| Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more. Sponsored By: ![]() |
Thread Tools | Search this Thread | Display Modes |
#1 |
will lowering springs from 08 fit 07?
will lowering springs from 08 focus fit 07 zx5?
2007 ZX5 SES with Steeda SRI, 2.5" trubendz SS exhaust with a high flow cat Team Duratec #33 |
#2 |
Team Focalize FTW!!!
it should. they changed the designed in 07 if i believed from what it was in the previous models.
unique(adj): to break off from the crowd and do your own thing zetec crew#232 |
#3 |
Hmm. My brother bought a 2008 that has lowering springs and said if I paid for his alignment we could switch.
#4 |
yeh that can work. i also have a massive omni kit for sale. if you dont know what that is, its basically a conversion kit to fit previous gen springs that were meant for 00-04 focus onto your ride. if u want more info pm me!
#5 | |
Clarification.... the omni kit allows 00-05 front "struts" to be mounted on 06 and later cars. Naturally you have to use an 00-05 spring with the struts. Both the front springs and front struts for 06+ cars vary from the earlier cars. The omni kit allows a wider range of suspension options than what is currently available for 06+ cars. |
#6 |
Hay Geezer maybe you can help me. I have an 08 coup with 1.6 sportline springs need better struts & shocks mine are stock will the 06-07 work Ive ask Tire Rack stores around me no help there. emailed CFM thay have not replyed can not find any sportline shocks or struts for my car. this 08 is tuff dont want coilovers.
NW POSSIE #10 SCCA- IMSA Go Karting IKF#8 FS Strut Brace, Massive Rear Brace, FS Eng. Mount, FS Eng Cover, F2 Header, FS Stealth Exhaust, FS CAI, 17in Rims and AR103 Plugs, FS Tune |
#7 |
bump
#8 |
06 to 09 are pretty much the same and interchangable. I haven't heard if any changes were made for the 2010 models. As mentioned earlier, you can also use shocks from 00 to 05 models but it requires the Massive Omni conversion kit (a tapered shim and bolt) that cost about 100.00 the last time I checked.
#9 |
Just the answer i was looking for thank you I really need new struts and shocks for this 08 it will make canyon runs better
| Bookmarks |
