Basic Bolt-ons: Intakes and Induction - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-20-2009, 05:04 PM   #1
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
Points 32,363, Level 100
Points: 32,363, Level: 100 Points: 32,363, Level: 100 Points: 32,363, Level: 100
FF Reputation: 201 warneej Excellent Standing Member warneej Excellent Standing Member warneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
One of the first aftermarket parts folks like to install on their cars are aftermarket intakes. An aftermarket intake in most cases removes the stock airbox and replaces it with more of a free flowing setup. In this Topic I will go over what kind of intakes are out there and the pros and cons of each. Remember, all intakes fit both the 2.0L and the 2.3L. The only oddball is the 08-10 which only accepts the Steeda/FocusSport/AirRaid units as of yet.
NOTE: I have included links for pricing and pictures but by no means am I suggesting buying the particular product from that particular vendor. Do some shopping around, find the lowest price including shipping as that can be the deal breaker!
First off, there are two different styles of intake/induction setups. There is the shorty or short ram style and there is the cold air induction. Separately I have mentioned the "custom" intakes we have come up with.
Replacement Panel Filter:
There is no replacement panel filter for all but the 08-11 (non-PZEV) Foci due to Ford's decision to install a "maintenance free" lifetime air filter.
For the 08-11 (non-PZEV) models, K&N makes part #33-2401 which is available for around $45.99 from your local parts store.
Short ram intake:
Steeda 05-07 (note: will fit the 03-04 DTEC engines, but it is very tight against the headlight)
Steeda 08-10
AIRRAID Cold Air Dam Intake System 08-10
"Custom Short Ram"
The Custom Short Ram is built by removing the stock MAF tube, shaving off the tabs on both ends, flipping it and dremeling out the MAF sensor opening so that way it will fit in there facing the correct way, and then attaching one end to the stock throttle body boot and attaching a cone filter to the other end. It should sit right behind the driver's side headlight. If someone can find the "how-to" thread on this that would be greatly appreciated.
PROS
The benefit of this type of intake is that they are simple to install, they are fairly cheap and they give decent gains. Also, no risk of hydrolock.
CONS
These intakes can be louder then stock, for some folks this is a problem. Even though Steeda included a heat shield, they still take in ambient under hood air, which when the temps are hot can decrease power. There is a decent amount of air moving around when the vehicle is in motion however.
Cold air intakes:
Here are some of the more common cold air intakes you are likely to find.
FocusSport Cool-Flo (NOW FITS 08-11!)
K&N FIPK2
K&N Typhoon
Cosworth (discontinued)
F2 CAI
AEM CAI
"Stealth CAI"
PROS
These intakes make nice gains throughout the rpm range, mainly due to the fact that they locate the filter in an area where it can take in fresh air.
CONS
Most CAI setups use a tube which requires the stock electronics from the MAF sensor to be removed from its stock housing and then placed in the intake tube. This makes upgrading to a larger MAF impossible without buying a new intake. CAI setups also place the filter in a location where it is able to get very dirty very quickly. CAI require more frequent maintenance than short rams. CAI setups are also susceptible to water ingestion, being that the filter sits so far down near the ground.
These are not all of the intake setups for the Duratec motor, they are a group of the more common and more well known parts.
Comments, discussion, and corrections welcome!
173.4whp
gump
crew #6
warneej is offline
Old 03-20-2009, 05:24 PM   #2
norcalfocus01
Fan#: 55603
What I Drive: White N Gold 2001 Sedan
FF Reputation: 132 norcalfocus01 Excellent Standing Member norcalfocus01 Excellent Standing Member
nice write up bro!
norcalfocus01 is offline
Old 03-20-2009, 05:42 PM   #3
UnFocusedST
Fear the TurboSnail!
UnFocusedST's Avatar
Fan#: 40342
What I Drive: 2013 Performance Blue Focus ST
Points 6,373, Level 52
Points: 6,373, Level: 52 Points: 6,373, Level: 52 Points: 6,373, Level: 52
Level Up 12% Completed
Forum Activity 10%
FF Reputation: 13 UnFocusedST Great Standing Member
Buy-Sell-Trade Rating: (14)
You did forget the F2 CAI.
Team Duratec #17
Hatch Nation #17
Midwest Crew #55
Boosted Crew #118
UnFocusedST is offline
Old 03-20-2009, 05:47 PM   #4
warneej
warneej's Avatar
Fan#: 20372
its not on their website...is it still available?
173.4whp
gump
crew #6
warneej is offline
Old 03-20-2009, 06:25 PM   #5
besthaticouldo
i wear no pants
besthaticouldo's Avatar
Fan#: 26970
What I Drive: '11 OBP WRX Sedan
Points 32,001, Level 100
Points: 32,001, Level: 100 Points: 32,001, Level: 100 Points: 32,001, Level: 100
Forum Activity 6%
FF Reputation: 104 besthaticouldo Excellent Standing Member besthaticouldo Excellent Standing Member
Buy-Sell-Trade Rating: (23)
its the same as every other...
plus im not sure they are still making focus parts.
remember that building a car shouldn’t come from parts it should come from deep inside your soul. let the car speak for all the emotions, memories and experiences youve made and the car will take a life of its own. truth over fame.
besthaticouldo is online now
Old 03-20-2009, 11:00 PM   #6
focusboy5
focusboy5's Avatar
Fan#: 50002
What I Drive: Four Wheels
Points 8,173, Level 61
Points: 8,173, Level: 61 Points: 8,173, Level: 61 Points: 8,173, Level: 61
Level Up 8% Completed
FF Reputation: 31 focusboy5 Great Standing Member
Buy-Sell-Trade Rating: (13)
http://www.f2usa.com/index.php?main_...&products_id=1
focusboy5 is offline
Old 03-20-2009, 11:15 PM   #7
warneej
warneej's Avatar
Fan#: 20372
done
173.4whp
gump
crew #6
warneej is offline
Old 03-20-2009, 11:26 PM   #8
1-ST
1-ST's Avatar
Fan#: 53127
What I Drive: various duratec powered vehicles
Points 721, Level 14
Points: 721, Level: 14 Points: 721, Level: 14 Points: 721, Level: 14
Level Up 21% Completed
FF Reputation: 10 1-ST Great Standing Member
Marcy is discontinued, but probably more likely to turn up for sale than Cosworth. People cling to their Cossie stuff.
05 ZX4 ST - parts donor. Daily driver until a rock found the oil filter and locked the motor.
08 S Coupe - autocross toy. Less weight and more tire.
06 Ranger - lowered commuter and parts hauler.
1-ST is offline
Old 03-21-2009, 02:30 AM   #9
the_07ninja
Gal. 2:20
the_07ninja's Avatar
Fan#: 45089
What I Drive: 07 ZX3 some red color.
FF Reputation: 88 the_07ninja Excellent Standing Member
This thread is a wast of time, we have all seen the past ones just like this and know that no one new is going to search for this or even glance at it even if it gets stickied. There will still be the one who just post it any ways, nothing wrong with that, it just gives us all stuff to talk about. But the effort was in good intention. I hope this thread goes some where.
Team Duratec #36
RIFF crew /
L.O.T.H #69 baby
Originally Posted by jhurst747 View Post
Any man comfortable enough to use Vanilla Ice as his avatar is my hero.
the_07ninja is offline
Old 03-21-2009, 03:10 AM   #10
x FoCuSfReAk x
Lets get twisted
x FoCuSfReAk x's Avatar
Fan#: 60594
What I Drive: '05 Jeep WK
FF Reputation: 7 x FoCuSfReAk x Good Standing Member
Sure many people will still ask questions about this thread. But isn't that part of the reason we have the forums? I'm sure it will be helpful to a lot of the newer people to the focus world and will help them in selecting the parts they want. I think it's a great idea to help out a bit.
Nice write up!!
The fo is gone...she will be missed...
Originally Posted by mikebontoft View Post
lol I bet that was a kick in the ego pants.....
x FoCuSfReAk x is offline
Tags
cai , cold air intake , duratec intake , intake , k&n , ram air , short ram intake , sri
Similar Threads
Basic Bolt Ons: Intakes And Induction focaltech ZETEC Performance (2000-2004) 108 08-01-2014 07:39 PM
Zetec : Basic Bolt Ons Threads admin ZETEC Performance (2000-2004) 0 07-29-2004 10:28 AM
