Removing Glued Inst. Cover/Cust. Bezel Install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-10-2006, 05:36 PM   #1
zxdubya
Fan#: 31543
What I Drive: 2003 ZX3 PZEV
FF Reputation: 1 zxdubya Good Standing Member
I bought a brushed aluminum instrument panel bezel, but I couldn’t install it because the plastic lens covering the gauges was glued to the shroud or housing (I used both terms interchangeably). The instructions said I would have to cut it off with a Dremel and cutting disc. I didn’t want to go there, but I couldn’t find any details on the Forum on how to remove the lens when it’s glued or install a custom bezel over the stock one. [I corrected the pictures] Here’s my adventure:
Tools I needed for this job: scissors, an old dental tool, and a bottle of De-Solv-It:
With the nozzle set to “stream, “ spray only the bottom section of the shroud, inside and out, all the way across, and let it sit for a minute or two.
Using your fingers, grab the center of the bottom of the shroud and GENTLY rock the black part (not the clear lens) back and forth. It will start to creak and crack as it works loose.
Then move to one side, gently rocking the black part as you go, until it breaks loose. When you get to the section where the mounting tabs are, and on into the corners, use your finger to press it into the seam where the lens meets the black frame—from the inside—until it breaks loose. (I don’t recommend using the bolt tabs to rock this section as you did in the thin center section; I developed cracks in the lens near the sides of the tab. They were small and were covered up when I installed the assembly. Hopefully they won’t continue to grow)
I removed the icon film (for lack of a better description) from each side of the housing and washed and dried them.
Then I washed and dried the entire assembly because I sprayed all of the seams before I figured out I could slip the bezel in from the bottom and everything got coated. If you do wash yours, use a LINT FREE soft cloth to try it. A small paintbrush can be used to clean up any lint inside the assembly.
Once you’ve opened up the bottom, slide the bezel in by, again, gently pulling the black frame away from the lens. Be careful to not scratch the interior of the housing or the lens.
Once you have it inside, check the fitment.
If it looks good, turn the assembly over so you’re looking at it from the back.
Let the bezel lay on the lens (you might want to put a piece of paper between the lens and to bezel to avoid scratching the lens), and cut the double-sided tape to fit on various locations on the bezel (I put most of mine on the top and sides). Pull the backing strip off the tape (I used the scissors to put the tape into place) and press the pieces of tape in place on the bezel. Again, be careful not to scratch the lens when you do this. Make sure all parts of the tape are secured to the bezel or it will try to peel off when you remove the other backing strip.
Now, remove the second backing strip. This one was difficult because of the tight space and because there was nowhere to grab this backer. This is where I used the dental tool:
The long handle and pointed tip made it easier to pull the flimsy, invisible, second backing strip off. If the tape hangs over where it can be seen from the front, just use your finger to roll that part out of the way; the tape sticks to itself really well. Carefully turn the entire housing back so you can see it from the front. Line everything up and press it into place. Tada!
I didn’t bother reattaching the bottom seam. I hope this won’t cause a moisture/fogging problem later.
Here’s how it looks:
Mildly Modded '03 PZEV
zxdubya is offline
Old 04-10-2006, 06:47 PM   #2
levelseven
Registered User
Fan#: 28167
What I Drive: zx3
FF Reputation: 1 levelseven Good Standing Member
That looks sooooo good
levelseven is offline
Old 04-10-2006, 06:59 PM   #3
StealthGray
StealthGray's Avatar
Fan#: 19017
What I Drive: '04 Liquid Gray ZX3
FF Reputation: 12 StealthGray Great Standing Member
That's sweet! I've been seeing all the threads on the gauge backgrounds, and none have impressed me enough to even consider all the work involved. Then you had to go and post that bezel... dang!
You know what a learning experience is? A learning experience is one of those things that says, 'You know that thing you just did? Don't do that.' - Douglas Adams
StealthGray is offline
Old 04-11-2006, 10:07 AM   #4
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'HOW TO ARCHIVE'..... nice work!
Chad (S2)
S2 is offline
Old 11-23-2009, 10:50 PM   #5
FocusMoosh
Fan#: 70753
What I Drive: 2001 Ford Focus ZX3
FF Reputation: 1 FocusMoosh Good Standing Member
Please re-upload these photos!
FocusMoosh is offline
Old 11-24-2009, 05:23 PM   #6
MetalHead
Fan#: 68434
What I Drive: 2000 Atlantic Blue ZTS
FF Reputation: 1 MetalHead Good Standing Member
Agreed.
MetalHead is offline
Old 02-02-2010, 12:27 AM   #7
zxdubya
Fan#: 31543
Pics are back up!
zxdubya is offline
Old 02-02-2010, 08:09 AM   #8
akcapfoc
akcapfoc's Avatar
Fan#: 64965
What I Drive: 07 Focus ZXWagon SE, CD Silver, MTX
FF Reputation: 1 akcapfoc Good Standing Member
Thx!
akcapfoc is offline
Old 02-02-2010, 09:25 AM   #9
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2000 Explorer 4x4, 04 Mini Cooper S
Points 4,625, Level 43
Points: 4,625, Level: 43 Points: 4,625, Level: 43 Points: 4,625, Level: 43
Level Up 38% Completed
FF Reputation: 28 ah1f39 Great Standing Member
Is there a link for the brushed aluminum panel?
ah1f39 is offline
Old 02-02-2010, 04:47 PM   #10
zx360
zx360's Avatar
Fan#: 32439
What I Drive: 2005 black zx3 ses
Points 16,979, Level 83
Points: 16,979, Level: 83 Points: 16,979, Level: 83 Points: 16,979, Level: 83
Level Up 26% Completed
FF Reputation: 44 zx360 Great Standing Member
Buy-Sell-Trade Rating: (33)
they are on e-bay all the time
FocusFest 11' "Best in class" • Oct'11 HOTM • FITF'12 "Best Show & Shine" • July 12 ROTM
instagram @360DSGNS
zx360 is offline
