ZETEC Timing Belt Replacement - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-13-2010, 09:28 PM   #41
lhc_focus
Fan#: 42464
What I Drive: 2002 ZX5
Points 46,343, Level 100
Points: 46,343, Level: 100 Points: 46,343, Level: 100 Points: 46,343, Level: 100
FF Reputation: 11 lhc_focus Great Standing Member
Take a look at the opposite end. Are the slots still lined up? Oh, is the bar in place?
lhc_focus is offline
Old 05-14-2010, 07:30 AM   #42
RickNC
RickNC's Avatar
Fan#: 38833
What I Drive: Focus
FF Reputation: 1 RickNC Good Standing Member
I don't have the bar at this time. Was to late to call around last night when I got it apart. I am going to start calling to see if I can find the pin and the bar.
RickNC is offline
Old 05-14-2010, 09:43 AM   #43
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
Points 5,373, Level 47
Points: 5,373, Level: 47 Points: 5,373, Level: 47 Points: 5,373, Level: 47
Level Up 12% Completed
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
Get the bar and pin, put them in and you should be good.
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
Old 05-14-2010, 10:47 AM   #44
Elder
Points 13,417, Level 75
Points: 13,417, Level: 75 Points: 13,417, Level: 75 Points: 13,417, Level: 75
Level Up 42% Completed
Posted via FF Mobile IF he was near TDC #1 when the belt came off! Otherwise you need to carefullt turn crank so pistons move toward center of stroke (plugs pulled) so they are away from valves. Then set cams to timing position. Then bring #1 piston to TDC . at that point you can proceed with normal timing instructions!
sailor is online now
Old 05-14-2010, 11:59 AM   #45
RickNC
RickNC's Avatar
Fan#: 38833
What I Drive: Focus
I was under the impression I could put the pin in and hit it with the crank and that would line up the cams. Then put the bar in and proceed. If not please let me know. I had to order the bar and pin online so the car is going to sit for a couple days.
RickNC is offline
Old 05-14-2010, 03:32 PM   #46
Missourileo
Captain Retard
Fan#: 55980
I would take the t-belt off, or loosen the cam gears. Then put the timing pin in, align the crank with the pin. The put the timing bar in, align the cams with it, then tighten down the cam gears.
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Old 05-14-2010, 09:40 PM   #47
lhc_focus
Fan#: 42464
Originally Posted by RickNC View Post
Ok I am doing this now. Found the belt to be really loose. When I got in there I found that the idler pulley bolt had snapped. I don't know how it was even running. So when the cover came off the idler fell off and the belt came off. I think I also bumped the cam sprocket. So now I wonder how I am going to make sure the timing is correct with no belt...........
If the belt fell off as stated above, putting the crank pin in won't help the cam sprocket position. Slow down. Look at the opposite end of the cams, are the slots fairly close to parallel? You can't just spin them. If so you should be able to wiggle the bar into place. That's what I did. LUK
Old 05-15-2010, 07:16 AM   #48
RickNC
RickNC's Avatar
Fan#: 38833
What I Drive: Focus
They are. The intake cam is slightly turned. I know that moving the crank to the pin isn't going to move the cams since there is no belt. However, from what I have read it seems that if the crank is against the pin and the cams are lined up all is good. No? I know I have lots of questions but the more I read on here the more confused I get. Everybody seems to say somethign different.
RickNC is offline
Old 05-15-2010, 08:16 AM   #49
Alex2507
Alex2507's Avatar
Fan#: 74979
What I Drive: 2000 Silver Focus SE Zetec
FF Reputation: 1 Alex2507 Good Standing Member
I had to order the bar and pin online ...
Can you provide a link to where you got them? I'm just starting to gather up parts and courage for this as my 2000 SE has 160k miles and I'm starting to think it might be time ...
Alex2507 is offline
Old 05-15-2010, 10:27 AM   #50
lhc_focus
Fan#: 42464
Sounds to me like you are very close with the cams. When I went to put the bar in the slots they were off about 1/8". I turned the cam just enough to slip the bar in place. Then put the pin in the hole. Now your good to go.
It will take several tries to get the belt on. If you don't keep the crank against the pin, there will be slop in the belt. Like I said, you'll get it after several tries. It does require patience, you got some on the shelve? LUK
Similar Threads
When should you get a timing belt changed? Jebus SVT Performance (2002-2004) 13 05-25-2009 04:00 AM
timing belt replacement racer1735 SVT Performance (2002-2004) 15 05-22-2007 12:14 AM
2002 1/2 zx3 timing belt removal With a twist not the same as most of the other cars Knuckles899 General Technical Chat 4 03-11-2007 04:34 PM
1.8 Zetec timing belt ciscodisco ZETEC Performance (2000-2004) 0 02-17-2006 05:10 AM
