Rear Squeak Solved! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-17-2010, 12:40 AM   #1
NemesisEnforcer
Force-Powered Focus
NemesisEnforcer's Avatar
Fan#: 48598
What I Drive: LIQUID GRAY 2005 ST
Points 18,461, Level 86
Points: 18,461, Level: 86 Points: 18,461, Level: 86 Points: 18,461, Level: 86
Level Up 23% Completed
FF Reputation: 352 NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member
Rear Squeak Solved!
Okay, so as so many of us have posted, the focus has a tendency to develop an annoying squeak/creak when going over bumps. It comes from the rear, and can be on the left or right.
I could not believe people when they said that it could be the e-brake cables, but I secured them anyways. They go through a loop that is bolted to the frame. That bolt can get loose too, and cause its own squeak. The loops are on the sides of the car, about one foot from the rear wheel wells. The big cable goes right through them, so you can't miss em.
BUT, for me, the noise still came from time to time. So, I went under there and really looked all over. Turned out there is a plastic clamp that runs under the rear seat. It gets loose over time, and when you hit a bump, it can move, causing that squeak. It holds the e-brake cable in place further up the car, away from those bigger loops that are about a foot fwd of the rear wheel wells. This clamp is about two feet in from the side of the car, more near the center.
Trust me, when you touch this spot, and you hear the noise, you know IMMEDIATELY that this is what has been driving you nuts. It makes the exact noise I hear in the car. It sits up a bit, recessed under the back seat. I tried to get some pics of the spot for you guys. I put some grease on it, but it also flips over (rotates), and you can then put the cable back into the clamp. When flipped, it tightens right up. No more noise. I dreaded when I first started to go over the usual bumps that cause the problem noise, but boom, no more noise.
Pics:
The white clamp in the middle is the problem, with the green thing going through it. Its all tight now, in that pic...before, the clamp faced upwards instead of down, and it was loose.
You can see some of the white lithium grease I applied squishing out from under the clamp.
Look for those other hoses/lines you see in the pics, and you will see it.
If you have this damn random rear squeak, check this out. If you try it, post up your results!
Hope this helps. I know it drove me NUTS.
GIVE DUE REP!! ST Crew #78 /Duratec Crew #91
Go Pats!! Go Green!! Go Sox!! Go B's!
Seeker of Wisdom, LG Crew #1
Resident Sith Lord & Jedi Master, MMA
Thx to those in the military.
NemesisEnforcer is offline
Old 01-17-2010, 12:39 PM   #2
TaylorinAlaska
TaylorinAlaska's Avatar
Fan#: 62423
What I Drive: F-dub soon-to-be
FF Reputation: 17 TaylorinAlaska Great Standing Member
I always thought my spring holder things were misaligned, causing the springs to rub the frame. Well its worth a try, thanks!
Originally Posted by Peregrine View Post
Who in their right mind would run 185's on a 7"wide tire? That's retarded.
TaylorinAlaska is offline
Old 01-17-2010, 02:51 PM   #3
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
What I Drive: 2004, Pitch Black Zx3
Points 16,184, Level 81
Points: 16,184, Level: 81 Points: 16,184, Level: 81 Points: 16,184, Level: 81
Level Up 67% Completed
FF Reputation: 13 fhh02a Great Standing Member
Buy-Sell-Trade Rating: (10)
Ill check that out
fhh02a is offline
Old 01-17-2010, 06:51 PM   #4
NemesisEnforcer
Force-Powered Focus
Fan#: 48598
Originally Posted by fhh02a View Post
Ill check that out
Seriously! I thought it was the springs too. I even did the flip thing. Nope. Was this little clamp the whole time. You have no idea how gratifying it was when I tapped it, and that exact noise occurred...
Old 01-18-2010, 01:00 PM   #5
puppetman
rawr
Fan#: 65577
What I Drive: 07 ZX3, 86 honda vf500f, 81 Vespa
Points 3,508, Level 37
Points: 3,508, Level: 37 Points: 3,508, Level: 37 Points: 3,508, Level: 37
Level Up 6% Completed
FF Reputation: 3 puppetman Good Standing Member
hmmm i might have to try this when it gets warmer out. that creak is so DEAD!
in illinois there are 4 seasons....almost winter, winter, still winter, and construction
Originally Posted by blackoutSVT View Post
hey man don't hate, it cost alot of money to look that cheap...
puppetman is offline
Old 01-18-2010, 10:42 PM   #6
NemesisEnforcer
Force-Powered Focus
Fan#: 48598
kill it!!
has anyone tried this yet, of those who have this issue? id like to hear the feedback.
Old 01-23-2010, 11:32 PM   #7
NemesisEnforcer
Force-Powered Focus
Fan#: 48598
bump...anyone tried this?
Old 02-01-2010, 04:02 PM   #8
JAMUS
JAMUS's Avatar
Fan#: 50025
What I Drive: 2007 Liquid Grey ZX5
FF Reputation: 10 JAMUS Great Standing Member
i'm still have suspension issues. i have new springs sitting at home. When the weather gets warmer i'm ripping off the rear sway and i'll do this at the same time. I'll post my results in the spring
Done: Debadged,Tinted, MBRP SS 2.5 exhaust, K&N CAI
Soon: tinted sidemarkers
Last of the Hatches #48 Team DURATEC #151 SAP Krew #4
JAMUS is offline
Old 02-01-2010, 04:16 PM   #9
NemesisEnforcer
Force-Powered Focus
Fan#: 48598
ur getting that squeak tho?
Old 02-01-2010, 04:21 PM   #10
JAMUS
JAMUS's Avatar
Fan#: 50025
i've had that squeak since i bought the car lol
JAMUS is offline
