Go Back   Focus Fanatics > Ford Focus Discussions > Ford Focus Technical Chat
Ford Focus Technical Chat This section is for technical discussions relating to general maintenance, electrical issues, engine trouble, and recalls.
Thread Tools Search this Thread Display Modes
Old 11-07-2009, 10:22 AM   #13
FF Reputation: 213 whynotthinkwhynot Excellent Standing Memberwhynotthinkwhynot Excellent Standing Memberwhynotthinkwhynot Excellent Standing Member
Originally Posted by illinipo View Post
Right now a couple of my cyls have very uneven lash. And the problem started directly after I did this round of bucket swapping.
Yep, learned that lesson with pushrods on engines without adjustable rockers. I figured the buckets would be similar- you gotta mark them so you can put them back exactly where they came from if the valve lash is good before you remove.
It seems like the OP is getting good advice in here on what might be causing the problem. I might search for another mechanic, or ask this guy to use feeler gauges so he can tell you how much adjustment is needed. The right way to do it is to install the cams, and rotate each lobe to it's base lobe circle (backside) then measure the clearance between the bucket. To figure the actual bucket you need to make up the difference, use a C caliper to measure the thickness of the inside of the bucket and add what you need to bring it within specs.
Moderating Tech Chat and Duratec Chat, let me know if I can help.
whynotthinkwhynot is offline   Reply With Quote
Old 11-07-2009, 10:36 AM   #14
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: 2002 SE wagon "Ol' Blue" 200k miles
FF Reputation: 267 illinipo Outstanding Standing Memberillinipo Outstanding Standing Memberillinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (17)
The diffrence here is I actually know what im doing just dont have the buckets i need yet
SUV this!
illinipo is online now   Reply With Quote
Old 11-07-2009, 10:49 AM   #15
Oh thanks. I dropped the cardboard I had mine punched through and mixed them up. It took a lot longer to check clearances after the head install. OHC non-interference engines are much easier if you mess up your valvetrain.
Bookmarks
Search this Thread:
Advanced Search
Copyright 2002-2010 FocusFanatics.com. All Rights Reserved : Terms of Use : Privacy Policy : Advertise Information : Site Map
