Horn does not work - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-23-2008, 01:06 PM   #11
gonzorelic
gonzorelic's Avatar
Fan#: 13348
What I Drive: 2003 Pitch Black SVT Focus ZX5
FF Reputation: 31 gonzorelic Great Standing Member
id like to get a horn off a truck or something. something with a deeper tone. may have to hit the junkyard.
Jealousy is contagious,
Get well soon bitch!
WWW.PATTERNTEK.COM
WWW.SNAPOFFRACING.COM
gonzorelic is offline
Old 11-23-2008, 01:49 PM   #12
ajp
ajp's Avatar
Fan#: 54748
What I Drive: Red 2003 EAP
FF Reputation: 8 ajp Good Standing Member
PIAA supertones ftmfw
ajp is offline
Old 11-23-2008, 04:41 PM   #13
gonzorelic
gonzorelic's Avatar
Fan#: 13348
i had a hornblasters train horn on my truck. hornblasters.com FTMFW!
WWW.PATTERNTEK.COM
Old 02-16-2013, 04:06 PM   #14
roughrider
Fan#: 69505
What I Drive: 2000 focus
Points 21, Level 1
Points: 21, Level: 1 Points: 21, Level: 1 Points: 21, Level: 1
Level Up 41% Completed
FF Reputation: 3 roughrider Good Standing Member
This is just an update to this thread.
When I recently discovered my horn had quit working i went through all the steps to test and make sure it was actually getting power. Once I determined that it was the horn that was faulty I removed it and bench tested again with an old battery and some alligator clips on the terminals and it still didn't work.
I went thru the process of shooting WD-40 into the horn opening and sloshing it around and still nothing.
A couple weeks had passed and the horn still sitting on the bench I decided to test it again by putting the power to it and still nothing.
The difference this time was I figured i had nothing to loose and tapped the side and back beside mounting bolt with a small piece of brass rod and it started to operate intermitenly, but not steady or very loud tho.
At that point still thinking i would be throwing in the garbage I decided to mess around with the adjustment screw that is factory covered with silicon and ended up removing it and shooting a little bit of WD-40 in the hole.
This is where things get interesting and remember that i still have the leads connected so the horn is getting power as i'm putting the ajdustment screw back in the horn begins to function but this time with a steady tone.
Now I simply adjust the screw til the horn seemed the loudest and put a new bloob of silicon on the head of the screw and reinstall the horn back on the car, push the horn pad and it seems to function as it should.
Just thought I'd pass on the info for anyone that wants to save a few bucks and feels like a little challange.
261000kms and counting,,,,Wondering when the SPI will blow up!
2 zetecs for backup just in case.
roughrider is offline
Old 02-16-2013, 05:36 PM   #15
Elder
Points 13,449, Level 75
Points: 13,449, Level: 75 Points: 13,449, Level: 75 Points: 13,449, Level: 75
HeHe
Good to know the stock horn is that type!
VERY common "fix" I did often on motorcycles. They get used so seldom, plus the change in stiffness of materials from age... re tuning them usually "fixes" them for quite a while in my past experience..
Thanks for the update!
sailor is online now
Old 02-16-2013, 06:07 PM   #16
xxMichaelAnthony
xxMichaelAnthony's Avatar
Fan#: 58459
Points 15,567, Level 80
Points: 15,567, Level: 80 Points: 15,567, Level: 80 Points: 15,567, Level: 80
Level Up 44% Completed
Hella makes the supertones. PIAA horns sound like shit.
[HOONIGAN]
iTroll
xxMichaelAnthony is offline
Old 02-17-2013, 04:21 AM   #17
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
Most horns are that type if you look deep enough. Simply breaking the vibration setscrew loose can often get them working again, or cleaning up breaker point contacts to make them low resistance again. Water entry or rust usually the problem. I haven't bought a horn in 40 years, I always can fix them. I, like sailor learned long ago from motorcycle horns. Only reason to buy one is for when they cheap out and give you only one and adding the opposite tone then really ramps up the noise.
I wouldn't be spraying WD40 in there, once it hits current, the current will convert it to something (bubblegum) that does not help passage of that current. It's not electrical cleaner.
amc49 is offline
Old 02-18-2013, 02:26 AM   #18
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
It's probably too late for this but you should know that Ford has a "secret recall" on the horns on the early Focuses. The NHTSA and Ford cut a deal on this - in exchange for replacing a failed horn no questions asked, NHTSA didn't require them to do a formal recall. There is a Ford TSB on this that specifies free horn replacement.
tmittelstaedt is offline
Old 02-19-2013, 08:22 PM   #19
2003focusowner
Fan#: 51939
What I Drive: 2003 Focus SE SPI
Points 5,246, Level 46
Points: 5,246, Level: 46 Points: 5,246, Level: 46 Points: 5,246, Level: 46
Level Up 48% Completed
FF Reputation: 2 2003focusowner Good Standing Member
Would you happen to know where we would find the TSB?
2003focusowner is offline
Old 02-21-2013, 01:41 AM   #20
tmittelstaedt
Fan#: 108093
Points 233, Level 4
I went to my local library where they have an Alldata subscription and looked it up - sorry I didn't save the darn number. It was kind of irritating because I had just a week earlier replaced the horn on mine with one from a wrecker so I could have saved the $10 and gotten a new horn. :-(
Similar Threads
Drive Through Car Wash Kills my horn!! cowymo Ford Focus & General Car Chat 12 06-22-2007 06:35 PM
Stock alarm horn - 2k SE vrat_on_2k General Technical Chat 1 09-09-2006 01:02 PM
Can any Ford dealer work on my SVT? eurofocer SVT Performance (2002-2004) 7 06-20-2006 11:34 PM
Hard braking = Horn? dantegl36 General Technical Chat 11 05-01-2006 12:48 PM
