car won't start after running out of gas - Ford Focus Forum, Ford Focus ST Forum
Old 06-25-2009, 12:06 PM   #1
Treyfeezy
Fan#: 66363
What I Drive: 2004 red focus sedan
FF Reputation: 1 Treyfeezy Good Standing Member
My beautiful wife who I love dearly drives an 04 Focus sedan, she ran out of gas the other day apparently over night. Drove it home knew it was low thought she could make to the gas station the next day. Not so much. Went to start the next day, nothing. I fill up the can put it n the car, still nothing. The car just makes a clicking sound form the front, and I can hear what I assume is the fuel pump trying to work form the back when you turn the key.
I have tried letting it sit for a while, tried jumping it thinking maybe it didn't have enough juice. I was told something about a fuel cut off switch located in the front kick panel. Someone else suggested putting a little gas directly on the fuel injectors.
I'm thinking it may be the starter, any other thoughts.
Treyfeezy is offline
Old 06-25-2009, 12:21 PM   #2
joshfink
joshfink's Avatar
Fan#: 50565
What I Drive: Black 2007 ford Focus
FF Reputation: 4 joshfink Good Standing Member
If its rapid clicking it might need a jump... although you said you tried that...
My wife did this with her 02 wagon... for some reason the computer died... I doubt thats the issue here though. But that is my experience with this issue... can you hear the fuel pump humming whem you turn the key? the pump is in the rear of the car too...
"Whoopie! That may have been a small one for Neil but it was a long one for me!" - Pete Conrad stepping off the LEM onto the lunar surface during Apollo 12.
joshfink is offline
Old 06-25-2009, 12:33 PM   #3
Marbs
Marbs's Avatar
Fan#: 49029
What I Drive: 2006 Red ZX3 SAP
FF Reputation: 4 Marbs Good Standing Member
Did you find the fuel cut off switch? That is usually the cause of what you're describing.
2006 Focus ZX3 SAP, Draxas Header, FS Werks Flex pipe, MBRP exhaust, CAI, Tuned, Debaged, tinted windows, FRPP lowering kit, SVT 5-spoke wheels, Black Halo Projector Headlights, Niteshaded Side markers and tails, Mazda rear wiper, mustang antenna.
Marbs is offline
Old 06-25-2009, 12:56 PM   #4
whitefox
whitefox's Avatar
Fan#: 54401
What I Drive: 2008 Ebony CC 2dr coupe SES 5spd
Points 1,952, Level 26
Points: 1,952, Level: 26 Points: 1,952, Level: 26 Points: 1,952, Level: 26
Level Up 52% Completed
FF Reputation: 35 whitefox Great Standing Member
But the fuel cut off switch does not engage unless you are in an accident, or hit something hard as in a pot hole (there would be a bent or broken wheel if this were the case)
Carl - whitefox -
Team Duratec # 164
Mid-Atlantic Team EXTREME
2008 Focus Ebony Clearcoat 2dr SES 5spd
whitefox is offline
Old 06-25-2009, 01:06 PM   #5
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Sound like the battery was run down trying to start it. Are you sure the jumper cables were securely attached when you tried to start it? Sometimes if the cables are not making a good connection, the jump will not work.
P.S. I believe that if the fuel cutoff switch is the problem the starter will still crank the engine, but the fuel will not flow. So this does not sound like a fuel cutoff switch problem.
penguin is offline
Old 06-25-2009, 01:19 PM   #6
mikebontoft
Derpy Cheetah
mikebontoft's Avatar
Fan#: 58647
Points 23,355, Level 94
Points: 23,355, Level: 94 Points: 23,355, Level: 94 Points: 23,355, Level: 94
Level Up 1% Completed
Forum Activity 20%
you could at least try the cutoff switch..... it wouldn't hurt.
just don't press the transform button hidden next to it, you wouldn't want that
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parting) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-sold) | '75 BMW 2002 "Carby" (resto-mod racecar) | '75 BMW 2002 (donor -sold) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (alt. daily).
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
mikebontoft is offline
Old 06-25-2009, 01:21 PM   #7
Treyfeezy
Fan#: 66363
I haven't looked yet. I was told about the switch later last night googled it this morning, was gonna give it a shot when I get home from work. She didn't hit anything that I know of, but she is kinda rough with a car.
Joshfink, yes it's kind of a fast clicking and I can hear the fuel pump hum
Old 06-25-2009, 01:25 PM   #8
mikebontoft
Derpy Cheetah
Fan#: 58647
Forum Activity 20%
ah.... in that case then, the vehicle doesn't have enough electrical energy to start.... so in other words the battery's dead. try cleaning off the battery posts with something like a wire brush. I had to do the same on mine, then it finally started.
(btw, unrelated......but just for the record, trying to jump a taurus with a focus is HARD when you're doing it by yourself. I had to put a book on the gas pedal to put enough voltage to the other car just a fun story lol.)
Old 06-25-2009, 01:51 PM   #9
Treyfeezy
Fan#: 66363
I will try that again when I get home. It was late and dark last night when I tried to jump it. I'll try cleaning the terminals and making sure the cables are making good contact.
Old 06-25-2009, 02:10 PM   #10
wsigo
Fan#: 57221
What I Drive: 2002 Toreador Red SE Sedan
FF Reputation: 5 wsigo Good Standing Member
Don't do that!
mikebontoft I know you said it was off topic- but I figured the explanation below would help Treyfeezy as well since it sounds like his battery is dead!
After you've connected the jumper cables to both vehicles stay in the running vehicle for 5-10 minutes with the engine revved slightly above idle. ~1500-2000 rpm will suffice. You don't need to rev any higher, as that's not going to make the alternator put out any more power. After you have held steady for awhile charging the dead battery- just let it idle back down and go try to start the other vehicle.
wsigo is offline
Similar Threads
after car gets hot my car won't start!? nsfig General Technical Chat 12 04-10-2013 08:09 PM
Command Start will not start car. ramadlyn General Technical Chat 4 02-20-2009 03:57 PM
My (mis)adventures in a 2007 Ford Fusion rental car turbovation Ford Focus & General Car Chat 42 02-01-2007 08:49 AM
April 2005 U.S. Auto Sales Scorecard Kneel Ford Focus & General Car Chat 3 05-04-2005 03:56 PM
Aussie Cleaning whippet_zetec Auto Washing, Detailing & Paint Protection 1 09-28-2004 07:32 AM
