removal of crankshaft pulley bolt? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-27-2010, 06:57 PM   #1
the_doc735
Fan#: 74469
What I Drive: focus lx blue
FF Reputation: 1 the_doc735 Good Standing Member
Question removal of crankshaft pulley bolt?
will a 450 Nm impact wrench remove the crankshaft pulley bolt on a 1.6 zetec SE petrol engine?
I have tried breaker bars, chain wrenches, rubber loop wrenches, long handle spanners, tapping with hammer and heat treatment, plus release oil; all with no effect at all except to bust the timing slots in the camshafts (with a timing bar). Spent endless hours on this scenario and its beginning to wear me down!!! ~ How the hell do I shift this bolt? I have also tried two very very strong men pulling in opposite directions which didn't work (except for causing one of them great personal injury!).
Advice please....
cheers, many many thanx!!!
PS: the pulley itself is smooth and flat with NO holes for a holding tool to insert. It's actually a double pulley with the larger one nearest to the block and a slightly smaller pulley in front of it.
the_doc735 is offline
Old 04-27-2010, 09:24 PM   #2
Elder
Points 12,735, Level 73
Points: 12,735, Level: 73 Points: 12,735, Level: 73 Points: 12,735, Level: 73
Level Up 72% Completed
Posted via FF MobileHave at it! Alternating directions sometimes is the trick for the REAL stubborn ones. Shortest socket that fits and NO extension if possible. (extension soaks up the impact). Bloody thing isn`t reverse threaded is it? (anyone knowledgeable chime in now...) Luck!
sailor is online now
Old 04-27-2010, 10:43 PM   #3
mikeeshaq
Fan#: 72526
Points 626, Level 12
Level Up 52% Completed
Hmmm...
Reverse threaded....
imagine if that bolt was loose, now what is the normal rotation of the engine?
Would the loose bolt start to turn in or out?
The design engineers would have made it turn in for normal running
mikeeshaq is offline
Old 04-27-2010, 10:55 PM   #4
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Points 4,699, Level 43
Level Up 75% Completed
Engine rotation is clockwise looking into the pulley and Bolt is not reverse threaded as I recall - for a U.S. SOHC SPI.
Are you sure you really want to use an impact on that bolt?
60k+ miles.
a_2000_se is offline
Old 04-27-2010, 11:30 PM   #5
the_doc735
Fan#: 74469
not sure ...no
Old 04-27-2010, 11:33 PM   #6
the_doc735
Fan#: 74469
Originally Posted by sailor View Post
Posted via FF MobileBloody thing isn`t reverse threaded is it?
my main dealer says it's anti clockwise to release that bolt.
Old 04-27-2010, 11:33 PM   #7
the_doc735
Fan#: 74469
Originally Posted by mikeeshaq View Post
Hmmm...
don't know?
Old 04-28-2010, 12:05 AM   #8
Elder
Posted via FF MobileJust covering all bases w/reverse thread question... (would turn out) Why NOT use impact? Normal tool when you can get at it with one... Reversing directions with an impact helps remove stuck bolts - Same as with wrench but more so as impact gets a better "hit" when you catch it`s mechanism just right - back & forth gets you that extra impact ...
Old 04-28-2010, 12:30 AM   #9
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,996, Level 74
Points: 12,996, Level: 74 Points: 12,996, Level: 74 Points: 12,996, Level: 74
Level Up 37% Completed
Forum Activity 32%
Buy-Sell-Trade Rating: (45)
To loosen the crankshaft pulley bolt you have to turn it counter clockwise. I just recently did this when I changed my timing belt. I used an impact on mine and it took it right off of there without any issues.
zetecDon is online now
Old 04-28-2010, 08:56 AM   #10
Elder
Posted via FF Mobile^^^^ Now that sounds normal..... Can be hard without impact, no way to hold firmly....
