#41 | ||||
#42 | ||||
"Elder"
Posted via FF MobileSingle tooth as described sounds more useful for tming setting, assembly work... prob. not for stuck bolt removal...
#43 | ||||
For the record I've used the method of placing the socket on the crank pulley bolt and use a breaker bar to the garage floor and bumping the starter. Works like a charm.
On a stick shift with the car off, I've placed the car in 5th, handbrake on and apply the brakes and bump the starter. Did that one a couple times on my old 240sx.
2003 ZX5 2003 Wagon |
#44 | ||||
"suitable for counter-holding crankshaft when releasing or tightening crankshaft pulley bolts" |
#45 | ||||
#46 | ||||
going to try the LASER C311 Crankshaft Locking Tool next with a six foot breaker bar on the bolt!! [don't confuse this with the timing pin]
![]() and/or Laser 4275 flywheel locking tool: ![]() i.e. one at the front (of the block) and one at the rear!! Last edited by the_doc735; 05-03-2010 at 01:42 PM. |
#47 | ||||
the_doc735.......the crankshaft locating pin should NOT be used as countertorque when loosening the pulley bolt.......only use the flywheel tool. I can't find the link now but I remember seeing a warning (and photos on where the pin contacts the crank) about not using the pin when loosening the pulley bolt, for example.
#48 | ||||
crankshaft locating pin = timing pin?
If yes(?) ...don't worry I'm not using the timing pin; I'm using the crankshaft locking tool which has an entirely different part number, it is A LOT more robust than a timing pin and unlike the timing pin it DOES have a 'hex head' rather than thumb screw grip - to allow spanner tightness to be applied |
#49 | ||||
"Elder"
#50 | ||||
I found the photo of your referenced tool kit and it appears that the "locking" pin is shorter than the "locating" pin which makes sense because I believe that the locking pin has to be contacting the crank web/counterweight in a different location because you'll be trying to rotate the crank in a counterclockwise direction when loosening the pulley bolt, as opposed to a clockwise direction when locating the crankshaft for timing the cams. My concern was because of these photos in post #4 here: http://passionford.com/forum/technic...cking-kit.html
