General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
#11 | ||||
I'm still confused as to why I would get it bored if it's not out of round.
#12 | ||||
I'm having trouble finding Eagle rods for a 2.0. Can someone help me determine what compression ratio and PSI I should run with 91 octane gas? The 91 octane is important because that's so common here.
#13 | ||||
WWTPD?
Bring it home, pop it in your car and you'll be good to go. 9:1 is an excellent compression ratio for this vehicle. Decent off-boost throttle response, with enough headroom to turn up the boost without getting too finicky. Yes you need a new head gasket. You should be doing new head studs as well. And you though you could just drop in rings and pistons didn't you!!?
1287/3985 |
#14 | ||||
( o Y o )
9.0 if what you plan on running is 91 octane. If you had access to 93 (like here in Florida, that is premium) I would run 9.2 compression. Now, you would like to run more than 15 psi from time to time, that, to me, says 9.0.
And for the reasons behind boring the block out, the rings may have scored the cylinder walls and to get a good seal, those scorings will have to be removed with a boring and honing. Plus, there is no replacement for displacement!
#15 | ||||
Thanks for the input everyone.
My plans have changed again. I swung by my local salvage yard which is typically way expensive, but I thought what the heck. They had a 2006 D20 with 68 miles on it for $500. It includes the exhaust manifold, intake manifold, fuel rail, injectors, COPs etc. It was from a rollover, most likely during a test drive. So my plan is to throw that in for now (since 10psi was fine for the stock engine, the overboost hurt it) and I'll have still my current engine to take my time with building up.
| Tags |
| bottom end, forged, internals, turbo |
Similar Threads
| You're doing it wrong!(Post autofails here!) | mattsstang87 | Ford Focus & General Car Chat | 10765 | Today 02:41 PM |
| Front end Rattle fixed | Ed60 | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 2 | 05-01-2007 11:25 PM |
| Do all Focus's have the split rear BOTTOM cushion? | InFocus66 | Ford Focus & General Car Chat | 8 | 02-09-2007 07:58 AM |
| stock end links vs. prothane end links | scironzts | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 4 | 06-04-2004 11:15 AM |
