2005 Dual Halo Projector Retrofit Project - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-29-2009, 01:08 AM   #71
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
Buy-Sell-Trade Rating: (13)
^hahahaha. I'm not sure of all the special lighting terms.
UPDATE:
So I bought some 3.6V LED's from radio shack today and tried them out in the eyebrows. Blew them instantly. Instead of the light emitting diode it became a smoke emitting diode. haha (circuitry humor). I'm going to go with 12v rated LED's like I should of in the first place. I am going to have to modify the back cover of the headlight to fit the new bulb and adapter cable; just the plate that you remove to take the bulb out. No biggie there; I picked up some JB weld and I have some 1/8 inch thick vinyl sleeves around here that I'll use to extend the plate out while still using the same screw locations. Things are coming together nicely :-D
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
D23 Crew: #07
Jgrove998 is offline
Old 05-29-2009, 09:48 AM   #72
NemesisEnforcer
Force-Powered Focus
NemesisEnforcer's Avatar
Fan#: 48598
What I Drive: LIQUID GRAY 2005 ST
Points 18,461, Level 86
Points: 18,461, Level: 86 Points: 18,461, Level: 86 Points: 18,461, Level: 86
Level Up 23% Completed
FF Reputation: 352 NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member
why did you try the 3.6v leds? just cheaper?
GIVE DUE REP!! ST Crew #78 /Duratec Crew #91
Go Pats!! Go Green!! Go Sox!! Go B's!
Seeker of Wisdom, LG Crew #1
Resident Sith Lord & Jedi Master, MMA
Thx to those in the military.
NemesisEnforcer is offline
Old 05-29-2009, 02:09 PM   #73
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
Well I guess I just wanted to find out if they would work or not. Might of been easier just to get the multi-meter out and see what voltage was coming out of the LED terminals
Got my new 6000K bulbs and adapter cables today. I will do another test by mounting both lights in the car and comparing the cutoff with no lens and with the aftermarket lens. Pictures later today :-D I might even try the "washer mod" which was mentioned before. Basically it just changes the projector lens angle to produce more blue-ish light at the cut off line. But it also takes away from the sharpness of the cutoff. You can do all sorts of colors from adding more or less washers but the more washers you add the blurrier your cut off gets.
1988 F150 Custom
D23 Crew: #07
Old 05-29-2009, 03:37 PM   #74
NemesisEnforcer
Force-Powered Focus
Fan#: 48598
how do washers change the color? by augmenting the reflector?
Old 05-29-2009, 06:39 PM   #75
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
For TSX projectors you put a washer between lens and the reflector at the bottom. So basically it would be the reflector assembly then the washer then the lens assembly. There is a graphic I saw which explained it, let me find it.
1988 F150 Custom
D23 Crew: #07
Old 06-01-2009, 04:20 PM   #76
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
No, i would be augmenting the projector lens by changing the angle at which the light hits it and reflects out.
but I've decided not to do the washer mod though.
1988 F150 Custom
D23 Crew: #07
Old 06-01-2009, 04:35 PM   #77
NemesisEnforcer
Force-Powered Focus
Fan#: 48598
oh okay, why not?
Old 06-01-2009, 08:38 PM   #78
Djmike2485
Registered User
Fan#: 3230
What I Drive: Silver 2000 Ford Focus Zetec 4 Dr.
FF Reputation: 6 Djmike2485 Good Standing Member
Need pics of the washer mod thing. Come to think of it, need updated pics! :)
Djmike2485 is offline
Old 06-01-2009, 10:21 PM   #79
NemesisEnforcer
Force-Powered Focus
Fan#: 48598
yeah, i still dont get how it changes the color. seems weird.
Old 06-01-2009, 11:06 PM   #80
slowduratec
slowduratec's Avatar
Fan#: 59069
What I Drive: 2006 Toreador Red ZX3
FF Reputation: 10 slowduratec Great Standing Member
This is what he's talking about
Stock tsx projector
Then after the color mod
You get more of a bluer color at top of the cut off I got these off of Hid Planet
IT'S SLOW (KANYE WEST IS GAY!!!)
Team Duratec #236
slowduratec is offline
Similar Threads
Marathon: Life After Halo dazada Gaming Fanatics 0 11-20-2007 07:46 PM
KS dual halo uniquezx3 MK1 Focus 0 11-18-2004 02:34 AM
dual headlights with halo eyes crobro24 MK1 Focus 10 03-16-2004 11:30 AM
Project ALL-MOTOR ALL_MOTOR_ZETEC Ford Focus & General Car Chat 71 12-17-2003 10:42 PM
