SVT Clutch replacement completed (pics) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-06-2010, 02:51 PM   #1
nacnudv8
nacnudv8's Avatar
Fan#: 52725
What I Drive: former owner:Pitch Black '03 SVT 3D
FF Reputation: 7 nacnudv8 Good Standing Member
I have been posting here for a couple of weeks following the failure of my clutch system. I had drive (ie clutch) but couldn't disengage the clutch and thought it was the hydraulics.
I changed the CMC and bled with a vacuum pump - no result.
I then went in search of the slave cylinder and after taking the trans-axle off found the clutch to be toast, with the fiction material tightly packed in the pressure plate holding the clutch onto the flywheel. My slave was also leaking a bit, probably due to the high pressures I was exerting on it to dis-engage the clutch.
There are many posts on changing the clutch here but I though some of my pictures and issues I found may be of help to you all.
Ready to get going - Car up really high!
The space I had to drop the trans-axle:
Battery Box, air box all out.
Disassemble the suspension and removed the axles complete with knuckle
Don't forget to remove the bolts completely or the knuckle will not release from the front strut or bottom ball joint.
Shafts pop out very easily with a pry-bar. Support the end before you pop out of it may fall out or over bend at the CV joint.
This is the fill plug not the drain plug - as I found out - you need to drain the oil or you will pour oil on your self when you drop the trans-axle.
I made a DIY brace to support the engine from the top. I was easily strong enough. I also used the main cross bar to tie the trans-axle to so I could lower it under control.
The manual tells you to detach the reverse switch - but not how! I just could not see it to know where or what to pull - so I cut the two wire near to the top of the bell housing and spliced them once the tranny was out.
It turned out that the reverse light switch just pulls of the connector, it has a little tab to release it. The other switch however on the back of the tranny near to the fire-wall near to the driver side is the VSS and needs to be removed completely by undoing the Torx bolt and pulling it clear.
Removing the starter motor was a pain - as it was so hard to get to the bolts. I undid one from the under-side and the other from the top side. Not also the bracket for the manual shift cables. This is held on by two bolts fixing it to the tranny and both need to come off so the whole bracket is free. Both of these were red-Loctite fixed (why I don't know) and were very very hard to get off.
Transmission out!! - I had a friend help me pull it off and we were both under the car and pulled it onto a cinder block and then out from the car.
Note all the friction material in the bell-housing.
Here is the flywheel and pressure plate. Note all the friction material jammed into the pressure plate.
An eye for an eye makes the whole world blind.
Mahatma Gandhi
nacnudv8 is offline
Old 06-06-2010, 03:08 PM   #2
firelink74
firelink74's Avatar
Fan#: 58474
What I Drive: 2001 silver se
FF Reputation: 1 firelink74 Good Standing Member
do it yourself FTW!
SPI last of a dying breed
firelink74 is offline
Old 06-06-2010, 06:15 PM   #3
nacnudv8
nacnudv8's Avatar
Fan#: 52725
^^^ translation?....
Mahatma Gandhi
nacnudv8 is offline
Old 06-06-2010, 07:03 PM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Level Up 52% Completed
That'd be "For The Win". Always cheaper and more rewarding doing it yourself. Lots of good, useful pics in your post.
So I'm curious as to whether a simple replacement of the faulty clutch disc (and a thorough cleaning) solved your problem (if you've gotten that far) and if no other clutch components needed attention - aside from the slight slave cylinder leak you mentioned? Any idea what caused the friction material to separate and shred like that? Was the disc nearing the end of its useful life?
BC_ZX3 is offline
Old 06-06-2010, 07:08 PM   #5
arlenn
Fan#: 67609
What I Drive: 2002 Silver ZX5
Points 3,454, Level 36
Points: 3,454, Level: 36 Points: 3,454, Level: 36 Points: 3,454, Level: 36
Level Up 70% Completed
FF Reputation: 16 arlenn Great Standing Member
BC,
It would be interesting to see the swept area of the flywheel. I have suspicions of what might have happened.
arlenn is offline
Old 06-06-2010, 07:20 PM   #6
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
True.
Reason I asked about disc age was I had something similar happen a long time ago (on another car) where the disc was worn down to the rivets and a large chunk of friction material between two rivets cracked and broke free. Caused similar problems but the fix was simply a new disc (and a lot of labour).
BC_ZX3 is offline
Old 06-06-2010, 09:32 PM   #7
arlenn
Fan#: 67609
My thought would have been EXTREMELY high temps that basically destroyed the matrix marital freeing the fibers; a blue swept area of the flywheel.
arlenn is offline
Old 06-06-2010, 09:53 PM   #8
nacnudv8
nacnudv8's Avatar
Fan#: 52725
Thanks BC_ZX3 - learn something every day!
- No I replaced the clutch and therefore had to change the flywheel as mine was the original pre-TSB version. The new style OEM LUK clutch for the SVT is a bit larger in dia. so it needs a new flywheel too.
It was not cheap! C F M in Florida sold me the kit which included the through-out bearing, pressure plate and the alignment tool.
arlenn - regarding your question - I'll go now and post some pics of the flywheel and pressure plate - perhaps you both can shed some light on what happened. I think heat with a worn friction material did it.
It was the non-flywheel side of the clutch that was distroyed.
And BTW at the time I was passing an old slow 60's Camero at a normal speed and when I was level with him, he floored his throttle and tore off - I pursued and we got .......fast. - - - then "pop" as I tried to sift down a gear and then was unable to change gear..... :(
Mahatma Gandhi
nacnudv8 is offline
Old 06-06-2010, 10:07 PM   #9
arlenn
Fan#: 67609
"pop" you say? hmm.
maybe clutch disk spider broke? diaphragm spring broke?
arlenn is offline
Old 06-06-2010, 10:21 PM   #10
nacnudv8
nacnudv8's Avatar
Fan#: 52725
Originally Posted by arlenn View Post
"pop" you say? hmm.
That's what I thought - spring was good although parts of it were bent until I took it off the flywheel then it straightened out. It was a seal giving way in the slave I think.
Mahatma Gandhi
nacnudv8 is offline
