removal of crankshaft pulley bolt? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-29-2010, 03:39 AM   #21
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Points 4,699, Level 43
Level Up 75% Completed
Originally Posted by iroc34 View Post
.....take it to a garage and ask them to loosen the bolt for you and then tighten it back up enough to get you home!! ......
lol - done this a few times on a few cars. Mostly exhaust. Have the wife take it down and they do it for free - I don't have much luck myself....... go figure.
60k+ miles.
a_2000_se is offline
Old 04-29-2010, 07:55 AM   #22
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
Points 5,291, Level 46
Points: 5,291, Level: 46 Points: 5,291, Level: 46 Points: 5,291, Level: 46
Level Up 71% Completed
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
Keep in mind, if the air compressor that you are using only puts out, let's say 60 psi, then you aren't getting the full potential of the impact. It doesn't matter if you have a 50,000 ft. pound impact, if there is not sufficient air.......it's useless. You can put a breaker bar,short extension combo on the bolt, lower the car on the breaker bar and it will break it loose. Do this slowly with a jack.
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
Old 04-29-2010, 11:26 AM   #23
jasonbi
jasonbi's Avatar
Fan#: 13305
What I Drive: 2002 SVT
Points 4,467, Level 42
Points: 4,467, Level: 42 Points: 4,467, Level: 42 Points: 4,467, Level: 42
Level Up 59% Completed
FF Reputation: 3 jasonbi Good Standing Member
time to start jacking threads...sorry, but its a somewhat related question....once that bolt comes out, does the crank shaft pulley come off easily or do you need tools to "pull" it off?
#3286 OF 4788
jasonbi is offline
Old 04-29-2010, 11:57 AM   #24
Missourileo
Captain Retard
Fan#: 55980
The pulley should come off with a little bit of WD40 and some wiggling.
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Old 04-29-2010, 01:09 PM   #25
disciplerocks
GT40 all the things!
disciplerocks's Avatar
Fan#: 59330
What I Drive: 04 ZX3, 12 Hatch
Points 13,185, Level 74
Points: 13,185, Level: 74 Points: 13,185, Level: 74 Points: 13,185, Level: 74
Level Up 84% Completed
FF Reputation: 13 disciplerocks Great Standing Member
Not sure if I missed something, but is this the pulley for accessories or timing belt? If its for the accessories then there is a how to from focushacks. basically brace your rachet against frame, remove spark plug wires and crank it over.
Posted via FF Mobile
disciplerocks is offline
Old 04-29-2010, 02:33 PM   #26
a_2000_se
a_2000_se's Avatar
Fan#: 62964
He mentioned it was a double pulley so I guess it could be both.
Who would have thought to check the "How-to's". Sometimes it's more fun to reinvent the wheel - I know I like to do that, lol.
But what torque is now on that bolt is anyone's guess. And that 1.6 liter engine probably doesn't have a big starter - but then it, isn't my car.
I'm kind of leaning toward the 'jack method', clean and controlled. Just make sure you put the wrench handle on the 'correct' side of the bolt.
Actually I thought we just might be trying to increase the 'hits' on FF !
60k+ miles.
Old 04-29-2010, 02:43 PM   #27
the_doc735
Fan#: 74469
What I Drive: focus lx blue
FF Reputation: 1 the_doc735 Good Standing Member
use a standard (regular) 3 leg puller!
the_doc735 is offline
Old 04-29-2010, 02:45 PM   #28
the_doc735
Fan#: 74469
Is the car still drivable? My Ingersol 1/2" impact is rated at over 750 ft lbs. That`ll get r done. One way or another..
no its not drivable without reassembly!
Old 04-29-2010, 02:46 PM   #29
the_doc735
Fan#: 74469
As for the torque behind it, I have no idea. It's just an old impact gun that my dad has. I will ask him tomorrow what the torque setting is on his impact gun if he even remembers lol. I have also removed these bolts from other cars using two people, one person to hold the pulley and another person with a short 6 point socket and breaker bar with an extention on the breaker bar. Just had to use short tugs at it to loosen the bolt up but it came out fine in the others as well.
may yet try 2 strong men AGAIN!
Old 04-29-2010, 02:48 PM   #30
the_doc735
Fan#: 74469
car is not drivable without reassembly
