#1 | ||||
暗炎
How To: 05-07 Halo Projector CCFL Transformer Replacement
As of now, the 2005 to 2007 Focus only has one option for aftermarket headlights.
![]() The Halos in my passenger light went out last week. Since these halos are the CCFL type, I assumed that both of them going out simultaneously had to be the result of a blown transformer. This is partially because I've had CCFL tubes inside my car before and experienced many transformer changes. What you will need: New transformer (http://www.oznium.com/cathode-transformer) 10 mm socket 7 mm socket Phillips head screwdriver Flat head screwdriver / Knife Pliers Wire strippers Soldering iron with solder Electrical tape / Heat shrink tube Double sided tape Remove Headlight. Remove cover for high beam bulb (reflector housing). ![]() and locate a black box with a white label. ![]() The box is attached with double sided tape. Place a flathead screwdriver or knife under it and pry it up. Theres plenty of extra wire, so don't worry about accidentally removing the halo lights. I cut the power wires to the transformer in order to make working on it easier. Once out, pry it open with a flathead screwdriver or knife. ![]() This is necessary to disconnect the wires from within the transformer. The only issue here is that they are glued in. I used pliers to crush the circuit board and cut the unneeded connector. Your other option is to cut the wires and solder on the new ones. Once out, the original connectors will plug straight into the new transformer. Since I cut the wires going into the transformer, I had to solder them to the new connector. If you decided to cut these wires, don't forget to replace the rubber grommet. Reconnect your wires. Apply double sided tape to the new transformer and replace it inside your headlight. ![]() Reinstall your headlight and make sure everything is working.
Remove Advertisements |
#2 | ||||
good to know incase mine go out.
nice write up
teamduratec #143! focus sport cool-flo, f2 v.3 header, trubendz 2.5 SS, frpp 1.5" front sportline rear, vf rear engine mount, 93oct Focus Power tune |
#3 | ||||
"Party Pic WHORE"
^tru dat!! good info!!
ST crew #29 team DURATEC #53 MBRP exhaust, SRI, BFG G-Force sports, Steeda STS, painted stock rims, 1 12" diamond audio D6 sub, 3201T audiobahn amp, JVC headunit, Kicker 6X8's, 2 Farad cole cap, FC front strut bar, under body LED kit |
#5 | ||||
Nice. Mine went out a while ago. I didn't have the time or intelligence to find the needed replacement parts. I just put my stockers back in. Now, I can fix my halos and put them back in. I liked the look better than the stocks. Even though the light throw sucks, a bunch on the halos... ;-)
2007 ZX4, 2.0 liter Duratech, MBRP, Cossie CAI, Tri-Ax, SVT suspension, and blacked out CCFL halo projectors (halo died in one, but I got it fixed! Waiting for HID conversion kit). Not much else, yet... ;-) |
#6 | ||||
暗炎
Thats exactly why I did this write up.
Its sort of simple and not very hard, but if you don't know what you're looking for it can seem overwhelming |
#7 | ||||
Thanks DarkFire. I now have mine repaired. Worked like a charm.
Thanks again. Now I just need to wait for my HID conversion it to show up... Cliff
#8 | ||||
Similar Threads
| "HOW TO" Ebay Halo Projector led replacement (56K WARNING) | scrammer | MK1 Focus | 188 | 01-22-2013 12:19 PM |
| Halo Light Replacement Question | Blitzkrieg2003 | MK1 Focus | 0 | 04-21-2008 10:29 PM |
| KS Halo Replacement Bulbs? | lildisco | MK1 Focus | 9 | 08-26-2005 11:28 AM |
| Replacement Halo Light Housings | randazzm | MK1 Focus | 0 | 01-09-2004 10:32 PM |
| Projector w/ halo replacement | triplehsoul | Archive | 0 | 01-03-2004 10:25 PM |
