ECU Tuning Chat Discuss performance tuning options for your Ford Focus.
#11 | ||||
I agree, if the TB is in the stock location on the stock manifold then there's no reason to use anything except the stock manifold volume parameter unless someone was trying to fudge someting in the tune...
Since he's changing the whole set-up from draw thru to blow thru, he might be changing back to a stock manifold from a custom one?
213 whp / 160 wtq D23 NA with stock intake and TB. Inventor of "The $0 Thunder Throttle" & "Focuzdax-7" brake swap. I like the same qualities in women and pistons; Lightweight, fast, and with the smallest skirts possible...
Last edited by tb1999; 05-13-2010 at 10:37 PM. Reason: corrected error, going to blow thru, not the other way around |
#12 | ||||
FF Affiliate
Your going to blowthrough , that changes things all in it self , blowthrough does not use the same MTF as suckthrough so you will just have to play with it
By reading what your saying about your tuning this , you need to stop get the SCT book and go over a few things so you dont hurt your engine , the MFT is some what easy in the scale of things that need to be done Tom
#13 | ||||
Token Engin-nerd
A lot of people scale manifold volume when they do the mafia scaling so I was saying he should reset that to stock if it is changed.
#14 | ||||
I thought that since the MAF hotwire will cool off proportionately based on the density of the air etc, that having boost flowing through it versus air at near atmospheric pressures would be irrelevent? I don't doubt you, I'm just trying to understand why....
#15 | ||||
Token Engin-nerd
Theres also a lot of difference due to the filter turbulence in drawthrough vs nice straight tubing in blowthrough Plus with a higher reynolds number due to higher velocity in drawthrough, the boundary layer will be higher off the tube wall, effectively making the tube even smaller and making the air go even faster.
#16 | ||||
While the basic theory is correct, there are mittigating circumstances and other theories that ultimately dictate what goes on in the MAF tube Thanks for helping me understand that. I can get a full night's rest now....
#17 | ||||
FF Affiliate
Tom
#18 | ||||
Token Engin-nerd
At atmospheric pressure in the inlet pipe, the mass of air will take up more space and therefore move faster than it does in the pressurized charge pipes.
Since it is moving faster it will have a higher reynolds number and the boundary layer will be taller, making the tube effectively smaller and further increasing the velocity of the air in the inlet.
#19 | ||||
If any of you are wondering the proper way to tune your MAF transfer table. There are a few steps you should follow to make th process much easier.
1. Force the EEC to run in open loop. This makes it much easier to tune the lower voltage part of the function because the o2 sensor is not having any say over fuel. 2. Set your base fuel table to 12:1. This is your target AFR. 3. Datalog. You will need to log AFR with a wideband and you will need to log MAF voltage. TPS and RPM are fun to have but are not needed. Make sure your engine is heated up all the way before logging cause cold start enrichment will throw it off a little. First you log the 0-2 volt part of the curve. Once the car is running and heated up and you start logging. leave it in neutral. Ease on the throttle slowly and steadily. keep increasing the throttle until you reach 2 volts or you dont want to free rev it any higher. Once you are done the log. Then you need to tune. for example. if at 1.2 volts your afr is 14:1 and your target afr is 12:1 then you need to multiply the airflow value at 1.2 volts by 1.16. You go through all of the values from 0v to 2v in the same manner. The process may have to be repeated a few times to get it as close as possible. Then you are ready to do some datalogs while driving for the 2v to 5v section of the transfer. You always want to ensure that you are starting in the rich side. Doing hard pulls leaner than 12:1 can get dangerous. Especially with forced induction. I find a good way to get a ballpark figure of what the transfer values should be before starting is multiply the values proportionaly to the size of the MAF upgrade. For example. If your starting with a 60mm maf and converting to an 80mm maf then you would multiply all the values by 1.3 as a starting point. Again, you get the engine up to operating temp. Then you find a nice open strech of road ( or a dyno). You get logging and start doing moderate pulls. I find 3rd gear works real well. You want to make sure to make slow and steady pedal movements. This helps to make nice smooth datalogs that are easy to read. Let the car slow down to the bottom slowly accelerate to the top of the gear. If you are on the rich side then it is ok to start doing some good hard pulls as long as it stays on or below 12:1afr. Once you think you have enough clean data to tune as many data points on the curve as you can (except the high 4v area. If you get up here you still need a bigger MAF!). Then you start rebuilding your curve by multiplying the airflow values at each voltage data point relative to the amount that the logged AFR is away from your target 12:1afr. You may have to repeat this process a few times to get it perfect. When the MAF transfer is spot on. The AFR will hold at 12:1 all the time. Idle, light cruise and WOT. The only time it should stray fronm 12:1 is when decelerating. Once you have the MAF curve done. Then you are free to set Base Fuel table back to stock and enable closed loop fuel control. That way you can have you lean idle and cruise with input from the o2 sensor. |
| Tags |
| 3" maf, blow through |
