 focus haynes manual has very few greasy pages thanks to this forum........
Do not tell fish stories where the people know you; but particularly, don't tell them where they know the fish.
RAD2000 is offline
Old 11-18-2011, 06:53 PM   #18
madhamster
Fan#: 91924
What I Drive: 2001 black 2.0 focus
FF Reputation: 1 madhamster Good Standing Member
you most lower or raise the engine to allow room for removal, i went up . its not that hard if you can turn a wrench you can do it. I put the jack under the oil pan , removed the one bolt for the water bottle and set aside, moved the power steering reservoir to one side, removed engine mount , removed bolts on water pump pulley and removed then i raise the engine as far as i could and wedged a long pry bare between fender and a different pulley in order to push the engine over slightly to allow removal and did not have to remove the ac pump this way
madhamster is offline
Old 11-19-2011, 10:01 AM   #19
greygoose8732
greygoose8732's Avatar
Fan#: 65707
What I Drive: 01' Liquid Grey S2, 03' Black SVT
FF Reputation: 1 greygoose8732 Good Standing Member
I replaced my water pump and timing belt and now my crank seal is shot (leaking oil) and the Haynes manual says to pull the WHOLE motor to change the seal!
greygoose8732 is offline
Old 11-21-2011, 07:04 PM   #20
itzbigmike
itzbigmike's Avatar
Fan#: 91808
What I Drive: 2003 pitch black svt
FF Reputation: 1 itzbigmike Good Standing Member
excellent instructions you couldn't have made it easier. quite tedious it took about 4 hrs but i didn't have to remove the motor mount or the a/c compressor..thanks for the detail
itzbigmike is offline
Similar Threads
Focus 2002 Zetec - Water Pump Failure? stubee General Technical Chat 4 11-16-2008 06:02 AM
Just had timing belt and water pump changed now car is overheating?!?!? DanielW General Technical Chat 5 11-10-2008 10:37 PM
water pump problems officefocus General Technical Chat 1 06-25-2006 11:54 AM
Water pump clicking... Marko1962 General Technical Chat 9 07-03-2005 02:20 PM
