Door Lock Broken? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-18-2009, 06:15 PM   #1
kavolier
Fan#: 64446
What I Drive: 05 White ZXW
FF Reputation: 1 kavolier Good Standing Member
Door Lock Broken?
Hi guys, bear with me I'm new, so I'm not sure if this exact problem was posted anywhere else. I did a quick search but didn't see anything.
I have a 05 ZXW SE. I discovered today that my rear driver door lock does not lock - does not move actually. All the other doors are fine (they work with the key fob or the lock button). If you try to push the button locked manually - it won't push locked either. I have no idea how long its been like this and of course I find out the day before I have to leave for a business trip and will have to leave it at the airport for 4 days. Lucky me.
I was hoping someone might have a suggestion as to what the problem is? Can I fix it myself (with some of husband's help)? How much will it cost? And is there somewhere I can get really really good instructions on all of the above? (I am a diagram person.)
Any help is so greatly appreciated - thanks!
kavolier is offline
Old 05-05-2009, 12:25 PM   #2
kavolier
Fan#: 64446
Bump!
Really, no one has any idea where to get started trying to solve this??
The other 3 locks and the trunk are OK. Is it mechanical? Electrical?
Should I just take it to the dealership?
PLEASE HELP!!!
kavolier is offline
Old 05-09-2009, 02:49 PM   #3
egburtus
Fan#: 65013
What I Drive: 04 glacier blue wagon German build
FF Reputation: 1 egburtus Good Standing Member
Unhappy
Originally Posted by kavolier View Post
Bump!
PLEASE HELP!!!
I have the same problem with my rear passenger door. The lock button moves freely in with the handle when I open the door, toward the "unlock" position, but cannot be pushed or actuated with the remote. It did the same thing about a year ago, and to the best of my memory, I just forced the button into the lock position. It worked fine until about a week ago. I tried pushing it, with no luck. Obviously, something is bound up inside the door. I tried removing the door panel, but got stuck with the window crank. Can't figure out how to remove it without breaking it. Anyone out there know how to fix this, or keep it from happening again?
egburtus is offline
Old 05-09-2009, 02:55 PM   #4
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,650, Level 94
Points: 23,650, Level: 94 Points: 23,650, Level: 94 Points: 23,650, Level: 94
Level Up 30% Completed
Forum Activity 16%
hmm well I have the same trouble.....I think. My right rear door will lock alright if I press it manually, but with the remote it will not....it makes that really annoying loud motor sound.
I had my shop teacher look at it and he says the motor/actuator itself has likely been stripped, and I'd need to get a new one. Only problem is if you do buy a new one, it comes with the door latch as well, which means more cost.
mikebontoft is offline
Old 05-09-2009, 04:02 PM   #5
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
From the description it probably is a bad actuator..... and it does come with the latch. They cost around $140, from the dealer.
As to installing it yourself.......not a job for a beginner. You'll get in over your head in a minute or so.
My driver door actuator/latch broke under warranty. The Ford mechanic who was doing the job, broke some linkage pieces during the installation. I was waiting....they ended up giving me a free rental car for two days.
I'll keep my guns, my freedom, and my money.....you can keep the "change".
bluefront is offline
Old 05-09-2009, 10:10 PM   #6
Happenedtoyou
Happenedtoyou's Avatar
Fan#: 11169
What I Drive: 2007 Ford Focus ZX5 with SAP
FF Reputation: 1 Happenedtoyou Good Standing Member
Door Lock
Good News and Bad News...
Good news is you probably don't need a new lock cause it an easy fix... but the bad news is, it is a bitch to take the whole thing apart.
I had the SAME exact problem on the SAME exact door, only on my zx5. You need to get the actual electronic mechanism out, in your hand, away from the door. Take that apart till you see the wheel in there and the motor, and make sure it moves freely. I did this, and what seemed to happen is that the gears jumped a step.. and they need to be put back literally. I fixed it, and it works now.. FORD wanted to charge me 50$ to check it out, and probably would of charged me over $100 to get a new lock..
It took me an hour to fix it with the help of my roomie.
Good enough?
SPZ
Szymon Zmijewski
____________________
2007 Ford Focus ZX5 Black
Happenedtoyou is offline
Old 06-26-2010, 02:46 PM   #7
maestro
Fan#: 76258
What I Drive: 2004 Ford Focus
FF Reputation: 1 maestro Good Standing Member
Question How to fix this?
I seem to have the same problem with a European 2000-2005 Focus. My rear door would not lock and the lock button on the door would not press in to lock. The central lock would not work either.
Any new advice on that? I couldn't find anything better than this thread.
I managed to take apart the door's panel & insulation and then to unscrew the lock itself, but I didn't manage taking the lock mechanism out as it's attached to the outside handle and it's too difficult seeing what's inside the door's body.
I'm afraid a mechanic would just replace the whole assembly for too much $$$.
It can't be something requiring a reset, can it?
Any advice on how to take the lock out or otherwise fix this? Maybe schemes of how things look inside the door?
Thanks in advance for any idea!
maestro is offline
Old 06-27-2010, 01:27 PM   #8
Elder
Points 12,874, Level 74
Points: 12,874, Level: 74 Points: 12,874, Level: 74 Points: 12,874, Level: 74
Level Up 6% Completed
FWIW - try spray lube on mechanism first, rear door TSB on my '04 to do this to prevent such problems, and just a good general practice anyways...
sailor is online now
Old 06-27-2010, 02:13 PM   #9
maestro
Fan#: 76258
Thanks sailor.
I did use WD-40, although I later read someone recommending against this one.
It never got tough to lock tho. It went straight to impossible.
maestro is offline
Old 06-27-2010, 02:59 PM   #10
Elder
Ah well, never hurts to try - spray penetrating grease for general maint. is the ticket - WD-40 as you tried to free up something that's already not working well.
Sometimes the problem with not locking is that it isn't fully latching, preventing the lock mechanism from working - normal operation as it won't lock when not fully latched...
So lubing then cycling mechanism by opening and closing a number of times would be the trick to be sure the "simple" fix isn't all you need.
Sounds like your problem is deeper, but this works for some with less of a problem..
Similar Threads
HOW TO: Fix / Weld broken ZX3 Driver's seats niko MK1 Interior Mods & Upgrades 7 07-31-2013 08:47 PM
[How To] Removing a broken bolt. Algorhythm General Technical Chat 6 07-31-2013 06:40 PM
Broken Rear Window refemall MK1 Focus 6 02-02-2011 08:29 PM
got my new$670 hid lamp and it was broken Milwaukee MK1 Focus 12 09-20-2008 09:37 PM
Old or Broken Turbo arrestmespi General Forced Induction 5 11-08-2005 07:54 PM
