Spi head gasket - Focus Fanatics
Old 10-04-2009, 08:18 PM   #1
90base
90base's Avatar
Fan#: 59586
What I Drive: 2003 Cd Silver LX
FF Reputation: 3 90base Good Standing Member
Spi head gasket
I suspect my head gasket is trash can I reuse the head studs I thought I read u could on a focus but I searched to no avail.
Tnks
Brandon
Posted via FF Mobile
90base is offline
Old 10-05-2009, 06:37 PM   #2
andrew3464
Fan#: 69203
What I Drive: 2001 Red Focus 2.0 SPI
FF Reputation: 1 andrew3464 Good Standing Member
Hi Brandon,
According to the Haynes manual-"....the bolts are the stretch type that must be replaced with new ones whenever they're removed."
I replaced mine when I had the head resurfaced and valve job done.
andrew3464 is offline
Old 10-05-2009, 06:39 PM   #3
mikebontoft
Toxx
mikebontoft's Avatar
Fan#: 58647
did you ever get that head replaced btw? and yes IIRC bolts are one time one use unfortunately.
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parting) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-sold) | '75 BMW 2002 "Carby" (resto-mod racecar) | '75 BMW 2002 (donor -sold) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (alt. daily).
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
mikebontoft is online now
Old 10-05-2009, 07:06 PM   #4
trailbikerider
trailbikerider's Avatar
Fan#: 50501
What I Drive: 2002 Granny Gold ZTS, 94 2.3 Ranger
FF Reputation: 14 trailbikerider Great Standing Member
Buy-Sell-Trade Rating: (15)
They're called TTY Bolts (Torque-To-Yield) and yes, they're only good once.
Originally Posted by SVT3658
I am enjoying this ice cream like Evan enjoys drinking a beer from a koozi in a beach chair across the street from a middle school
trailbikerider is offline
Old 10-05-2009, 07:33 PM   #5
Buy new bolts, if you think you're going to be keeping that car and engine until the doors fall off, do some research and see if ARP makes bolts for the engine. Those shouldn't stretch.
Old 10-05-2009, 10:02 PM   #6
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Are the 'ARP' bolts torqued to the same spec's as the OEM bolts?
The SOHC are one time use, $24 - Felpro. The DOHC are rated for two uses before replacement - aren't they?
60k+ miles.
a_2000_se is offline
Old 11-12-2012, 12:36 PM   #7
PuntaGorda
Fan#: 105933
What I Drive: 2001, Maroon, SE
FF Reputation: 1 PuntaGorda Good Standing Member
I'm rebuilding a SOHC 2.0 SPI and have less than complete faith in the specifications provided by our trusty friends at Fel-Pro. Could I get a few second opinions on the torque specifications and end sequence for the Head Bolts? I currently have them all at 44 ft/lbs and will hold sequence until a consensus of the SPI gods has been made. Thank you.
PuntaGorda is offline
Old 11-14-2012, 01:29 AM   #8
It is routine for gasket makers and others to now suggest that ALL stressed bolts like head bolts should be changed, it is more of a guarantee their part will be successful. Besides that it sells more parts...............I notice that Felpro now calls for new bolts on engines I know for a fact don't need them.
The way you tell-
if final tightening is worded as a DEGREE OF ANGLE such as 90 degrees or 45 degrees or whatever, then yes, you need to change the bolts.
if final tighten is a TORQUE, or 44 ft.lbs. or 65 ft.lbs., etc. then bolts are reuseable provided nothing has happened to them that would warrant their being changed.
SPI seems to call for a last tighten of 1/4 turn so that is 90 degree angle, so yes, bolts need to change. They get stretched out of shape at first tightening, you can blow head gasket by using them again since they are already internally yielded (TTY, or 'torque to yield', the type of bolt).
amc49 is offline
Old 11-14-2012, 01:45 AM   #9
My stuff says.......................
go to 37 ft.lbs.
back off all 1/2 turn
go back to 37 again
go 1/4 turn more all
then go another 1/4 turn all again.
9 3 1 5 7
front
8 6 2 4 10
amc49 is offline
