Just a little off the hard top... LOTS OF PICS - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-13-2010, 09:26 AM   #1
Flying56eagle
Flying56eagle's Avatar
Fan#: 69819
What I Drive: 2009 RED SANGRIA METALIC SES COUPE
Points 3,699, Level 38
Points: 3,699, Level: 38 Points: 3,699, Level: 38 Points: 3,699, Level: 38
Level Up 33% Completed
FF Reputation: 11 Flying56eagle Great Standing Member
Cool Just a little off the hard top... LOTS OF PICS
Installed the sliding ragtop on Sun, (I will say I got the ideal from seeing it on a members 4 door ride on here, so yes I copied some one, and glad I did) It's a 35"X35" sliding ragtop from streetbeat, $368.00 labor was quoted around $400-$600 Did it myself..
Before you start do have only one..
Then read all the directions before you start
Make your template and MAKE SURE IT IS SQUARE..
Place the template on the inside first and then on the roof CENTER IT And then adjust front to rear as needed, Then tape it down and mark it.
Place the frame on top to make sure it is were you want and NEED it
Then remove your head liner if needed, IN NEWER MODLES I WOULD BECAUSE OF CURTANT SIDE AIRBAGS.
Make sure you unplug all wires
Cover the interior to protect it
And This is VERY IMPORTANT, SIT DOWN CHECK YOUR SELF MAKE SURE THIS IS WHAT YOU WANT AND HAVE ONE MORE
Drill your pilot holes, I used a magnet to help grab the savings
Cut your lines out, and also have someone help at the last cuts to hold top up while cutting
Make sure you check your cut line...
And Finish your cuts
Use a fine file to clean all the edges and your corners
Place your frame back on to make sure it fits , DO NOT FORCE IT. Mark your holes and pre drill them, remove frame and enlarge holes as
needed, use 1/4 bead of really good silicone sealant, And bolt it down checking your work as you go.
Replace your headliner and when you TRIM it MAKE SURE YOU GIVE YOUR SELF 3" OF PLAY for the pinch molding, And be careful of any wires.
All in all it took around 6 to 7 total hours, for someone that has never done this before, not to bad.. and it wasn't to hard to do.. Just Make sure it is what you want..
The interior headliner was tough because the fabric has a fiberglass backing, glued to a 1/8" sheet formed fiberglass panel, so I will have to steam the fabric to take out the creases.
Still have some cleaning and touch up, and need to steam out the creases on the headliner, and will post some pics when all is done and cleaned..
Stay Focused
Some say I give them hell, I just tell them the truth , They think it's hell
Last edited by norcalfocus01; 04-14-2010 at 12:41 AM. Reason: Cleaned up the layout for eaiser reading and fixed title.
Flying56eagle is offline
Old 04-13-2010, 09:30 AM   #2
hypnoticracing
Fan#: 51709
What I Drive: 2003 Focus Sedan Zetec 5 Spd
FF Reputation: 13 hypnoticracing Great Standing Member
Buy-Sell-Trade Rating: (19)
wow deifantely unique.. looks like you took your time and di it right though
03 SE Liquid Grey zetec 5 spd
07 F150 FX2 Sport, White
Parting out the slammed sedan...
hypnoticracing is offline
Old 04-13-2010, 10:04 AM   #3
1sloho
12 years strong
1sloho's Avatar
Fan#: 111
What I Drive: '02 zx5
Points 14,517, Level 78
Points: 14,517, Level: 78 Points: 14,517, Level: 78 Points: 14,517, Level: 78
Level Up 17% Completed
FF Reputation: 17 1sloho Great Standing Member
wow man. great job. takes some balls to cut a huge hole in ur roof!!
1sloho is online now
Old 04-13-2010, 10:18 AM   #4
Hitaway
Hitaway's Avatar
Fan#: 51132
What I Drive: '03 CD Silver SVT
FF Reputation: 6 Hitaway Good Standing Member
Looks good, that had to take some guts to cut into your car. I bet the beer helped, lol.
#3712 of 6,158. 2003 CD-Silver SVT
Focus Rising 2011 @ Carlisle All Fords, Carlisle PA.
Over 100 Foci planning to come! You can be the next!
www.focusrising.com
Hitaway is offline
Old 04-13-2010, 10:19 AM   #5
Yocrew
Fan#: 54713
What I Drive: 02RedSVT #306
FF Reputation: 19 Yocrew Great Standing Member
Buy-Sell-Trade Rating: (12)
Wow, first really big move on a new coupe. That's something you can't take back. You have a rep from me sir, and I never give them out.
Yocrew is offline
Old 04-13-2010, 10:40 AM   #6
GrndZero
GrndZero's Avatar
Fan#: 9630
What I Drive: 2002 Silver ZX5
FF Reputation: 3 GrndZero Good Standing Member
Not only is that a great idea and looks like it was done very well. You have one awesome garage!
2002.5 Silver Euro ZX5
GrndZero is offline
Old 04-13-2010, 10:50 AM   #7
puppetman
rawr
Fan#: 65577
What I Drive: 07 ZX3, 86 honda vf500f, 81 Vespa
Points 3,508, Level 37
Points: 3,508, Level: 37 Points: 3,508, Level: 37 Points: 3,508, Level: 37
Level Up 6% Completed
FF Reputation: 3 puppetman Good Standing Member
thats very impressive! i like it alot! and you did it with beer!
in illinois there are 4 seasons....almost winter, winter, still winter, and construction
Originally Posted by blackoutSVT View Post
hey man don't hate, it cost alot of money to look that cheap...
puppetman is offline
Old 04-13-2010, 11:00 AM   #8
Rafal
Rafal's Avatar
Fan#: 73222
What I Drive: 2005 Beige ZX4 SE
FF Reputation: 2 Rafal Good Standing Member
meen if I would try do to something like that I would have a convertible, nice JOB very clean to :)
17" Team Dynamics Monza,H&R Coil Overs, FS-Stealth Exhaust, FS CAI, tuned by TOM, GlowShift gauges, CFM 67mm TB, VF polyurethane engine mounts, FS lower & upper stress bars
SEDAN REVOLUTION-58
Rafal is offline
Old 04-13-2010, 11:12 AM   #9
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
What I Drive: 2004, Pitch Black Zx3
Points 16,184, Level 81
Points: 16,184, Level: 81 Points: 16,184, Level: 81 Points: 16,184, Level: 81
Level Up 67% Completed
FF Reputation: 13 fhh02a Great Standing Member
Buy-Sell-Trade Rating: (10)
as they say...no guts, no glory....
well sir you have guts and glory...... cause there is no way in hell that I would do that
fhh02a is offline
Old 04-13-2010, 11:20 AM   #10
slipster17
slipster17's Avatar
Fan#: 37217
What I Drive: 2011 Yellow Blaze Fiesta SES
Points 4,068, Level 40
Points: 4,068, Level: 40 Points: 4,068, Level: 40 Points: 4,068, Level: 40
Level Up 59% Completed
FF Reputation: 16 slipster17 Great Standing Member
Buy-Sell-Trade Rating: (11)
awesome Ron, simply awesome. Can't wait to see this at one of the meets over the summer.
To be entirely honest, when you talked about doing this at Tunerwars, I didn't think you would actually follow through with it! lol.
April 2010 ROTM
2011 Yellow Blaze Metallic SES Fiesta hatch
Carlisle All-Ford Nationals 2011 1st Place - Fiesta Class
slipster17 is offline
